 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
monome + LiSa
Audio files: 6
G2 patch files: 48
PostPosted: Sun Jan 27, 2008 8:02 am    Post subject: monome + LiSa Reply with quote  Mark this post and the followings unread
Did my first attempt at using LiSa. That's a nice UGen! Smile
Also posted here:
http://post.monome.org/comments.php?DiscussionID=677&page=1#Item_1
There's a lot of talk at the monome site about doing new batches of 256s and 40h kits and other stuff. If you are interested in having a simple interface to ChucK I really recommend checking these out. The 128s and 64s are priceworthy IMO, if you are the kind of person who likes to throw together a new ChucK program, mess around with it and maybe drop it to do another. With the monome you have great interface while doing this.
Code:
//   Stefan's little live sampler     //
//   by Stefan Blixt                  //
//   2008-01-27                       //
//   last update: 2008-01-27          //
// Hook up a radio or your own stuff or something else to the main input and go crazy.
// Adjust monome size below.
// global values of interest
16 => int monome_width;
16 => int monome_height;
1::second => dur loopLength;
10::ms => dur crossfade;
//==== OSC ====
OscSend xmit;
xmit.setHost("localhost", 8080);
OscRecv orec;
8000 => orec.port;
orec.listen();
orec.event("/256/press,i,i,i") @=> OscEvent pressEvent;
OscRecv tickOrec;
8001 => tickOrec.port;
tickOrec.listen();
tickOrec.event("/myclock/tick,i") @=> OscEvent oscTickEvent;
fun void lightColumn(int x, int state, int mask1, int mask2) {
   xmit.startMsg("/256/led_col", "i i i");
   x => xmit.addInt;
   if (state == 0) {
      0 => xmit.addInt;
      0 => xmit.addInt;
   } else {
      mask1 => xmit.addInt;
      mask2 => xmit.addInt;
class Loops {
   // practical values
   dur localLoopLength;
   localLoopLength / monome_width => dur slotLength;
   //signal chain
   adc => Gain flatGain => LiSa loopme => dac;
   adc => LPF lpf => loopme;
   1000.0 => lpf.freq;
   adc => HPF hpf => loopme;
   6000.0 => hpf.freq;
   localLoopLength => loopme.duration;
   int voices[2];
   loopme.getVoice() => voices[0];
   loopme.getVoice() => voices[1];
   loopme.rate(voices[0], 0.9);
   loopme.rate(voices[1], 0.9);
   loopme.rampUp(voices[0], crossfade);
   loopme.rampUp(voices[1], crossfade);
   loopme.rampDown(voices[0], crossfade);
   loopme.rampDown(voices[1], crossfade);
   // Graphics
   int mask1;
   int mask2;
   fun void init(float divider, int inmask1, int inmask2) {
   inmask1 => mask1;
   inmask2 => mask2;
      loopLength / divider => localLoopLength;
      localLoopLength / monome_width => slotLength;
   fun void playLisasSlots() {
      while (true) {
         0 => int voiceCounter;
         for (0::ms => dur currentTime; currentTime < localLoopLength; slotLength +=> currentTime) {
            (currentTime / slotLength) $ int => int column;
            lightColumn(column, 1, mask1, mask2);
            voiceCounter++ => int voice;
            if (voiceCounter >= 2) {
               0 => voiceCounter;
            loopme.playPos(voices[voice], currentTime);
            loopme.play(voices[voice], 1);
            slotLength => now;
            loopme.play(voices[voice], 0);
            lightColumn(column, 0, mask1, mask2);
monome_height / 4 => int loopAmount;
Loops loops[loopAmount];
loops[0].init(1, 0x0f, 0x00);
loops[1].init(1.5, 0xf0, 0x00);
spork ~ loops[0].playLisasSlots();
spork ~ loops[1].playLisasSlots();
if (loopAmount > 2) {
   loops[2].init(0.75, 0x0, 0xf);
   loops[3].init(0.5, 0x0, 0xf0);
   spork ~ loops[2].playLisasSlots();
   spork ~ loops[3].playLisasSlots();
//======== Input ==========
fun void keyPressed(int x, int y) {
   if (x < monome_width && y < monome_height) {
      y % 4 => int row;
      loops[y/4] @=> Loops @ loop;
      0.0 => loop.flatGain.gain;
      0.0 => loop.lpf.gain;
      0.0 => loop.hpf.gain;
      if (row == 0) {
         1.0 => loop.flatGain.gain;
      } else if (row == 1) {
         1.0 => loop.lpf.gain;
      } else if (row == 2) {
         1.0 => loop.hpf.gain;
      x * loop.slotLength => loop.loopme.recPos;
      1 => loop.loopme.record;
      loop.slotLength => now;
      0 => loop.loopme.record;
fun void keyReleased(int x, int y) {
//==== Startup graphic ====
xmit.startMsg("/256/clear", "i");
0 => xmit.addInt;
1::ms => now;
5 => xmit.addInt;
255 => xmit.addInt;
255 => xmit.addInt;
10 => xmit.addInt;
255 => xmit.addInt;
255 => xmit.addInt;
1::second => now;
0 => xmit.addInt;
while (true) {
   pressEvent => now;
   while (pressEvent.nextMsg() != 0) {
      pressEvent.getInt() => int x;
      pressEvent.getInt() => int y;
      pressEvent.getInt() => int state;
      if (state == 1) {
         keyPressed(x, y);
      } else {
         keyReleased(x, y);
You are Wendy Mackaye, first girl on the red planet.
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
