How about a Glossary ??
Page 2 of 2 [48 Posts]
Goto page: Previous 1, 2
Danno Gee Ray
PostPosted: Fri Jan 11, 2008 6:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks good to me...IE6 WinXP
richardc64
Audio files: 25
PostPosted: Sat Jan 12, 2008 5:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks great, in IE6 and Opera9.2.
Could it be implemented for other areas of electro-music, like the Quick References, etc?
"It's quite OK to make music with tea spoons and rubber bands!" -- Blue Hell
Audio files: 116
G2 patch files: 317
PostPosted: Sat Jan 12, 2008 5:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you, and all others who responded.
Other areas, could be a good idea! But for now it's going to be just a hack for this, to see how it works out, it needs some more hours of work Very Happy
Audio files: 22
PostPosted: Sat Jan 12, 2008 7:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Jan,
It works great here. I am at my PC at work right now.
PC with Win XP Prof.
Explorer 7
Very nice !!!!!!!!!!!
I will check it at home on my laptop and report !
You da' man !!!!!!!!
Bill
Audio files: 116
G2 patch files: 317
PostPosted: Sat Jan 12, 2008 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
The editor could work now as well ...
The file scanner is a bit primitive, so be sure to read the remarks at the bottom of the editor screen. There should be backups when the file gets screwed up somehow ... I hope Laughing
It's probably best to copy the text out of the editor screen into a real editor, do the work there and then past it back into the browser and hit submit. When you see errors after you submitted you can use the back function of your browser to go to the editor again for as long as the session will last.
An edit session can take a maximum of three hours now, after that the session id will be invalidated.
Scroll to the bottom of the glossary as present in this thread and click "log in", good luck on the captcha, it's not the average one Wink
Audio files: 116
G2 patch files: 317
PostPosted: Sat Jan 12, 2008 9:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I improved a bit on the link control ... hey peeps you can actually edit this yourselves Very Happy
richardc64
Audio files: 25
PostPosted: Sun Jan 13, 2008 2:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Very cool! I changed the entry for HDL, which had said "High level description language" to "Hardware Description Language." Took me awhile to realize that "(read more...)" is added automatically when a link is included.
Well done.
Audio files: 116
G2 patch files: 317
PostPosted: Sun Jan 13, 2008 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I added some new comments to the editor "manual" trying to point this out, thanks!
I'm changing the code a bit now to make things a bit more general (and maybe suitable for more than one glossary).
JovianPyx
Audio files: 123
PostPosted: Sun Jan 13, 2008 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Just a note about the LUT entry, while the acronym refers directly to the term Look Up Table, from a conversation in another FPGA forum, I learned that LUT refers specifically to specialized high speed logic that perfoms look up table functions, but it is really a single bit slice RAM. As a RAM, the LUT structure can actually implement RAM when that is applicable. In other words, a look up table, such as a sine look up table is not technically the same as an LUT. When someone says "LUT" to me, I think of the FPGA specific structure, when someone says "look up table", I think of the more general definition. Within a Xilinx FPGA (and possibly others), "distributed RAM" (as opposed to Block RAM) is implemented on LUTs for efficiency and because it is capable of asynchronous reads. LUTs are also used to generate complex logic functions which have 4 inputs and one output (for a 16 state LUT)
And here's more...
- CLB
(Xilinx only?) Configurable Logic Block, part of FPGA internal structure, Xilinx CLBs include 2 "slices".
- Slice
(Xinlinx only?) A slice is a collection of logic that is one bit wide. The slice is configurable and can perform many different functions.
- Distributed RAM
(Xilinx only), these are small logic device internal RAMs, usually implemented on LUTs. Can be configured as dual port RAM.
- Block RAM
(Xilinx only?) possibly others, larger sized logic device internal RAMs (synchronous read), configurable. Dual ported by design.
- Routing
The process of configuring connections between logic elements. Routing is important because it can affect timing due to the distances signals are required to travel.
Audio files: 22
PostPosted: Sun Jan 13, 2008 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Routing
To go along with this :
PAR - Place and Route
Yes, a very general term that could be synonymous with many things .... depending on it's context. Sort of like the term BUFFER .... does it mean you are referring to a place in memory where things are stored or is it a non-inverting amplifier???
Which is really nothing more than RAM organized as a 16 x 1 scratch pad .... It's still a LUT or a LOOK UP TABLE ... just a very small one as opposed to a "sine" lookup ...
Bill
JovianPyx
Audio files: 123
PostPosted: Sun Jan 13, 2008 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Bill
It's interesting how names of things morph depending on their use, the LUT is called simply a LUT when it's used as a complex logic function generator (in which case it is considered a ROM because the write line is not available to the design) or when referring to the internal primitive silicon construct, but when used as RAM, it's called "Distributed RAM". For me, until I had pored over some log files, this was a tad confusing. The Idea came on when I was "warned" that my distributed RAMs were implemented on LUTs due to declaring an asynchronous read (this is not a bad thing, so I don't really understand why it's called a "warning"). As distributed RAM, it can be used as an updatable LUT (if that's what you need) by implication, but it's never called that, it's called "distributed RAM", probably for clarity in human communications. In the latter case, I believe it's properly referred to as a "look up table" (not a LUT) even though it's still implemented on a LUT... Shocked Very obscure lexical minutia, but I think the distinction is important for us here.
JovianPyx
Audio files: 123
PostPosted: Sun Jan 13, 2008 1:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also, I think we should include DCA, DCF, DCO and DCLFO as synonyms for NCA, NCF, NCO and NCLFO respectively.
Audio files: 22
PostPosted: Sun Jan 13, 2008 7:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very interesting topic. Here is a excerpt an architectural description of the Spartan II FPGA which supports this statement:
From Xilinx Website:
Spartan-II function generators are implemented as 4-input look-up tables (LUTs). In addition to operating as a function generator, each LUT can provide a 16 x 1-bit synchronous RAM. The Spartan-II LUT can also provide a 16-bit shift register that is ideal for capturing high-speed or burst-mode data. This mode can also be used to store data in applications such as digital signal processing. The storage elements in the Spartan-II slice can be configured either as edge-triggered D-type flip-flops or as level-sensitive latches.
The block diagram is shown below this post.
So in the most generic of definitions:
LUT - Look Up Table - A fast memory by which a group of input signals, representing (x), may randomly index it's array, representing f(x), thus producing the transfer function of (x).
In computing, LUT's are used in place of computation of a trigonometric function because of of the very fact that the values are already pre-calculated for you so the table is just simply indexed and read. The trade off is more silicon is required. This is why a "Wavetable" synthesizer can have so many voices play at once, the functions are not calculated but simply are looked up. Much faster !!
So in the case of the "sine LUT", the inputs represent (x) or degrees expressed in radians so for a 256 entry table, it can be indexed in (Pi/256) radians. The sine amplitude is thus calculated via a fast LUT.
This may help settle on what definition we may give LUT ........ Very Happy Very Happy
Bill
 Filesize:  18.11 KB
 Viewed:  8394 Time(s)
Audio files: 22
PostPosted: Sun Jan 13, 2008 7:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
DCO, NCO
Also called DDS, Direct Digital Synthesis .......... Oh so may synonyms !!!
Shocked Shocked Shocked
Bill
Audio files: 116
G2 patch files: 317
PostPosted: Mon Jan 14, 2008 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
See : http://www.xs4all.nl/~ganswijk/chipdir/abbrev.htm#mips Shocked
Audio files: 22
PostPosted: Tue Jan 15, 2008 6:09 am    Post subject: Reply with quote  Mark this post and the followings unread
jan,
That format is really nice !!!!!!!!!!!
Bill
JovianPyx
Audio files: 123
PostPosted: Tue Jan 15, 2008 6:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Interesting, they don't have a definition.
We have the IP company as the only definition. While that's true, what about "million instructions per second"? When I worked for DEC, that rating acronym was always spelled MIPS. I don't think mips is correct, in metrics, lower case denotes diminuitive, such as mHz vs MHz, the first is millihertz where the second is megahertz.
Is there an authoritative reference?
Audio files: 116
G2 patch files: 317
PostPosted: Sun Feb 10, 2008 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
As no one takes up on this and the glossary has hardly been edited I think the experiment can be considered to have failed?
seraph
Editor
Editor
Audio files: 31
PostPosted: Sun Feb 10, 2008 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
maybe people around here is so knowledgeable they don't need it Wink
Audio files: 22
PostPosted: Sun Feb 10, 2008 5:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wink I like that !!!!!! Very Happy
Bill
Tony Deff
PostPosted: Wed May 06, 2009 11:40 am    Post subject: A Glossy what? Reply with quote  Mark this post and the followings unread
Or we could post a PDF table here.
Same basic problem, someone would have to keep updating it (and sooner or later that will stop happening). Also, the temporary suggestions list would have to be deleted by the Moderator after it had been incorporated into the table.
TLA = Three-Letter Acronym
Audio files: 116
G2 patch files: 317
PostPosted: Wed May 06, 2009 11:45 am    Post subject: Re: A Glossy what? Reply with quote  Mark this post and the followings unread
That' s why I made the thingie I posted above editable ...
seraph
Editor
Editor
Audio files: 31
PostPosted: Wed May 06, 2009 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bill
Bill, did you know you are "A formal abstraction for describing the workings of some process or machinery." Question
Niio1
