mini banana's?
Page 1 of 2 [35 Posts]
23isgood
PostPosted: Sat Feb 16, 2008 1:38 pm    Post subject: mini banana's?
Subject description: where to order in the US
Well im going to start ordering parts for my Luneta. I dont have any banana systems at all, so I was wondering where is a good place to order some mini banana plugs and jacks? How about the cables for these? What would be the required gauge? I cant wait, for my Luneta. It will be a while before I have something up and running, but im excited.
thanks
pete
Check out my music
fluxmonkey
PostPosted: Sat Feb 16, 2008 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don Lancaster had mini-banana stuff in his online store forever... check http://stores.ebay.com/Synergetics-Abeja
b
23isgood
PostPosted: Sun Feb 17, 2008 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not a bad link, but he doesn't have mini banana's. After doing some searching, I really could not find these. It seems that I may just have to go with the standard banana style. I really want to build my Lunetta into a box that is as small as possible, thats why I want the mini banana's. Here are a few links I found for standard banana's,
http://shop.vetcosurplus.com/catalog/product_info.php?products_id=1032
http://www.futurlec.com/Banana-BananaPlugs.shtml
http://www.testpath.com/Categories/Banana-Plug-Patch-Cords-PVC-Stacking-1835.htm
The Pomona cables are nice but expensive.
pete
Check out my music
Audio files: 107
PostPosted: Sun Feb 17, 2008 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's nice to have a few of those nice Pomona cables, but most of the cables can be non-stackable home-made cheapies.
loss1234
PostPosted: Sun Feb 17, 2008 7:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
shoot i wish i could find some mini bananas
i found the mini bannana jacks BUT not plugs at electronic goldmine
bugbrand
PostPosted: Mon Feb 18, 2008 2:42 am    Post subject: Reply with quote  Mark this post and the followings unread
It *may* be possible to order from Rapid now (they've changed their minimum order for outside UK) - their prices are generally pretty darn good and they offer them in a nice selection of colours (futurlec only do red and black)
Sockets
Plugs
And cheaper non-RoHS plugs
http://www.bugbrand.co.uk
loss1234
PostPosted: Mon Feb 18, 2008 5:56 am    Post subject: Reply with quote  Mark this post and the followings unread
now i am pissed...those look awesome but i cant find them ANYWHERE else...and futurlec only seems to have the big banana plugs not the 2mm.
boo
fluxmonkey
PostPosted: Mon Feb 18, 2008 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
if you're having trouble sourcing, you might want to re-think your choice. hard to find, non-standard... i doubt the space savings would offset these downsides.
b
loss1234
PostPosted: Mon Feb 18, 2008 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah good point
anybody know where to get cheap pre-made banana cables? i have had real trouble with the plugs from radios shack (the kind where you solder the wire to the little hole toward the tip....maybe i am using the wrong type of wire ( I USED 24 AWG STRANDED)
any tips on making or sourcing the banana cables?
thanks
RF
Audio files: 28
PostPosted: Mon Feb 18, 2008 8:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Some sort of Test lead wire would be my first choice - but it's probably overkill....*
Here's the first thing that came up on a Google search - I'm sure you can find it for less $$, and probably in a smaller gauge.
http://www.bulkwire.com/product.asp?ProdID=21718&CtgID=6578
bruce
* (I have overkill tendancies. (Witness my 1/4 inch jacks and 1/8 aluminum panels (It's a deeply ingrained personality issue. )))
That - and introspective criticism. Rolling Eyes
toppobrillo
PostPosted: Mon Feb 18, 2008 2:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
here they are, they're called "tip plugs/ jacks" at mouser, for about the same price as banana types
http://www.mouser.com/catalog/633/1097.pdf
josh
RF
Audio files: 28
PostPosted: Mon Feb 18, 2008 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the pointer Josh!
Audio files: 51
PostPosted: Mon Feb 18, 2008 5:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can get black and red 2mm banana sockets and plugs from Dick Smith, but I'm only gonna use the sockets. For plugs, I'm just gonna solder a couple of 2mm nails to a variety of wire sizes/colours, and cover the joint with a bit of heatshrink. This will afford just as much (probably more) strain relief as the shitty little plugs would. (I'd have to re-inforce them with heatshrink anyway) And it will save some money as well.
Some extra colours in the way of sockets would be nice, but black-in and red-out will do fine for now.
We would lose our friends.
So,.........
frijitz
Audio files: 54
PostPosted: Mon Feb 18, 2008 9:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
josh
Ummm ... those are good, but they are not the same as miniature bananas.
Ian
toppobrillo
PostPosted: Mon Feb 18, 2008 11:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
they're not? i know the plugs aren't exactly 'bananas', more like pins.. i guess i have never seen these 2mm bananas. do they make stackable plugs?
edit: here are some minis on the previous page, see H
http://www.mouser.com/catalog/633/1096.pdf
hmm those tip plugs/jacks look really nice though.
josh
fluxmonkey
PostPosted: Tue Feb 19, 2008 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
another option would be the ciat lonbard/peter blasser method of brass pegs and alligator clips:
seriously
23isgood
PostPosted: Tue Feb 19, 2008 11:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Great searching guys! The Mouser parts look nice but way too expensive. There is always a catch. I really like those really tiny ones.
Check out my music
danielwarner
PostPosted: Tue Feb 19, 2008 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
You could use 2.5mm (3/32") jacks and plugs, that might not be cost effective though, haven't looked into sourcing them
RF
Audio files: 28
PostPosted: Tue Feb 19, 2008 6:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
josh
FWIW - I really like these pin types of plugs/jacks. Several years ago I scavanged some from a few pieces of old test equipment for use on another project...
However - You can't stack 'em, they don't work with anything else in my kit (or most anyone elses), they are no cheaper than Bananna's, have no smaller footprint than Bananna's, they are harder to find....
What the heck - I'll probably use them anyway Laughing
bruce
goldenechos
PostPosted: Wed Feb 20, 2008 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
If you are going to go for the mini bananas, I would advise getting the sockets and plugs from the same manufacturer.
I purchased a lot of several hundred EF Johnson mini bananas from ebay.
I then sourced some plugs from Ponoma, also sold as mini banana. these would not fit those sockets. It took me 3 tries to finds a plug that worked.
williamsharkey
PostPosted: Fri Feb 22, 2008 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Has anyone ever made specialty cables with circuit components inside of the cable?
For example: A cable with a diode in it?
Or maybe you are ideologically oppose to this - "a cable should do nothing, only modules affect sound"
williamsharkey
PostPosted: Fri Feb 22, 2008 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
What about small Neodymium Disc Magnets, has anyone made a cable system with these?
If it worked, it would be cool because it would be flush to front panel, like this:
Code:
VCA
           - insulator
    magnet[]
           - insulator
           |            []=======cable======[]
  VCA OUT [][]==\\
OSCILLATOR       ||
   freq   [][]\  ||
           -  \\_/|
           |   \_/
bugbrand
PostPosted: Fri Feb 22, 2008 8:17 am    Post subject: Reply with quote  Mark this post and the followings unread
That's a really interesting idea!
You could put a mini-magnet inside something like a grommet (y'know - those little rubber rings you pass cables through panels with)
I could imagine, perhaps though, that it may be hard to solder onto the rear-side of the magnet (and I think you'd want to do that, no?)
williamsharkey
PostPosted: Fri Feb 22, 2008 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
"I could imagine, perhaps though, that it may be hard to solder onto the rear-side of the magnet (and I think you'd want to do that, no?)"
Yeah, the texture on a neo magnet is very slick. And i wonder if solder responds to the magnetic field?
I'm gonna try to obtain some magnets and do experiments on them.
Audio files: 116
G2 patch files: 317
PostPosted: Fri Feb 22, 2008 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
You could just use a small iron or silver disc that you solder the wire on. The disc will stick to the magnet, and when it's good enough for a cable connection it's probably good enough for the connection on the other side as well Very Happy
Beware though that not every magnetic material will conduct electricity, ferrites are insulators, well the ferrite rods used for AM radio antennas and the ferrite shells used for coils are. So best try a sample first.
I see no reason to worry about a bad influence of magnetism on solder, I'd think the forces would be way to low to cause mobility of possible magnetic materials (like silver) in the solder mix.
