Pehr
Joined: Aug 14, 2005 Posts: 1306 Location: Björkvik, Sweden
danielwarner
Posted: Sat Feb 16, 2008 2:56 am Post subject:
Subject description: Protection circuitry |
| Maybe some 5.1V zener diodes on inputs, that way one could safely experiment with interfacing with other synths, drum triggers, microphones, without damaging the ICs? |
Joined: Apr 03, 2004 Posts: 19569 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Sat Feb 16, 2008 5:13 am Post subject:
| Pehr wrote: | Sure ! The XR2211 can detect frequencies and send logic signals if the incoming tone is within the range.  |
Ah, memories I used such devices a long time ago for remote control of video machines; it would still work today, even over the mobile network. _________________ Jan |
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Sun Feb 17, 2008 11:31 am Post subject:
What I've been calling Lunettas don't represent everything that Stanley Lunetta has designed and built. My experience with these is from the early 1970s.
I don't know what Stan did later, but I bet he didn't change the spirit. The basic elements of the sprirt are - you learn by trying and experimentation. You build just for yourself (share ideas and techniques, but they don't have to be "products" or even things that other people could build.)
So, if reading Stan's interview inspires you to develop something similar to what he describes, then by all means go ahead and try.
Often, I would ask Stan, "How did you figure that out?" He would say something like, "I just hooked one of these chips up and started fooling around." Sometimes, a design would only work on one chip!
I do know that Stan liked mercury switches. I bet his hat have many of those mounted inside (just a guess). I saw the hat once, but never got to look inside. I love mercury switches and micro switches. Put 4 on a modulo-n divider and you've got a position sensitive sequencer thingie. You can also route signals through them.
Build - Learn - Play - Share _________________ --Howard
my music and other stuff |
loss1234
Photon
Joined: Jul 11, 2005 Posts: 4737 Location: Nambucca Heads, Australia
Audio files: 51
Posted: Sat Feb 23, 2008 2:22 am Post subject:
Now we're talking!!!
Well,... If we're gonna talk blocks, we may as well go for the block of all blocks, the block's block, the block to get the party started, the block party (great name for a band!?) The "I'm thinking of a block between 1 and 10, guess which one" kind of block. LEGO.
But do Lego do a block which is big enough for the inputs and outputs of a dual 4bit binary counter?
Hey! (sound of machinery crunching concepts) Why not just glue Lego together? Make little shapes which are big enough for any CMOS chip you like! Possibly still supply power through the baseboard!
There are very good prospects for a dam sexy Lunetta here!!
(Well, I've always found Lego sexy. There nothing wrong with that is there? ) _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
We would lose our friends.
So,.........
Do you really want to lose yourself? |
CJ Miller
Posted: Tue Mar 11, 2008 7:15 am Post subject:
| I am a digital n00b, but am becoming somewhat familiar with most of these kinds of ICs. But what is a "pulse modifier"? I can think of many ways to modify pulses but I don't know whether or not this might be a CMOS chip I've never heard of. |
williamsharkey
Posted: Tue Mar 11, 2008 9:05 am Post subject:
| Uncle Krunkus wrote: |
(Well, I've always found Lego sexy. There nothing wrong with that is there? ) |
That's because there are girl and boy parts. That's how they fit together =) |
Adam-V
Posted: Tue Mar 11, 2008 6:28 pm Post subject:
A Pulse Modifier merely shortens or extends the length of a pulse by a given amount. You sometimes see them in the modular synth world as Trigger/Gate modifiers or delays. Something as simple as a 555 timer set up in one-shot mode would do this very nicely.
Adam-V
| CJ Miller wrote: | | I am a digital n00b, but am becoming somewhat familiar with most of these kinds of ICs. But what is a "pulse modifier"? I can think of many ways to modify pulses but I don't know whether or not this might be a CMOS chip I've never heard of. |
_________________ Digitalis Effect | Fractured Symmetry (www.spiralsect.com) |
scriptstyle
Posted: Tue Mar 25, 2008 1:49 pm Post subject:
| so glad i just read this whole thread!!! those quotes on pagr 1 are great, i need to read that interveiw. yo uncle block party is a really good band. i have already built a wsg, and some other small stuff tonight im hopeing to breadboard bug brands ocs schematic. but what is the sugested next step i have some 4017s and 4016s, maybe a baby 10 or somthing similar? and im still alittle confused on how this system is powered? or what is really suggested, this is one thing that is confusing me with getting into modular diy, i just dont want to build a bunch of stuff that dosnt work together. |
bingmachine
Posted: Wed Feb 11, 2009 9:56 am Post subject:
I'm wondering about a couple of the suggested blocks. What good are the 4 Bit Adder and Binary Comparator, other than as pieces of combinational logic that might give some unexpected(?) result. Does anyone use them for anything predictable?
Examples? Mp3s? Anyone?
/Erik Forsling |
slacker
Posted: Wed Feb 11, 2009 1:07 pm Post subject:
I haven't tried it, but you could use the adder to create 2 versions of the same pattern but with a "delay" between them. If you fed the outputs from a counter into one set of inputs and set the other set to a fixed number, the pattern out of the adder would be the same as the counter but so many steps ahead of it.
You could then use this to create canons in the same was that mosc describes in this thread http://www.electro-music.com/forum/topic-23881.html.
Or you could use it to create a third pattern from 2 others by feeding 2 different patterns into each set of inputs. The output would then be the sum of the other 2 at any step, this wouldn't necessarily be predictable though.
Not sure about the comparator. |
Audio files: 107
Posted: Wed Feb 11, 2009 3:01 pm Post subject:
| slacker wrote: | | I haven't tried it, but you could use the adder to create 2 versions of the same pattern but with a "delay" between them. |
Very good suggestion and concept here. I'm so glad so many people are getting into spirit of this stuff. The delay is simple a shift register, of course.
The comparator could be as simple as a bunch of AND gates ANDed together.  _________________ --Howard
bingmachine
Posted: Thu Feb 12, 2009 4:59 am Post subject:
Aaah. I see. Good thinking.
Ok. I have to add one of those as well.
Still don't see why you would want the comparer, but now I'm sure there's a good reason to add one of those as well!
I've already added everything else from the list in the first post to my design. Gotta start building this thing now!
/Erik |
slacker
Posted: Thu Feb 12, 2009 12:10 pm Post subject:
The way I see it , basically what you're trying to do with a lunetta is create interesting streams of pulses either to listen to directly or to drive other things.
So I guess the comparator is just another way to do this, you feed it whatever you like into it's inputs and you get a stream of pulses out of the output(s).
I reckon the adder would also make a great modulator type effect at audio speeds. |
Audio files: 51
Posted: Thu Feb 12, 2009 4:36 pm Post subject:
| bingmachine wrote: | Still don't see why you would want the comparer, but now I'm sure there's a good reason to add one of those as well!
/Erik |
What if you wanted to compare two sets of 4 bits and do something when they're the same? Or when they're not?
BTW I'm hopefully going to start on a project which needs this exact function very soon. _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
So,.........
Audio files: 107
Posted: Fri Feb 13, 2009 9:50 am Post subject:
My personal experience is that with these Lunetta style things one first builds quick and dirty or throw-away prototypes. Once you find something you like you can build more permanent versions, if you like. So, maybe after building a comparator, which takes only a couple of chips, you might not want to use it, or, then again, you might. _________________ --Howard
Pehr
bingmachine
Posted: Sat Feb 14, 2009 7:34 am Post subject:
Eeeh. Aren't we talking analog comparators then? Or could I somehow make a 4-bit ADC using a 4-bit binary comparator? I don't see how.
But I definitely have to add a couple of analog comparators. (Puuh, it never ends.)
/Erik |
Pehr
RF
Joined: Mar 23, 2007 Posts: 1481 Location: Northern Minnesota, USA
Audio files: 28
Posted: Mon Feb 16, 2009 12:07 pm Post subject:
| bingmachine wrote: | Eeeh.... (Puuh, it never ends.)
You make it sound like a chore....
Quick - throw a couple circuits together and play for a while.
bruce _________________ www.sdiy.org/rfeng
(Herb Deutsch to Bob Moog ~1963) |
synthmonger
Posted: Mon Feb 16, 2009 12:43 pm Post subject:
| I'd suggest adding my easy peasy 40106 vco in there somewhere! You can build 6 VCO's outta that chip! |
scriptstyle
Posted: Mon Feb 16, 2009 1:04 pm Post subject:
| synthmonger wrote: | | I'd suggest adding my easy peasy 40106 vco in there somewhere! You can build 6 VCO's outta that chip! |
i 2nd that! i dare you to breadboard it and not feel the need to get creative with it. when i had mine on proto i was like wow that sounds cool . then add a hand full of caps and resistors acouple switchs/hard sync pots and your like wow i gotta record this! or maybe even make a new schematic/pcb. |
bingmachine
Posted: Tue Feb 17, 2009 5:38 am Post subject:
Haha!
Thanks for the concern and the support, guys! I'm planning a design at the moment that definitely will allow me to build a little, play a lot, build a little, play some more. But I need to get a better picture of what to build. The final design will resemble a breadboard, but in a box: patching being made with wire in the central area, pots and switches surrounding that. I can post an fpd-file when it's finished.
At the moment the design contains at least:
4 VCOs (Synthmonger design + sync if it works)
4 "ordinary" clocks
4 high speed, fixed rate, PWM-clocks (i.e. settable probability kind of)
dual 4bit counter
presettable 4bit counter
10 step Johnson counter
switches (1x4053)
4bit mux
8bit mux
16bit mux (yes, all of them)
dual 4bit latch
dual 4bit shift register (serial in-parallell out)
2x8bit R-2R-network
2 passive mixers
2 ordinary mixers
4xTrig2Gate (NE558 with pots)
4xGate2Trig
4xAR-env
4x"VCA" (diode style)
4bit adder
4bit comparator
2 analog comparators
quad or
quad nand
quad xor
PLL
hex inv
8xTrig/CV input(/output) (e.g. 8 triggers coming from a TR505)
speaker
headphone ampl.
I might have forgotten something. I will start with the output section and some oscillators soon. Then I will keep adding stuff as I get bored with what I have (and get the time). Which makes me think that I might acctually succeed in building something. I won't even need a frontpanel to start with.
/Erik |
