Joined: Apr 03, 2004 Posts: 24081 Location: The Netherlands, Enschede
Audio files: 278
Posted: Sat Dec 08, 2007 8:38 am Post subject:
Dave Kendall wrote: | Maybe this one? |
Think so, thanks _________________ Jan
gavgomad
Posted: Sat Dec 08, 2007 9:12 am Post subject:
Beat me to it! ;-P
I'm already working on some other MB projects.... Seems like an excellent bridge for control over analog circuits - switching, mixers, control surfaces....
The "FFF", a good VCO poly (OB-8 in my case), and a switcher like this, you can have something better than a Polymoog, VP-330, Lambda etc. all combined and switchable by midi!
Gav. |
gavgomad
Posted: Sun Dec 23, 2007 5:30 am Post subject:
As my parts stock is low at the moment so I can't really build my Triple Chorus or my other projects, and as I'm trying NOT to think of work over my holidays.... ;-P
I've been turning my mind to the planning stages on some things, and this idea keeps coming up.... Overall, it would be nice to have a few solid string and vocal filters, that way you could feed them with a good poly and mix and match them.
Depending on how "doable" it would be, these would be my faves....
Strings:
Polymoog Vox Humana / Strings 1 / Strings 2
Roland VP-330 Strings (Upper/Lower)
Korg Lambda Strings 1 / Strings 2
Vocal/Choir:
Roland VP-330 (4 settings)
Polychrome Vocal Chorus (1/2/3 - not sure if these are separate filters?)
Korg Lambda Chorus
From the schems that I've seen (feel free to correct me if I'm wrong.... I've only eyed the VP-330 and Lambda) most of the filters that have variable attack/release controls simply use them for a volume VCA before the fixed filter? If so, the poly can do all of that work....
Coupled with JH's Triple Chorus, Schulte, and a stereo chorus, any decent analog poly could be a pad monster with these filters!
Just for interest, does anyone have the Polymoog Keyboard preset/filter schems and/or the Polychrome filter schems? Would be interesting to have a gander at them....
Gav. |
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Wed Jan 23, 2008 5:38 am Post subject:
A module with some simple anti aliasing filters like in the linndrum em sp1200 would be cool to. |
Undergrind
Joined: Jan 19, 2008 Posts: 32 Location: Berlin by night
Posted: Mon Jan 28, 2008 3:24 pm Post subject:
maybe a more modular one like a selection of eight small filters out of 4 different types. All with small pcbs and front. These are internally connected to a
FF <-- Filter Fixer
having an audioinput that will be sent internally to all "slave" filters. And a audiooutput which sums all the signals of the slavefilters with a poti recieven internally. This module locks (fixes) the initial frequencies of the slaved filters by sending a set of fixed (programmable?) cvs to the slavefilters. Or with a cv-controlable interval between the 8 bands.
the seperate audioinputs of the slavefilters disconnect the internal wiring. the cv freq input summs the incoming cv with the cv provided by "FilterFixer"
what do you think? or did I absolutely miss the point? _________________ www.myspace.com/undergrinder |
Electronicant
Posted: Mon Jan 28, 2008 6:37 pm Post subject:
Vocal |
The Rhodes Chroma, has really great vocal sounds. Last edited by Electronicant on Tue Aug 12, 2008 4:57 pm; edited 1 time in total |
ENDIF
Ricko
Joined: Dec 25, 2007 Posts: 251 Location: Sydney, Australia
Audio files: 27
gavgomad
Posted: Sun Feb 10, 2008 2:37 pm Post subject:
Just a couple quick Q's for anyone who may have sifted through this before....
I have been reviewing the notes from the Polymoog Keyboard, and the Vox Humana filter is a bit confusing (to my puny brain anyway! ;-P) It appears that there is a separate board altogether for the Vox Humana filters (at least for the lowpass portions), but there is reference to still another set of highpass filters associated with the Vox Humana preset on Board #1?
Is the Vox Humana "Board" the whole fixed bank, or not?
As another aside, has anyone gone any further in analyzing the Polychrome Vocal Chorus circuit? I've never encountered a Polychrome in person, and as all I have to go on is the PDF'd "spec sheet", I can't figure out if it is really a "fixed" filter, or whether there is something far more complex at work....
Gav. |
jhaible
Posted: Fri Jun 06, 2008 11:55 am Post subject:
Here's a short demo of the section that emulates the VP330 Vocoder Plus "male 8" voice.
Input signal is a single-oscillator sound with slight PWM be envelope and triangle wave vibrato from the PolyKorg Clone.
TC D-Two echo added, as well as a little bit of Quantec.
Starts with dry sound, switches to Male 8 Voice filter and back.
JH.
Description: |
Download |
Filename: |
jh_fff_vp330male8voice.mp3 |
Filesize: |
481.36 KB |
Downloaded: |
1163 Time(s) |
_________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
Electronicant
Posted: Mon Jun 30, 2008 2:20 pm Post subject:
Is it decided which filter it´s going to be in this module?
The Yamaha GX1/MOTM-485 VCF is nice too ofcourse. Adds a bit of distorsion. |
mono-poly
Posted: Mon Jun 30, 2008 2:54 pm Post subject:
I think the gx1 vcf is voltage controled so not fixed.
JH did you try that polychrome choir filter yet? |
mono-poly
Posted: Mon Jun 30, 2008 3:00 pm Post subject:
Jurgen honestly something like the buchla 194,195 would be cool. |
jhaible
Posted: Mon Jun 30, 2008 3:19 pm Post subject:
mono-poly wrote: | Jurgen honestly something like the buchla 194,195 would be cool. |
I'll have to look at these ... remind me should I forget.
JH. _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
gavgomad
Posted: Fri Jul 11, 2008 9:13 am Post subject:
Amazing demo on the Male 8' Filter, JH!
Is the plan to include all 4 settings of the VP-330 filter on board? If so, is there any benefit to having separate 4' and 8' inputs to the filters?
As well, I have to echo mono-poly.... although I know we're not looking for a "vocal" filter module here, the vocal filter from the Polychrome would be a spectacular addition!
Gav. |
jhaible
Posted: Fri Jul 11, 2008 12:24 pm Post subject:
gavgomad wrote: |
The 3 male settings are all slightly different, the female setting obviously a lot different, but IMO it's that Male 8 I've demo'ed that stands out. I'm not overly fond of the female setting.
norman phay
Joined: Jun 29, 2007 Posts: 176 Location: North-East England
Posted: Sat Jul 12, 2008 10:01 am Post subject:
That little demo clip sounds like the business, Jurgen. Looking forward to this one, for sure. The Novachord filters could be a good addition to this, if you're still looking for suggestions. This is the piece you suggest combining with the string filter at some point, I believe?
On the off-chance that Rick Jellife from upthread is still looking at this, can I just say that I really dig that "ricko-juicer" VST plug that you wrote, and that I also like the CS80r and the SH3-a-like VST instruments as well? Thanks for writing them and seeing fit to share your work with people. I did create a few presets for the CS80r, not a full bank of them to send to you yet though. |
Electronicant
Posted: Thu Aug 28, 2008 1:11 am Post subject:
Don´t forget the Logan Vocalist and it´s larger brother Vocal Synth. An eerie choir sound.
The human voice presets on Teisco EX-300 and SX-400 is said to be very nice too.
Yamaha SS-30 is another suggestion for strings. |
Ricko
Audio files: 27
Posted: Fri Aug 29, 2008 1:23 pm Post subject:
Subject description: [off-topic] |
Oh, thanks for that: people say I got the CS-60 ring modulator better than the commercial emulator. SynthEdit and simple DSP is so easy compared to hardware! In hardwara, the construction details are so much of the job. I really admire JH, Ian Fritz and so on, the ones who absolutely are masters of the analog game and then creative.
Rick Jelliffe |
julianw
Posted: Fri Aug 29, 2008 4:40 pm Post subject:
mono-poly wrote: | A module with some simple anti aliasing filters like in the linndrum em sp1200 would be cool to. |
+1
A vintage 'gritty' A/D>D/A Module ala SP1200/MPC60 (12bit) could be really useful (esp for drums), maybe there is some way of integrating into the Deltalab VC Delay project...
BTW Love the VP330 demo. |
phdinfunk
Posted: Sat Sep 06, 2008 11:54 am Post subject:
Another important fixed filter. Subject description: ... |
I would TOTALLY be in for the module you're describing. I've developed more and more of a taste for fixed filters.
One request: The Moog String Filter... God I forget what it's called, maybe someone knows. It was designed as a standalone box to pass sounds through and apply the formants of a violin to it.
My other request, definately the manual set and forget filter from Roland's SH-7 (or was it the SH-9?)
Moog's Vox Humana filter is a classic.... I like vocal filters, if you put more than one in there it would not go to waste.
Man oh man, I can't wait to build this. I think it will rock a lot. |
/mr
Joined: Aug 05, 2007 Posts: 223 Location: Elektron City, Sweden
Posted: Fri Oct 24, 2008 5:31 am Post subject:
I found this interesting thread today. I'm not sure if the project has been put on ice or if it's still alive, but... although I don't have any better fixed filter suggestions than the above mentioned, I would be very interested in buying an FFF PCB or two if it becomes reality!
The project is a good idea, since fixed filters can give an "acoustic" or "physical" quality to the often "too clinical" electronic sounds. Fixed filters are underrated devices, too rarely seen/heard. I have a equalizer-like Doepfer FFB that is remarkably useful, and I've always wanted more fixed filter units of different kinds.
Go for it!
A side note:
A couple of you have suggested mixing different filter outputs in the postings above. Since phase differences will cause frequencies to interfere both constructively and destructively, the resulting spectrums will be somewhat unexpected. I think the different internal filters should be seen as separate effect boxes instead. Perhaps with separate outputs, and the user can mix & treat these at will. |
jhaible
Posted: Fri Oct 24, 2008 6:15 am Post subject:
/mr wrote: | I found this interesting thread today. I'm not sure if the project has been put on ice or if it's still alive, but... although I don't have any better fixed filter suggestions than the above mentioned, I would be very interested in buying an FFF PCB or two if it becomes reality!
Go for it!
A side note:
FFF project will certainly happen.
I have an idea how to make it more universally usable than intended - maybe.
Phase cancellation from mixing:
Unexpected: Yes.
Interesting: Just because of being unexpected, IMO.
Creating a deep notch somewhere near a resonance peak may look stupid in a filter plot, but may just be what gives an interesting, organic sound quality!
jhaible
Posted: Fri Oct 24, 2008 6:17 am Post subject:
Re: Another important fixed filter. Subject description: ... |
phdinfunk wrote: |
Something like this ?
http://www.jhaible.heim.at/string_filter/jh_string_filter.html
/mr
Posted: Fri Oct 24, 2008 7:35 am Post subject:
jhaible wrote: | Phase cancellation from mixing:
Unexpected: Yes.
Creating a deep notch somewhere near a resonance peak may look stupid in a filter plot, but may just be what gives an interesting, organic sound quality! |
Definitely!
But important to know that MALE CHOIR + FEMALE CHOIR not necessarily results in MIXED CHOIR. For example. |
