  Live electro-music improvisation by Twyndyllyngs Chez Mosc
Wavetable Osc
Page 1 of 1 [3 Posts]
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Jul 04, 2007 3:37 am    Post subject: Wavetable Osc
Subject description: wavetable oscillator with non-constant formants (as it should be)
Based on the same core circuit as this:
http://electro-music.com/forum/post-127356.html#127356
...but driving a clocked random module instead, giving you manually selectable waveforms. The difference to the "synced noise" approach is that the formants don't remain constant when changing frequency, as the waveform is actually played back faster or slower rather than simply being lengthened or shortened (like what happens in the "sync" approach). This is as it should be with wavetable oscs.
Again, the tuning is not super-perfect, sorry.
WavetableOsc TK.pch2
 Filename:  WavetableOsc TK.pch2
 Filesize:  1.32 KB
 Downloaded:  1529 Time(s)
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Jul 04, 2007 4:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a greatly simplified version, using a OscD sawtooth oscillator.
Pros: way less mem% and cycles% count, better tuning.
Cons: aliasing kicks in faster when going into higher frequency region.
Interesting: when used in this way, the OscC and OscD sawtooth waveforms perform drastically better then OscA and OscB in sawtooth mode. I suspect they are based on a totally different code.
WavetableOsc2 TK.pch2
way cheaper and better tuning, but more aliasing
 Filename:  WavetableOsc2 TK.pch2
 Filesize:  963 Bytes
 Downloaded:  1471 Time(s)
W.T.
G2 patch files: 11
PostPosted: Sun Feb 17, 2008 7:17 am    Post subject: Reply with quote  Mark this post and the followings unread
i am curious but the patch is no longer online Sad
