cappy2112
Joined: Dec 24, 2004 Posts: 2086 Location: San Jose, California
Posted: Tue Dec 25, 2007 6:59 pm Post subject:
G2ools GUI beta 0.1, for Windows |
Hello Everyone and Merry Christmas!
I know I'm late getting this out, but at least it's out. My apologies.
Attached is the GUI for the G2ools converters, for Windows.
Depending on the feedback and bugs, I will also put together a version
for the MAC. I'm Windows developer by profession, so working on the MAC is mostly uncharted territory for me.
There is a readme file inside of the zip, and hopefully it is clear enough.
If not, let me know.
You MUST have the G2ools already installed (and working).
You do NOT need to have Python installed to use this on Windows.
The GUI is not a new version of the G2ools converter, it's just a user interface.
This has only been tested on Windows XP, SP2, so if you are using any other version of Windows and have problems, let me know.
Known problems with beta 0.1
1, If you select the NM2g2 converter and use a directory without patches or with DX7 patches, the GUI calls the converter, but never returns.
2. When using the DX converter there is a long lag from when you start the converter until you see the converted patches in the list box.
| Description: |
 Download |
| Filename: |
G2oolsGUI.zip |
| Filesize: |
6.25 MB |
| Downloaded: |
452 Time(s) |
gomidas
Joined: Jul 09, 2004 Posts: 358 Location: La Ciotat, France
G2 patch files: 6
Posted: Wed Dec 26, 2007 4:37 pm Post subject:
It's never too late...
Thank you very much for this, greaT JOB CAPPY2112, you work ten times faster than clavia do for their os...  |
cappy2112
Posted: Wed Dec 26, 2007 7:16 pm Post subject:
| gomidas wrote: | It's never too late...
You're welcome. I assume. It's working ok for you. There are still a few problems to fix, but I was able to convert about 10 subdirectories full of patches (about 100 patches or so, total), without any problems.
I know it's got a crude look & feel, but that can be improved over time.
I wouldn't say I'm ten times faster than Clavia, considering I started on this project about 9 months ago- then stopped  |
Tom_1970
Joined: Jan 14, 2007 Posts: 18 Location: The Netherlands
Posted: Thu Jan 03, 2008 7:20 am Post subject:
Great enhancement!!!
It works great on the patches I converted.
The only 'problem' is the display in some of the boxes in the interface, but that's hardly a problem for me.
I haven't done any DX conversions yet, but I will try later this day.
Great job. Thanks cappy2112.
Regards
Tom |
cappy2112
Posted: Thu Jan 03, 2008 8:19 am Post subject:
| Tom_1970 wrote: | Great enhancement!!!
Regards
Tom |
Thanks. Would you elaborate on what you mean by "the display in some of the boxes"? _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
dxmat
G2 patch files: 8
cappy2112
Posted: Thu Jan 03, 2008 11:08 pm Post subject:
| dxmat wrote: | | Work great, some box-display problem.[/img] |
Thanks.
Are you referring to the box in the upper right that's grayed out (the one labeled TBD) ?
That's intentional. That's there as a reminder for me. TBD means To Be Done (not Tony's Been drinking)
I may be adding something there in the next release. _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
dxmat
G2 patch files: 8
Posted: Sat Jan 05, 2008 3:04 am Post subject:
| Quote: | | Are you referring to the box in the upper right that's grayed out (the one labeled TBD) ? |
No.
See new uploaded screen on my previous post. |
cappy2112
Posted: Sun Jan 06, 2008 2:24 pm Post subject:
| dxmat wrote: | | Quote: | | Are you referring to the box in the upper right that's grayed out (the one labeled TBD) ? |
No.
Thanks. This is the kind of feedback I need.
Does anyone else see these graphics oddities on their systems?
Oddly enough, I don't see these issues on my system, but I have a few custom setting under Visual Effects in control panel turned on. Most are disabled to help maxmise performance. These settings sometimes affect how graphics appear, and is controlled by the OS.
For example- all of the square boxes in the GUI, have rounded corners on my system. This is something that is definitely controlled by the Visual Effects settings in Ctrl Panel
I will see if there's something I can do to make these issues appear on my system _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
Tom_1970
Posted: Mon Jan 07, 2008 3:55 am Post subject:
I wasn't able to react earlier, but dxmat describes the issue I mentioned in my post.
It's jus a minor thing to me, because ist works perfect when it comes to the actual conversion of patches.
Regards
Tom |
cappy2112
Posted: Mon Jan 07, 2008 5:18 pm Post subject:
| Tom_1970 wrote: | I wasn't able to react earlier, but dxmat describes the issue I mentioned in my post.
Regards
Tom |
Thanks for the feedback.
When you run it on your system, do the group boxes have square corners or rounded corners? _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
Tom_1970
Posted: Tue Jan 08, 2008 3:39 am Post subject:
| Square |
cappy2112
Tom_1970
Posted: Wed Jan 09, 2008 4:25 am Post subject:
Hi Cappy,
It already was enabled on my system.
I disabled it....no change
I enabled it again....still no change.
I guess I am not to helpfull  |
cappy2112
Posted: Wed Jan 09, 2008 2:40 pm Post subject:
| Tom_1970 wrote: | Hi Cappy,
You've told me what I needed to know, so that is helpful.
Are you running XP or Vista? _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
Tom_1970
Posted: Thu Jan 10, 2008 1:30 am Post subject:
I am runnig Windows XP (SP 2).
I will give it a try on my studio laptop. If it behaves different I let you know.
Regards
Tom |
eposk
Joined: Apr 29, 2005 Posts: 155 Location: Portland, OR
Posted: Fri Jan 11, 2008 2:50 pm Post subject:
| Thank you!!!!!!!!!!!!!!!!!!!!!! yes! |
aMUSEd
cappy2112
Posted: Mon Aug 27, 2012 12:03 pm Post subject:
| aMUSEd wrote: | | Could really do with a Mac version of this or something like it. |
Check your PM.
I think the website isn't users notifying of PMs again.
There are PMs in my sentbox from over a year ago _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
