What is the best use of SAD512, SAD1024 BBDs
Page 1 of 1 [12 Posts]
psylux
PostPosted: Mon Jul 23, 2007 2:43 pm    Post subject: What is the best use of SAD512, SAD1024 BBDs Reply with quote  Mark this post and the followings unread
It looks like I might end up with a few SAD512, and while my next BBD project will be Jurgen's board, I wonder if there is a design around to best make use of the higher specs these SAD chips are capable of?
stefano
PostPosted: Mon Jul 30, 2007 9:30 am    Post subject: Reply with quote  Mark this post and the followings unread
You can use these chips to implement Chorus, Flangers and Delay based effects. Try to google: Chorus "SAD 1024" .
Bye
Peake
PostPosted: Thu Aug 02, 2007 9:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
IIRC, the 1024 is used in the Electro Harmonix Electric Mistress, the A/DA flanger, and the MXR "117" flanger. All of which sound and behave differently and would each be valid sources for cloning. I see via Google that at least one person already did a limited run clone PCB for the A/DA flanger.
The only circuit I remember offhand as using the 512 was the ARP Omni 2 phaser/flanger board. Not as impressive as the Solina chorus ensemble, IMO.
Good luck, hope that helps.
StephenGiles
PostPosted: Fri Aug 03, 2007 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
There were a couple of 512 circuits in ETI by Tim Orr who knew what he was talking about.
Peake
PostPosted: Fri Aug 03, 2007 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Poking around this board, I see a member ID'd as Moosapotamus. He's the one who created the A/DA clone board I just mentioned. This is worthy of a new run, IMO.
Sorry, I'm way ahead of myself. The Modcan Super Flanger, based upon the A/DA, uses two MN3005 BBD ICs.
StephenGiles
PostPosted: Sat Aug 04, 2007 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I found this today on a German guitar effects forum.
http://www.4shared.com/file/21330824/4fd471e1/Jet_Flanger__Filter_Matrix2.html
moosapotamus
PostPosted: Sat Aug 04, 2007 7:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I thought the interest in that was kind of fading away... haven't had very many inquiries, lately. Awesome sounding flanger circuit, tho. I could certainly start a new thread to see if another run would be worthwhile. Documentation's here...
http://moosapotamus.net/IDEAS/ADAflanger/ADAflanger.html
And FWIW, here's the Bell Flanger which used the 512...
http://www.diystompboxes.com/pedals/Bell_BF20flanger1.gif
http://www.diystompboxes.com/pedals/Bell_BF20flanger2.gif
~ Charlie
moosapotamus.net
"I tend to like anything that I think sounds good"
StephenGiles
PostPosted: Sun Aug 05, 2007 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I must rescan the Bell Flanger, I really messed that one up when I did it. I got that by phoning the company many years ago!
funkyfarm
PostPosted: Sun Aug 05, 2007 2:10 am    Post subject: Reply with quote  Mark this post and the followings unread
~ Charlie
You definitely should !
And maybe wait until late september, when all the folks will be back from the beach.
We shall all stop dreaming on Eventide/Storm Tide Flanger !
I still remember hearing "ADA flanger is the king !" Wink
Small bear starts growling.
http://www.smallbearelec.com/Detail.bok?no=245
Peake
PostPosted: Sun Aug 05, 2007 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
~ Charlie
Hey! If I can get some money together, I'd definitely build a pair (I've a pair of NOS chips from when Midwest was still selling them- I remember when you could get them at Rat Trap). I agree, it's one of the most interesting flangers, IMO (never owned one of the Rolands). Thanks!
cebec
G2 patch files: 31
PostPosted: Sun Aug 05, 2007 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Serge WAD (Wilson Analog Delay) uses a SAD 1024.
funkyfarm
PostPosted: Sat Dec 08, 2007 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Is there any chance to see WAD schematic on-line one day ?
Some patents are still "active" for SERGE designs ?
http://www.serge-fans.com/wiz_audiomod.html
serge-fans.com wrote:
These features provide an amazingly varied palette of effects. Here are some of the possible ways to use this module:
* VC FLANGER
* "GLIDING" FREQUENCY SHIFT effects (the frequency shift effect is never steady, but is a function of envelopes varying the delay rate).
* STRAIGHT DELAY (perceived as fast repeats as in the delay between two tape recorder heads).
* ECHO CHAMBER EFFECTS, where the delayed signal is fed back into the Analog Delay's input. (The switchable AUX input is particularly valuable for this type effect, especially if an external VCA is inserted into the feedback loop, allowing voltage control of the number of echoes as well as their rate of occurrence).
* CHORUS EFFECTS
* VIBRATO EFFECTS
* DELAY AND ECHO OF CONTROL VOLTAGE ENVELOPES (via IN-2). Though the maximum guaranteed delay is .5 second, in practice the delay will go to more than 5 seconds for low frequency signals such as control voltages.
* MODULATION EFFECTS resulting from the modulation of the input signal by the clock internal to the Analog Delay.
** The first question often asked about the Analog Delay is how long a delay can it do? The answer to this question is fairly complex. Quite a long delay can be performed by the module. However, as delay becomes longer, the bandwidth of the signal which can be processed by the Analog Delay becomes more restricted. As an example, if it is desired to delay a signal consisting of a sine wave at 440 Hz (concert "A"), then better than a half second can be gotten quite cleanly. The same note with a lot of harmonics, say a square wave at 440 Hz, if delayed at a half second, will produce a very modulated output(if the Analog Delay's built-in filters are opened wide) full of extraneous signals, or will lose its overtones because the filters will remove them. (This is why many other delay modules have a dulling effect at long delays). The moral to this story is that one function which the Wilson Analog Delay will not do, is to reproduce the full effects of tape delay (i.e. "echo-plexing") without appreciably changing the signal being delayed. But tape delay is a stock effect, usually available to most synthesists (but which can be used with other voltage-controlled functions such as filtering, phasing, frequency shifting, etc., for more sophisticated effects).
The forte of this module is its ability to transform signals and control voltages in an incredible number of ways.
5 seconds delay for my CVs ? hmmm...
