abis
Joined: Apr 28, 2007 Posts: 34 Location: Toronto, Ontario
Posted: Mon Jan 07, 2008 3:35 pm Post subject:
G2 Demo and Mac OSX 10.3.9 conflict? |
After downloading and trying out the G2 Demo, I find I no longer have sound in Firefox and RealPlayer. Strangely, iTunes has not been effected.
I have a M-Audio Delta 24/96 soundcard and am running OS 10.3.9. The monitor mixer shows input from iTunes, but nothing from other sources of audio.
Has anyone else experienced this? I'm not sure where sound settings for Firefox are. Any suggestions for solving it? |
seraph
Editor
Joined: Jun 21, 2003 Posts: 12010 Location: Firenze, Italy
Audio files: 31
Posted: Mon Jan 07, 2008 4:08 pm Post subject:
Re: G2 Demo and Mac OSX 10.3.9 conflict? |
| abis wrote: | | Any suggestions for solving it? |
have you already checked out "audio MIDI setup" (applications>utilities>audio MIDI setup) to see which one is the selected audio device? _________________ homepage - blog - forum - youtube
| Quote: | | Politics is the entertainment division of the military industrial complex - Frank Zappa |
abis
Posted: Mon Jan 07, 2008 4:14 pm Post subject:
| yes, I tried that, and everything is set for the Delta card. |
seraph
Editor
Audio files: 31
Posted: Mon Jan 07, 2008 4:22 pm Post subject:
| abis wrote: | | yes, I tried that, and everything is set for the Delta card. |
try switching to the built in output. _________________ homepage - blog - forum - youtube
rh2y
Joined: May 08, 2007 Posts: 197 Location: Pittsburgh, USA
Posted: Tue Feb 05, 2008 7:10 am Post subject:
| abis wrote: | After downloading and trying out the G2 Demo, I find I no longer have sound in Firefox and RealPlayer. Strangely, iTunes has not been effected.
I ran into a problem like this once in 10.3.9 where Cubase would set the global Audio sample rate to 96 kHz, which would cause Safari and other apps to have no sound, though iTunes would still work. Check Applications -> Utilities -> Audio/Midi Setup, and set the system audio sample rate back to 44.1 kHz and see if it works again. They seemed to have fixed this behavior in later versions of OSX.
Russ _________________ Shameless plug: http://www.whiterose.net/~russ/synth.html |
abis
Posted: Tue Feb 05, 2008 3:33 pm Post subject:
That was just what the doctor ordered!
Thanks for solving this frustrating puzzle.
Andrew |
rh2y
Posted: Tue Feb 05, 2008 3:42 pm Post subject:
| abis wrote: | That was just what the doctor ordered!
I'm glad that fixed it for you!
I remember having the exact same problem and not figuring it out for quite a while. Rebooting just to get your sound back gets old in a hurry!
Maybe someone should whip up a quick AppleScript to set the sample rate back to 44.1 so you don't have to go through all those motions each time.
Posted: Tue Feb 05, 2008 3:48 pm Post subject:
| rh2y wrote: | I ran into a problem like this once in 10.3.9 where Cubase would set the global Audio sample rate to 96 kHz, which would cause Safari and other apps to have no sound, though iTunes would still work. Check Applications -> Utilities -> Audio/Midi Setup, and set the system audio sample rate back to 44.1 kHz and see if it works again. They seemed to have fixed this behavior in later versions of OSX.
Russ |
Actually, I´ve seen the exact same thing but with M-Audio drivers for various M-Audio products. The sample rate setting and often even sync would flip off into the twilight zone. Cubase was not involved at all.
Uh.. we are talking OS X here of course... _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
