Dr. Spankenstein
Posted: Fri Jan 18, 2008 6:00 am Post subject:
Is this a sensible way to write a menu in ChucK? |
| Code: |
KBHit CutterMenu;
int Char;
int MenuState;
menu();
fun void menu()
<<<"Welcome to Rhys' Menu">>>;
<<<"Select which number you like:">>>;
<<<"[1]">>>;
<<<"[2]">>>;
while (MenuState != 2)
CutterMenu => now;
appendChar(CutterMenu.getchar());
me.exit(); // Is this sensible having this here or will it reach the end of the function and stop automatically when MenuState == 2?
fun void appendChar(int Char)
if (MenuState == 0)
//<<<Char>>>;
if (Char == 49)
<<<"You have chosen 1">>>;
<<<"Would you like to choose yes or no?">>>;
<<<"[Y] or [N]?">>>;
1 => MenuState;
if (Char == 50)
<<<"You have chosen 2">>>;
2 => MenuState;
programme();
if (MenuState == 1)
if (Char == 121)
<<<"YES">>>;
2 => MenuState;
programme();
if (Char== 110)
<<<"NO">>>;
2 => MenuState;
programme();
fun void programme()
<<<"Programme Running">>>;
10::minute => now;
Also, how do I get rid of those ": (string)" lines that get printed along with the strings? The only way I know of at the moment is to include an integer or other non string!
Thanks,
Rhys |
Frostburn
Posted: Fri Jan 18, 2008 6:23 am Post subject:
You can get rid of the :string lines by breaking the string into two or more pieces.
| Code: |
<<<"I have something on me.">>>;
<<<"We","do","not!">>>;
//output:
//"I have something on me." : (string)
//We do not!
_________________ To boldly go where no man has bothered to go before. |
Joined: Jul 06, 2004 Posts: 6247 Location: The Hague, NL
Posted: Fri Jan 18, 2008 6:41 am Post subject:
<<<"yes, or like this", "">>>; _________________ while(!machine.crash() ) <<<"all is well">>>; |
Dr. Spankenstein
Posted: Fri Jan 18, 2008 7:03 am Post subject:
Thanks guys!
Rhys |
Dr. Spankenstein
Posted: Fri Jan 18, 2008 9:54 am Post subject:
OK menu is almost done but......
How do I store an int from more than one character from the keyboard?
So for example the prompt would say:
"Enter an number?"
ChucK then waits for the enter button to be pressed, reads the ascii code and converts it into an integer which it can then store as a variable?
| Code: |
if (ASCII == 13)
User_Entered_Data => int StoredInt;
This is usually pretty basic stuff with programming languages but I cant find anything in the examples, or am I not looking hard enough?
Thanks,
Rhys |
Posted: Fri Jan 18, 2008 12:05 pm Post subject:
Here you go;
| Quote: |
ConsoleInput: interim console input (until file I/O)
(use to be hidden Skot object)
see examples/string/readline.ck |
:¬) _________________ while(!machine.crash() ) <<<"all is well">>>; |
Dr. Spankenstein
Posted: Fri Jan 18, 2008 12:18 pm Post subject:
EDIT: There doesnt seem to be a parse int type of thing to convert the string token into an integer? An explicit cast doesnt work either  |
spencer
Joined: Aug 16, 2006 Posts: 52 Location: northern california
Dr. Spankenstein
Posted: Tue Jan 22, 2008 3:43 am Post subject:
Yes I beleive that should do it.
I should have really have seen that myself but lately I've not been seeing the wood for the trees thanks to many a late ChucKing night working on this project.
Thanks Spencer,
Rhys |
