  bingsatellites Mostly Ambient
Synthesizing (Open) hihats
Page 1 of 1 [11 Posts]
mother misty
G2 patch files: 130
PostPosted: Wed Dec 12, 2007 7:11 am    Post subject: Synthesizing (Open) hihats
Subject description: tips, tricks? Share them here!
Hi all,
I'm building a new drumpatch but I would like to use a different approach
for the open hihats. I mostly use some kind of filtered noise to make them but
I'm not satisfied with the results. It just sounds like... filtered noise Smile
I've searched the archives but I could only find Sheridan's "hihat machine"
which is great but rather DSP-expensive and hard to implement in a patch.
Is there anyone who has got some hihats tips/tricks/examples?
I would appreciate it if you could share them here.
misty.
PostPosted: Wed Dec 12, 2007 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Gordon Reid has something: http://www.soundonsound.com/sos/aug02/articles/synthsecrets0802.asp
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Dec 12, 2007 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I mostly I use the NordLead2 HiHat in an Open/Close configuration. Closed is created by holding the key and Open is done by a quick release on the key.
I post a picture of the settings.
As you see, there is no LFO, just the ModEnv A=0, D=14 and A=104, set to the FM.
There is no Noise used, just FM 'noise' done by a Pulse wave to the Triangle wave at Osc1. The Modulator is two octaves higher then the Carrier. Modulator has NO keyboard tracking.
Use a mixer to the FM fed by the ModEnv and Osc2.
The Open/Close trick is done by a zero Sustain.
The Filter is of course the 24 dB NordFilter
In the sound example the second sound is two keys together, which gives a nice detuned HiHat.
The SysEx file is the NordLead2 file.
Wout
 Filesize:  125.05 KB
 Viewed:  5383 Time(s)
NordLeadHiHat.wav
 Filename:  NordLeadHiHat.wav
 Filesize:  1.37 MB
 Downloaded:  399 Time(s)
P003Hi-Hat00.syx
 Filename:  P003Hi-Hat00.syx
 Filesize:  139 Bytes
 Downloaded:  166 Time(s)
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Dec 13, 2007 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
a. use a sample-rate/bit reducer module and set it to 11kHz and 8 bit. that gives you some nice character.
b. an eq module could also help here (sweepable).
c. also apply a shaper which is modulated with a decay env.
do this before your amp env tho Wink
Let me know if this helps.
/Dasz
http://www.clavia.se/misc/users/daszgarncarz.htm
http://haagenlive.blogspot.com/
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Dec 13, 2007 2:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have you been here already?
http://nm-archives.electro-music.com/010_NordModular/015_Workshops/Rhythm/DanceTechno-Dr&Bass.html
Wout
G2 patch files: 584
PostPosted: Fri Dec 14, 2007 3:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I find it tempting to always use the metallic noise oscillator. But a 'roll your own' can have a different character so it is nice for a change.
The 808 style six squares + HPF (18-30dB) is a good starting point, you can use square wave LFO's to lower dsp load.
Clipping enhances the 'metallic-ness', boost the level x 4 after the HPF then run through a clipper with clip level at 0. Maybe add another HPF after the clipper.
A feed forward comb filter is good for fine tuning the tone. See attached patch.
The attached patch is a version of the shimmer section of the cynare circuit. Variation 4 is open hihat-ish, 3 is a reversed cymbal, the rest are China type or gong like sounds.
shimmer.pch2
diy metal noise
 Filename:  shimmer.pch2
 Filesize:  1.86 KB
 Downloaded:  822 Time(s)
mother misty
G2 patch files: 130
PostPosted: Sun Dec 16, 2007 6:35 am    Post subject: Reply with quote  Mark this post and the followings unread
One of the reasons I never really bothered with six pulses + HPF is because it uses alot of DSP-power.
You need 6 shape oscs and shape osc's are DSP expensive. But I discovered that's not the case when you select the pulse waveform.
Infact it uses only 2.7% whiile a LFO uses 4.7%!
A LFO could probably use less, but there's no dedicated LfoShpB module Sad
I like the flavour of your hihat btw g2ian!
To the others: thanks for the tips!
I've you have more tips/tricks, let them come!
misty.
G2 patch files: 584
PostPosted: Sun Dec 16, 2007 5:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Misty
The 808 uses six cmos Schmitt trigger oscillators which produce 50:50 square waves. Using pulse waves does give some interesting variations though.
The first two oscillators in the 808 hat have trimmers to set the frequency precisely. This is because they double duty as the source for the cowbell. The schematic shows calibration values of 1.85ms and 1.25ms which is 540Hz and 800Hz.
Anyways, got inspired by a Korg KR55 OH sample, which showed some randomly spaced but fixed width sections chopped out of the wave. Here is a version which uses one of three square LFO waves through a rndTrig/inverter module to amplitude modulate the combined waves.
The rest is standard except the comb filter and ShpStatic to fatten up the envelope shape. That's 'fat' as in the opposite of 'skinny' BTW.
KRHat.pch2
 Filename:  KRHat.pch2
 Filesize:  1.48 KB
 Downloaded:  734 Time(s)
G2 patch files: 584
PostPosted: Mon Jan 07, 2008 11:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just did the Boss DR110 hats here
mother misty
G2 patch files: 130
PostPosted: Tue Jan 08, 2008 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks G2ian!
One more question I'm afraid Smile
Is there's some kind of logic for the oscillators frequency or do you just tune them untill they sound good?
misty
G2 patch files: 584
PostPosted: Tue Jan 08, 2008 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
The CR8000 and DR110 service manuals show the frequencies (or periods in ms) for each of the 6 or 4 oscillators.
The DR110 manual claims that the frequencies are chosen from analysis of real cymbal. The CR8000 manual simply says "frequency ratios between adjacent two; should be in 1.1 - 1.4 steps. Note that two oscillators generating on too close frequency will sound beating cymbal"
JuneSolstice2013
