 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
Happy New Year!
Thanks for a great live streaming floating concert and party.
How do I refresh a shred, keeping a value without crashing?
Dr. Spankenstein
PostPosted: Mon Jan 21, 2008 5:33 am    Post subject: How do I refresh a shred, keeping a value without crashing? Reply with quote  Mark this post and the followings unread
I've simplified the process as much as I can to demonstrate what I'm aiming for.
The idea is that I have to refresh a shred every so often as to avoid garbage errors.
Whilst this method works fine, it no longer works when I try to introduce a function that gets the last known value of a variable when the shred is refreshed (e.g. machine.removed then sporked)
Class.txt
Code:
public class Hello
   static int ValueRefresh;
   public static int setValueRefresh(int input)
      input => ValueRefresh;
   public static int getValueRefresh()
      return ValueRefresh;
Hello hello;
Machine.add( "Refresh.txt" ) => int refresh;
while(true)
   10::minute => now;
Refresh.txt
Code:
Hello hello;
hello.getValueRefresh() => int x;
x + 10 => int y;
spork ~ refreshing() @=> Shred @ refreshingDestroy;
printx();
fun void printx()
   while(x < y)
      <<<x>>>;
      1::second => now;
   Machine.add( "refresh.txt" ) => int refresh;
   me.exit();
fun void refreshing()
   while(true)
      x++;
      hello.setValueRefresh(x);
      0.1::second => now;
This method will always crash ChucK and I'm not sure how to prevent that other than syncing the two times together (e.g. both printx() and refreshing() use 1::second => now)?! This isnt ideal.
Any ideas anyone?
Thanks,
Rhys
PS. On a side note, how can I parse a string as an integer. In other words cast a string "23" to an integer of value 23?
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
