 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
Controlling ChucK using 2 seperate MIDI devices (gomidi2.ck)
Dr. Spankenstein
PostPosted: Tue Jan 22, 2008 12:50 pm    Post subject: Controlling ChucK using 2 seperate MIDI devices (gomidi2.ck) Reply with quote  Mark this post and the followings unread
Having played around with the MIDI code in the examples and incorporating it into my code I have since found that I cannot control two separate Ugens at the same time using two different midi sources.
ChucK will currently only allow one MIDI controller to work at any one time.
During a period of receiving data from one controller, any data received from a second MIDI controller, catches up, and is fed through very quickly after a period of inactivity on the first MIDI controller.
I have tried using separate sporks for each MIDI controller and using the gomidi2.ck code but alas there is no way I can have the two lots of data from two separate sources at the same time.
Can anyone suggest why this is and maybe a means of overcoming it?
Thanks,
Rhys
Top Selling Products! CLICK HERE!
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
