Pitch makers
Page 1 of 1 [17 Posts]
Audio files: 107
PostPosted: Mon Feb 11, 2008 4:39 pm    Post subject: Pitch makers Reply with quote  Mark this post and the followings unread
Once we have little cheap digital oscillators we need to make some pitch patterns.
One of the easiest to use is the modulo-n counter. You can get a 4018 chip that does this function. I don't do building any more so I leave it as an excersize for someone to post the way to set the pinouts. Here's a link to the data sheet: http://www.st.com/stonline/books/pdf/docs/2032.pdf
The idea is that you plug in your OSC, or any other signal that is square (digital) into the input and the output is divided by the binary number applied to the 4 control inputs.
There is no need to do anything but wire up the 4018 to the banana jacks.
1 input
4 control inputs
1 output.
That's it. You have a little mellody generator.
What do you do for the inputs. Well that's where a lot of fun comes from. You can plug anything you want into the control inputs. Lets say you have 4 oscillators - plug one into each input.
Or, if you have a binary counter IC, use that to divide down a single oscillator to make a pattern. It's best to use a binary up/down counter.
Here are a couple of G2 patches that work with the free G2 demo program. I made the modulo-n counter using flip-flops and logic gates since the G2 doesn't have a modulo-n counter module. All of the red stuff is the modulo-n counter. In the Lunetta, use the 4018 chip - much easier. Anyhow, the G2 patches are there just to give you an idea what this will sound like. Real Lunettas sound like this though - pretty much.
Using the OSC demo, be sure you change the frequencies of the oscillators so you get a feel as to what is happening. In the binary counter demo, be sure to try repatching the order of the connections from the binary counter. You'll get different patterns.
Mod-n w counter.pch2
A demo of the modulo-n counter (converter/divider) being controlled by a binary counter. This is something similar to the 4018 chip for use in a Lunetta.
 Filename:  Mod-n w counter.pch2
 Filesize:  1.14 KB
 Downloaded:  1046 Time(s)
Mod-n w oscs.pch2
A demo of the modulo-n counter (converter/divider) being controlled by 4 OSCS. This is something similar to the 4018 chip for use in a Lunetta.
 Filename:  Mod-n w oscs.pch2
 Filesize:  1.32 KB
 Downloaded:  961 Time(s)
bugbrand
PostPosted: Tue Feb 12, 2008 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Interesting!
Division is generally much easier than multiplication --- but, I've been reading a bit about using a 4046 PLL and a 4017 divider to multiply signals - haven't tried this properly yet, but.....
Here's the schem::::
(I think its from a book by Marston)
4046 / 4017 frequency multiplier
 Filesize:  27.35 KB
 Viewed:  11430 Time(s)
http://www.bugbrand.co.uk
Audio files: 51
PostPosted: Tue Feb 12, 2008 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
This is exactly the circuit I was looking for, for something else.
This Lunetta forum is bringing out some great ideas!
We would lose our friends.
So,.........
Audio files: 107
PostPosted: Wed Feb 13, 2008 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
That freq multiplier looks cool, but a little complicated... Rolling Eyes
Still, it's in the Lunetta spirit. I'd suggest building the divider first. Once one gets into these things, it turns out that you can really enjoy the simplest circuits.
loss1234
PostPosted: Thu Jun 19, 2008 8:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
bugs
did you ever build that multiplier? i have been doing a ton of stuff with the 4046 lately but i myself have been using it with a 4024 between pins 3 and 4.
one of the things i am doing a lot now is converting an audio signal to square, uping its frequency with a 4046 and then spitting the divided outs to the control ins of other counters.
i was wondering if there is any significant difference with a 4017 but i guess i can just try it.
jnuaury
Audio files: 9
PostPosted: Fri Jun 20, 2008 2:20 am    Post subject: Reply with quote  Mark this post and the followings unread
the 4024 should only give you octave multiplications... x2, x4, x8 etc
the 4017 will give you non-octave intervals in addition to a few octave multiplications
loss1234
PostPosted: Fri Jun 20, 2008 3:37 am    Post subject: Reply with quote  Mark this post and the followings unread
wow
i need to try that!!
Audio files: 51
PostPosted: Fri Jun 20, 2008 6:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, this is related to the other question you posted Loss1234 hey?
I knew I'd seen something else which was a lot more immediate than the description I quoted.
If you used a 4046 with a 4017 in the feedback path you could take an input up in frequency by 2X, 3X, 4X, 5X, etc. which would equal some octaves, but also the 3,5,7,9 are not octaves. Then you could divide back down by 2,3,4,5,6,7,8,9 etc. using another 4017. This way you could get heaps more intervals/ratios.
Don't forget that 4017s can be cascaded with the addition of an AND gate, which would mean more ratios again. For example, you could multiply by 13 and then divide by 12. Would that be 1 semitone up? Maybe not, but you get the idea. Man I wish I had the time to start on my own Lunetta!
BTW The cascading of 4017s can be seen at the bottom of it's datasheet. Very Happy
So,.........
loss1234
PostPosted: Fri Jun 20, 2008 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
wow
thats the ticket!!!
now i have so many ideas!
cant wait to get to the bench tonight.
thanks
ericcoleridge
PostPosted: Fri Jun 20, 2008 11:52 am    Post subject: Reply with quote  Mark this post and the followings unread
loss1234 wrote:
bugs
Loss, how is this working out for you? Does the 4046 follow your squared-up audio signal pretty well?
I'm gonna breadboard the multiplier circuit too when I get a chance. This is something I've been looking for as well-- I want a multiplier for use in clocking rhythmic audio signals to drive syncable delay effects, and/or other syncable circuits. More less, I'm trying to get the function of a tap-clock that can do triplets, quarter-notes, eighths, etc.
Draal
PostPosted: Wed Jan 05, 2011 10:52 am    Post subject:
Subject description: The 4018 Revisited
Mosc, thanks for the info on this ic! Works as described and super simple to implement. Lots of cool sounds depending on what's being fed in. Got to get me a bunch more Very Happy ! Here's a track recorded live with the Fender FRV-1 reverb pedal. I patched thru my 4040 as well as my 4015 shift register to alter the mood a bit. No editing or other effects used.
OnTV by Draal
Zontar Prevails!
Audio files: 107
PostPosted: Mon Jan 17, 2011 12:06 pm    Post subject:
Great, glad you are getting into this. Your track sounds great.
Kabzoer
PostPosted: Mon Feb 07, 2011 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can you give me a download of that G2 program?
Audio files: 116
G2 patch files: 317
PostPosted: Mon Feb 07, 2011 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Go to http://www.nordkeyboards.com/main.asp?tm=Products&clpm=Nord_Modular_G2&clnmm=Information and download the demo there.
Kabzoer
PostPosted: Thu Feb 10, 2011 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
I downloaded all the stuff, but there comes no sound out of it...
Audio files: 116
G2 patch files: 317
PostPosted: Thu Feb 10, 2011 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Interesting Laughing
You did download the DEMO?
You did select an audio out in Setup/Audio Midi?
Kabzoer
PostPosted: Fri Feb 11, 2011 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! Got it working Very Happy
So, it counts the number of inputs that are high, and divides the clock by that?
Niio2
