 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
 Forum index » Instruments and Equipment » Linux as a music workstation
Linux Audio Driver Annoucements
Page 1 of 1 [11 Posts]
jksuperstar
G2 patch files: 17
PostPosted: Mon Jul 23, 2007 10:24 am    Post subject: Linux Audio Driver Annoucements
Subject description: post your news about new drivers for linux here
First, I noticed (finally!!) the Emu 1616/1616m (basically all microdock based interfaces) will have support in the next release of ALSA.
http://www.alsa-project.org/alsa-doc/forums.html?vendor=vendor-Creative_Labs#matrix
Also, FreeBoB seems to be collecting quite a list of supported FireWire devices for Linux:
http://freebob.sourceforge.net/forums.html/List_of_Supported_Devices
myspace.com/triptechmusic
Triptech <-- new album!
Kassen
PostPosted: Mon Jul 23, 2007 10:51 am    Post subject: Re: Linux Audio Driver Annoucements
YES! That's brilliant news, especially since I just got a HD that's the exact same model as the one that's in my laptop which I am planning to swap into the laptop and install Linux on.
Modern technology offers an endless field day to any deviant strains in our personalities. --J.G.Ballard
Kassen
PostPosted: Mon Jul 23, 2007 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmmmm, but no midi.
jksuperstar
G2 patch files: 17
PostPosted: Mon Jul 23, 2007 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, no MIDI, but I'm hoping that will come soon. Now I can start on that linux distro again (the one with low-latency, simple graphics, and all the e-m.com tools that we all love so much like chuck, Pd, and maybe even some VST/LADSPA/LV2 plugin support.)
Maybe once there's MIDI support, (someone?) can add MIDI control to the mixer, if the linux driver has one.
Kassen
PostPosted: Sun Aug 05, 2007 4:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe that would be the distro for my laptop then. Would you considder including Fluxus? I think Fluxus is in Dyne already and I'm having trouble compiling it on my desktop so far. Fluxus is a system for livecoding graphics (based on Scheme, it has a physics engine and openGL)
ten fingers ten toes
PostPosted: Thu Jan 31, 2008 11:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
If anyone is considering purchasing one, I have a Phonic Helixboard Firewire 12 running perfectly in Ubuntu 7.10 using Freebob 1.0.7. Now if only I could find the alsa jack plugin so I could route alsa audio into jackd -- right now most of my applications are not jack aware (Firefox is a biggie -- no youtube!) but I'm sure this can be corrected if I spent some more time.
Stochastic
PostPosted: Mon Feb 25, 2008 11:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi, just thought I'd share some info on that jack/alsa plugin in Ubuntu Gutsy. According to this post: http://ubuntuforums.org/showthread.php?p=4380041 it doesn't work in Gutsy because of a bug, but there may be workarounds.
Audio files: 28
G2 patch files: 295
PostPosted: Tue Feb 26, 2008 3:50 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome Stochastic
Stochastic
PostPosted: Tue Feb 26, 2008 9:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Blue Hell.
I stumbled across this section of the forums after lurking in the ChucK section for a bit now. Thought it had a rather low traffic rate and figured my enthusiasm for FOSS and audio could help.
Coriolis
PostPosted: Wed Jun 11, 2008 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm - I see there is FreeBoB support for the Focusrite Saffire, but not the dsp and mixer section. I wonder if that means it would work with my Saffire LE?
Anybody have experience with the Saffire? And no mixer support sounds like a bummer...
C
Stochastic
PostPosted: Wed Jun 11, 2008 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
You may want to try the new beta ffado driver (a reincarnation of freebob) as the developers have been given saffires (both pro and LE) to test on, so the mixer (probably not the DSP) should work.
http://greyrock.blogspot.com
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
