Schulte Compact A Phasing
Page 8 of 26 [649 Posts]
Goto page: Previous 1, 2, 3, ..., 6, 7, 8, 9, 10, ..., 24, 25, 26 Next
jhaible
PostPosted: Mon Jan 28, 2008 1:26 am    Post subject: Reply with quote  Mark this post and the followings unread
LDRs are on their way to me!
JH.
mono-poly
PostPosted: Mon Jan 28, 2008 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
surprise
Electronicant
PostPosted: Tue Jan 29, 2008 4:56 pm    Post subject: More projects Reply with quote  Mark this post and the followings unread
Hi. For future projects....Would it be possible to make boards for a tape delay with CV control? I´d like to see something like the Fulltone Tube Tape Delay with CV control in my modular Smile
hachiman
PostPosted: Tue Jan 29, 2008 6:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
please stay ontopic ...! I doubt you get answer anyway.
now how about the CV into the phaser? Laughing
PostPosted: Tue Jan 29, 2008 6:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
but then it wouldn't be true to the original Wink Very Happy
ACHTUNG!
hachiman
PostPosted: Tue Jan 29, 2008 6:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
I ordered 2 I can mess with the other one. FYI the System 700 phaser is also 741 "chain"
qwave
PostPosted: Wed Jan 30, 2008 10:34 am    Post subject: Help for soldering needed Reply with quote  Mark this post and the followings unread
OK, now that the shipping is near, I need to find someone willing to solder the components to the board for me. I am not a electronic tech at all. I am a carpenter.
So if there is someone willing to help me, please let me know. I will pay for all the additional parts and of cause for the labor.
I offer help on wooden side panels if needed.
keep on turning these knobs
Till "Qwave" Kopper
http://www.till-kopper.de
jhaible
PostPosted: Wed Jan 30, 2008 12:03 pm    Post subject: Re: Help for soldering needed Reply with quote  Mark this post and the followings unread
Hey Till,
I'll solder your board, and you build the wooden enclosure for my next synth?
Wink
JH.
jhaible
PostPosted: Wed Jan 30, 2008 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, the jacks for remote control do *not* accept CVs. (You need insulated jacks, and the sleeve is not grounded!) That's not elegant, but close to the original with its multi-function DIN jack.
Nevertheless, you *should* be able to feed a CV into the *Tip* of a TRS plug into the AMOUNT jack, with Sleeve and Ring both *unconnected*, and a connection of the Phaser's signal GND to the GND of the CV-producing device. The interesting CV range will be about 0V ... +10V in that case.
This is completely untested - yet.
Oh, and I don't plan to offer a tape delay.
JH.
ericcoleridge
PostPosted: Wed Jan 30, 2008 3:55 pm    Post subject: Re: More projects Reply with quote  Mark this post and the followings unread
Sorry for this off topic.
I have a Korg SE500, that has CV control over tape speed, and it's a little disappointing actually. Unfortunately, it takes the motor a long time to respond to the in-coming CV signal so that the ferquency change is not very dramatic. It does give intesting results sending LFOs and modulations, but for dramtic delay shifts, it doesn't really work.
Of course, I don't know if this is a "flaw" of the Korg design itself, or a design hurdle in general for voltage controlling electric motors.
jhaible
PostPosted: Wed Jan 30, 2008 4:01 pm    Post subject: Re: More projects Reply with quote  Mark this post and the followings unread
Just think of the extreme mechanical stress on everything, if you'd, for instance, tried to achieve transposing the contents of the tape by 1 octave (by doubling the speed) *without* portamento.
But you should really start a new topic for that - please!
JH.
Etaoin
PostPosted: Thu Jan 31, 2008 12:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Anyone in Germany willing and able to order these heatsinks from Reichelt and send them to The Netherlands? All expenses paid of course. Please PM if you can...
EDIT:
No need to reply anymore. This should be covered!
http://www.casia.org/modular/
Serenadi
PostPosted: Thu Jan 31, 2008 8:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Etaoin, you'll have pm.
morbank
PostPosted: Thu Jan 31, 2008 10:37 am    Post subject: Trouble finding parts? Reply with quote  Mark this post and the followings unread
Hello All, I'm new to this list and I accidentally posted this as new post but I meant to post it here, so sorry for the double post...
I'm eagerly awaiting the pcb from JH and while I wait I thought I'd try and get a head start on tracking down some parts. I have pretty limited experience shopping for parts and I'm already having a tough time here in the US with some of them so any help answering the following questions would be greatly appreciated!
1. Are the heatsinks exact dimensions crucial? I've found the right style of heatsink but then dimensions never match up!
2. The trimpots, Again I can't seem to find the right combo for value and size.
3. Can the Capacitor voltage be as high as 50 or 100v? And I'm finding many specs don't show the spacing measurements or even what type of capacitor it is.
4. Any idea why I can't find the 120Ohm, 5 Watt resistor?
5. The closest I've come to finding the lamps is 6v 100mA, but they are $20. And no trace of the holders!
6. And while I can find the fuses I've had no luck with the holders either.
7. And no sign of the 2p2t relay as well.
8. And lastly, are the board connectors called something different here in the states? Sockets maybe?
9. Any recommendations for places where you guys have found some of the parts I'm having trouble locating?
So far I've visited Digi-key, Mouser, All Electronics (who's retail store is near my work), Rapid Electronics, Jameco, Allied Electronics. I also got some info on a few new spots from replies to my first post, Futurlec and Apexelectronics which is another store near my work.
Sorry for all the clue-less-ness but I'm determined to do this project justice and hopefully someone here can point me in the right direction.
-Clay Morrow
jhaible
PostPosted: Thu Jan 31, 2008 2:02 pm    Post subject: Re: Trouble finding parts? Reply with quote  Mark this post and the followings unread
Dimensions are not crucial.
The advantage of the ones I've chosen is that they can be soldered into th eboard, thus are mechanically fixed, and won't touch each other even though the gap betweene them is small. Therefore thy don't need to be insulated from th etransistors and voltage regulators. (They carry voltage, though, so don't short them with a screwdriver etc. !)
Alternatively, you can insulate every transistor and voltage regulator, and allow the heatsinks tuching each other. Could even be mounted on one single heatsink then, if you find a good mechanical solution.
Look around. These are of a *very* common size.
Sure. you can always use higher voltage rating. just make sure that they won't bee to big in size, so they will still fit on the board.
Honestly, no. Every good electronics shop should have 5 watt resistors.
7V 100mA lamps may be hard to get outside Europe.
I know someone has started organizing a group buy from Reichelt. I'll let you know (on the forum) when I know more.
Alternatively, you can experiment with 6.3V 100mA lamps, and two 1N4002 diodes in series. (They go where the two wire bridges are shown on the PCB) This is untested, though. I'm pretty sure that there will be a way to organize getting 7V lamps from Europe.
Glad to heat this!
I expect a similar solution as for th elamps themselves.
Alternatively, you can simply solder the lamps into the board with two pieces of wire. They are operating way below their nominal rating in this circuit, so I don't expect you'll ever have to change them.
You don't need a specific brand. DIL relays are very common, from various manufacturers. The Meder seems to be obsolete. A Finder 12V DIL relay works fine (tested!) - othere brands will work also.
Can someone from the USA chime in here?
JH.
jhaible
PostPosted: Thu Jan 31, 2008 2:09 pm    Post subject: Re: Trouble finding parts? Reply with quote  Mark this post and the followings unread
Hmm ...
I have seen heatsinks with *exactly* the same dimensions at Mouser. That's why I've chosen them in the first place.
What i didn't do was actually ordering them from Mouser (I just compared data sheets from Mouser and Reichelt).
And what, unfortunately, I didn't do either, was writing down the mouaser number. But they are there, absolutely.
Same goes for the relays. I don't believe none of these shops have DIL relays. I'd expect them *all* to have them. (Not the Meder brand, though.)
The only thing that *will* be a little harder to get are the lamps.
Either you get them from Reichelt (Group buy ...), or maybe one of the small shops who also offered TDA1022s for the Triple Chorus put them in stock.
If nothing else works, you can go the 6.3V + 1N4002 route.
JH.
Etaoin
PostPosted: Thu Jan 31, 2008 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got mine from the Dutch store http://www.elektronica-online.nl/
They do seem to have an international store as well, although I don't have any experience with that. It does cary E10 7V 100mA as well though:
http://www.elektronica-online.com/target/content_details.php?id=5428
jhaible
PostPosted: Thu Jan 31, 2008 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.elektronica-online.com/target/content_details.php?id=5428&PHPSESSID=444af9be03ed594db846a68f0dc7c278
Excellent. Thanks for posting this!
JH.
morbank
PostPosted: Thu Jan 31, 2008 3:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow thanks guys! elektronica worked out great for the bulbs, although they didn't seem to have the holders...
JH, I'm reading over your comments now and will report back with any findings. Thanks again for all the help.
-Clay
morbank
PostPosted: Fri Feb 01, 2008 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Just following up on my search for parts. I've found most everything now and I thought I would share some info for the parts that were hard for me to track down here in the US.
Mouser finds:
Heatsink:
532-523002T00
TO-220, VERT 13.6 TR
Trimpots:
531-PT10H-1K
1Kohms 10mm Rnd
531-PT10H-500K
500Kohms 10mm Rnd
Fuse Holder:
441-EPD2005
Fuse Block 5x20mm
Relay:
817-A-12W-K
Mini Signal 12VDC
Lamp Holders (8th from the bottom):
http://www.greenweld.co.uk/acatalog/Shop_Bulbs_199.html
I still can't find the 2, 3, and 5 pin board connectors so if anyone has a US source please let me know.
-Clay
jhaible
PostPosted: Fri Feb 01, 2008 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not tested myself, just quoting Serenadi from the Frequency Shifter thread:
they are called MTA 100 connectors.
JH.
morbank
PostPosted: Fri Feb 01, 2008 3:27 pm    Post subject: MTA 100 Connectors Reply with quote  Mark this post and the followings unread
Thanks JH. Do these (Option C) look right?
http://www.mouser.com/catalog/632/1223.pdf
Polorized Headers or Friction Lock Headers?
-Clay
jhaible
PostPosted: Fri Feb 01, 2008 3:45 pm    Post subject: Re: MTA 100 Connectors Reply with quote  Mark this post and the followings unread
-Clay
Option C looks closest to the PSK types I'm using.
JH.
qwave
PostPosted: Sat Feb 02, 2008 2:13 am    Post subject: Reply with quote  Mark this post and the followings unread
I received the board today.
Thanks !
Till "Qwave" Kopper
Clack
PostPosted: Mon Feb 04, 2008 12:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have a few quick questions if someone doesn't mind answering - or jurgen if he is not to busy?
im building it into a metal box,
whats the smallest transformer I can use? I mean what region of current will this need?
Would there be any point in heatsinking the regulators to the case? I understand you cant electronically contact a regulator to chassis ground i will insulate that - pointless maybe
Im going to try it with 6.5v 300mA 0.97W bulbs ill say what happens - need a good stock of bulbs incase i drop it or they blow or somthing
Clacktronics.co.uk
JuneSolstice2013
