crazeydazey
Posted: Thu May 31, 2007 5:04 am Post subject:
A bit of a rant... Subject description: sorry |
I ordered all my components the other day from this list not really checking what I was buying, just assuming that everything was ok..
Imagine my suprise when my order was delivered and I got 3 lawnmowers, a bag of bird seed, and a pair of incontinence pants..
no just kidding, but I did get a bag of about 600 resistors all 5% ( I know it requires quite a few 1% resistors) - but that's ok I've got plenty of 1% resistors kicking around.. no probs.
a TTL 7416 HEX INV/BUF DRIVER - the SLMS requires a CD40106 Hex Inverter, I'm not sure if they are the same pin layout, but TTLs run at 5v and I was always told not to mix TTL and CMOS (don't know why??)
and a big bag of pots - all linear, I thought it required some linear and some log pots, but I can't find where it tells you on rays page which to use..
I'm not slaggiing the guy who made this list off (Matt Bartlett), probably because he could be a member of this forum, lives in the UK and probably got a roundhouse kick that chuck norris would be proud of, but I'm a little peeved that I have spent a good view quid on parts and may need to spend a bit more..(plus they didn't have any Tantalum Capacitors or the temp co resistors...)
but never mind I'll live.. |
Clack
Joined: Aug 08, 2005 Posts: 438 Location: Walthamstow - london
Posted: Thu May 31, 2007 5:34 am Post subject:
er .. . . . I dont think rapid sells any of those items, I think the problem is the delivery bloke. Ive used those numbers from that list and it was perfectly fine. And you can get the cd40106 from rapid too.
Rapid is a bit funny sometimes though, I had a bag of 100ohm resistors that inside were actually 330ohm and ive received somone elses order before too ( I accidentaly kept it ! ) |
Joined: May 16, 2005 Posts: 8933 Location: Birmingham, England, UK
Posted: Thu May 31, 2007 9:15 am Post subject:
Yes, I used that list too, and only part way through, noticed there were many mistakes. This isn't really Ray's fault because he lives in the States, and Rapid are British. Ray's just more than happy to take 'contributions' such as component lists. I'd email him and send him an updated list- that's if you want to
I ordered (and still do) most of my Soundlab parts from Rapid. The real problem is that the order codes change, so it's best to always recheck them.
So,
I'm afraid, the one who has made the error here is err... yourself. Sorry. FWIW, you can return stuff to Rapid if it's the wrong part. Irritating, but very British
PS, if you look down the page on the mfos site, it does recommend where to use log pots. It is there, you just have to look for it, and yes, there is a heck of a lot of info _________________ ACHTUNG!
crazeydazey
Posted: Fri Jun 01, 2007 1:29 am Post subject:
v-uv-v wrote: | Yes, I used that list too, and only part way through, noticed there were many mistakes. This isn't really Ray's fault because he lives in the States, and Rapid are British. Ray's just more than happy to take 'contributions' such as component lists. I'd email him and send him an updated list- that's if you want to |
I'm not really blaiming anyone other than myself, I know I should have checked, and I think I'll give emailing a new list a miss too, if rapid keep changing there numbers, then there will be another post on here in a year or too saying "that crazeydazey, needs chopping putting the wrong list on rays site.." so I don't think I'll bother..
I don't think I'll send them back, I'm sure they will get used (except the 7416, I don't see TTL used in the circuits I've seen..could be wrong!!)
cheers though for listening to my rant... |
Lemmy
Posted: Sat Jun 02, 2007 2:07 pm Post subject:
Oh
I have the same 7416 waiting to be plugged in. Are you sure it's not going to work? Will I blow anything up if I try it? |
crazeydazey
Posted: Mon Jun 04, 2007 1:15 am Post subject:
lemmy wrote: | I have the same 7416 waiting to be plugged in. Are you sure it's not going to work? Will I blow anything up if I try it? |
I'm not 100% sure (I'm still a newbie myself), but I did electronics at college for 4 years and most of this was digital electronics, and I'm sure TTL chips need 5v and the SLMS runs on 9v (which is good for CMOS)
Also I don't even think the pin layouts are the same???
So I wouldn't unless some one else says it's ok.. (as I say I'm a newbie) |
crazeydazey
Lemmy
Posted: Tue Jun 05, 2007 5:24 am Post subject:
Yup,
I found that too. I managed to find the right part on the Rapid site, I think:
part no. 83-0482 |
Zodiak
Joined: May 20, 2007 Posts: 249 Location: Gillingham, Kent UK
Posted: Mon Jun 11, 2007 8:32 am Post subject:
I had a strange one from rapid last week, half way through typing in the order for my SL the basket suddenly emptied
2 minutes later it all came back, and then it switched to somebody elses order completely!
At this point I went to bed and just gave up.
next day everything was fine and my list was still there so I ordered it and everything seems to have arrived. The only warning I would give though is the 1V/oct trimmers are not on the list and I didn't notice until I started to put it all together... DOH!!!! |
crazeydazey
Posted: Tue Jun 12, 2007 5:08 am Post subject:
Quote: | The only warning I would give though is the 1V/oct trimmers are not on the list and I didn't notice until I started to put it all together... DOH!!!! |
Yeah I fell for that one too, I have since found a better list which also tells you which pots are log and lin at elby-designs |
crazeydazey
Posted: Mon Jul 02, 2007 5:24 am Post subject:
AAAAAAAAAAAAAARRRRRRRRRRRRRRRGGGGGGGGGGHHHHHH!!
why does no one sell 2M and 3M resistors???
Can I use 2M2 and 3M3 instead???
I'm going insane... but apart from that everythings great...
I thought building synths was fun!!! |
crazeydazey
Posted: Tue Jul 03, 2007 6:25 am Post subject:
also why does the PCB have + marks on for C3 which is tantalum, should it be 2uf elec????
boing boing boing.. I'm a little teapot... |
Audio files: 278
Posted: Tue Jul 03, 2007 6:51 am Post subject:
2 M and 3 M are not standard values, people have been asking about this before and the answer always was to just use 2M2 and 3M3.
The tanatalums are polarized and so a + sign needs to be on the PCB, it's not always easy to find the mark on the capacitor itself, but there always is some sign or another, maybe post a picture of it ... _________________ Jan
crazeydazey
Posted: Tue Jul 03, 2007 8:16 am Post subject:
Quote: | 2 M and 3 M are not standard values, people have been asking about this before and the answer always was to just use 2M2 and 3M3.
aah right.. sorry I should read some of the old posts first before ranting on.. I'm just idle...
cheers for the advice I will look at the cap tonight before soldering it in, I'm sure i'll see it if I open my eyes..
Again Cheers... |
Zodiak
Posted: Sun Dec 30, 2007 8:30 pm Post subject:
Blue Hell wrote: | 2 M and 3 M are not standard values, people have been asking about this before and the answer always was to just use 2M2 and 3M3. |
I didn't actually use them For example in the noise circuit I didn't want to use up all my 1M and had a pile of 820K so I used them instead, I also swapped the 4.7M for another 820K and the 1K to 1 220R. It works just fine just draws more current, but as I use a PSU instead of batteries thats not really an issue for me.
I can't find my notes for the 3M and 2M but I think they are just a potential divider and I ended up using 680K and 390K or something similar and again it works just fine. It might change the envelope repeat time slightly and draw more current, but in practice I don't notice any difference and I have all my resistors down snug to the PCB which will be handy next year as I plan to use my new one for live work.
OK so it will probably be two of them with an additional ADSR, MIDI interface, delay unit and mixer but the basic circuit will remain untouched |
