  bingsatellites Mostly Ambient
Possible issue using multiple outs on Motu Ultralite / OSX
Audio files: 218
G2 patch files: 93
PostPosted: Sun Feb 24, 2008 3:42 am    Post subject: Possible issue using multiple outs on Motu Ultralite / OSX Reply with quote  Mark this post and the followings unread
I've looked around some, but can't find any similar experience - this might be some config mistake on my part, but I doubt it.
I want to route out ChucK audio to something else than the main outs on my Ultralite audio interface (8 ordinary outputs besides the main outs). I tried doing this:
Code:
chuck --out4 multiple_output_test.ck
on this file:
Code:
LiSa lisa => dac;
1::second => lisa.duration;
1 => lisa.loop;
SinOsc sinOsc => lisa;
0.1 => sinOsc.gain;
0.3::second => lisa.recPos;
1 => lisa.record;
0.3::second => now;
0 => lisa.record;
sinOsc =< lisa;
1 => lisa.play;
while (true) {
   1::second => now;
The result is audio on all extra outputs (but not the main ones), judging from the visual feedback on the ultralite box. Also, if I listen to what I get on one of the outputs, I hear what I is in the wav file that I have attached. Not what you'd expect from a SinOsc with gain 0.1, eh? If I run this patch without --out4, I get the nice sine beeps that I expected.
Ah! And as I am writing this post, I think I've solved my problem. Very Happy Embarassed If I change --out4 to --out8 (which better matches the amount of audio outs on the ultralite --out10 doesn't work, so I guess that ChucK can't connect to the S/PDIF outputs), then it worked. It still outputs to all 8 extra outputs though, unless I specify a channel with lisa => dac.chan(0), which will send to only output 1.
OK, just to complete my survey on this, if I kept --out4 and started specifying which channel to use like this:
Code:
LiSa lisa => dac.chan(0);
then I got some weird modulo output selection, with audio on output 2 and 6. If I change to --out3 I get a horrible high-pitched sharp sound on channel 1, and the mangled beep on all channels 2-8.
So, I've worked around my problem, but there seems to be some kind of bug in there when it comes to using multiple outputs on my setup. To wrap up, here's what --probe says:
Code:
$ chuck --probe
[chuck]: found 4 device(s) ...
[chuck]: ------( chuck -- dac1 )---------------
[chuck]: device name = "Apple Inc.: Built-in Microphone"
[chuck]: probe [success] ...
[chuck]: # output channels = 0
[chuck]: # input channels  = 2
[chuck]: # duplex Channels = 0
[chuck]: default device = NO
[chuck]: natively supported data formats:
[chuck]:    8-bit int
[chuck]:   16-bit int
[chuck]:   24-bit int
[chuck]:   32-bit int
[chuck]:   32-bit float
[chuck]:   64-bit float
[chuck]: supported sample rates:
[chuck]:   44100 Hz
[chuck]:   48000 Hz
[chuck]:   96000 Hz
[chuck]:
[chuck]: ------( chuck -- dac2 )---------------
[chuck]: device name = "Apple Inc.: Built-in Input"
[chuck]:    8-bit int
[chuck]:   16-bit int
[chuck]:   24-bit int
[chuck]:   32-bit int
[chuck]:   44100 Hz
[chuck]:   48000 Hz
[chuck]:   96000 Hz
[chuck]:
[chuck]: ------( chuck -- dac3 )---------------
[chuck]: device name = "Apple Inc.: Built-in Output"
[chuck]: # output channels = 2
[chuck]: # input channels  = 0
[chuck]:    8-bit int
[chuck]:   16-bit int
[chuck]:   24-bit int
[chuck]:   32-bit int
[chuck]:   44100 Hz
[chuck]:   48000 Hz
[chuck]:   96000 Hz
[chuck]:
[chuck]: ------( chuck -- dac4 )---------------
[chuck]: device name = "MOTU: MOTU UltraLite"
[chuck]: # output channels = 14
[chuck]: # input channels  = 12
[chuck]: # duplex Channels = 12
[chuck]: default device = YES
[chuck]:    8-bit int
[chuck]:   16-bit int
[chuck]:   24-bit int
[chuck]:   32-bit int
[chuck]:   44100 Hz
[chuck]:   48000 Hz
[chuck]:   88200 Hz
[chuck]:   96000 Hz
[chuck]:
[chuck]: ------( chuck -- 3 MIDI inputs )------
[chuck]:     [0] : "MIDISPORT 2x2 Port A"
[chuck]:     [1] : "MIDISPORT 2x2 Port B"
[chuck]:     [2] : "UltraLite MIDI Port"
[chuck]:
[chuck]: ------( chuck -- 3 MIDI outputs )-----
[chuck]:
/Stefan
multiple_out_test.wav
Weird sound of SinOsc with gain 0.1
 Filename:  multiple_out_test.wav
 Filesize:  721.14 KB
 Downloaded:  387 Time(s)
JuneSolstice2013
