loss1234
Posted: Wed Dec 05, 2007 5:52 am Post subject:
ray wilson vco versus soundlab vco |
built up the raw wilson vco (with tempco) last week. it sounds great BUT my particular pcb doesnt seem to be very good at rejecting noise caused by some of my other modules. (a soundlab vco)
now maybe this is because it needs more bypassing? anyone else have similar problems? or should i be ditching my soundlab vco for modular use?
its only when i turn the pitch knob on my soundlab vco that the pitch goes weird on my ray wilson vco
thanks _________________ -------------------------------------------- check out various dan music at: http://www.myspace.com/lossnyc
http://www.soundclick.com/lossnyc.htm http://www.indie911.com/dan-snazelle |
Pehr
Joined: Aug 14, 2005 Posts: 1307 Location: Björkvik, Sweden
loss1234
Joined: May 16, 2005 Posts: 8933 Location: Birmingham, England, UK
Posted: Wed Dec 05, 2007 9:21 am Post subject:
loss1234 wrote: |
maybe i should use 2 grounds? |
Or two PSU's (something that has already been mentioned? )
_________________ ACHTUNG!
Pehr
loss1234
Posted: Wed Dec 05, 2007 12:26 pm Post subject:
decoupling info?? |
ONE PSU FOR EACH VCO? hmmm...keep in mind this problem is ONLY happening right now with 2 vcos interacting with each other...i am not hooking up any other modules right now
keep in mind I AM NOT MIXING OR MODULATING THE VCOS WITH EACH OTHER....this drop in pitch happens when i only listen to ONE VCO..
if i have a stable vco like the ray wilson vco and i listen to it alone its fine..but then if i plug in the soundlab vco and turn the psu back on..the ray wilson vco sounds fine UNTIL i start turning knobs ON THE soundlab vco!! its crazy....b
I WILL SAy that the sn voice is less prone to this than the ray wilson vco...but even it seems to be effected by me changing the pitch on the soundlab vco,,,
update..i finished the SN voice today and hooked it up as well...same problem...so its possible that the soundlab vco is pulling down the pitch of the sn voice or ray wilson vco, but this new psu isnt allowing any drop in voltage, so this must be a noise on the line thing...
v-un-v mentioned a separate psu but i think there must be other ways to isolate modules from each other that i just dont understand yet...any info on decoupling would be appreciated _________________ -------------------------------------------- check out various dan music at: http://www.myspace.com/lossnyc
Pehr
loss1234
Posted: Wed Dec 05, 2007 3:15 pm Post subject:
interesting....
i think my "problem" is twofold.
1. when i add more modules, you are right the pitch does drop a tiny bit. no big deal. its good to know your psu does this too
BUT
2. when i have my soundlab vco plugged in, but NOT plugged into the speakers, it changes the pitch of other modules on the same psu when its pitch knob is turned...very scary...like a poltergiest.
maybe the problem is just the soundlab vco...i did rip its circuit out of the entire soundlab...i didnt build the whole soundlab, just the vco and i added some bypass caps, but its possible this wasnt really meant to be run as a separate circuit
