ENDIF
meir
Posted: Fri Sep 21, 2007 11:09 am Post subject:
i'm in for 4 to |
oldmanfury
Posted: Sun Sep 30, 2007 10:29 am Post subject:
Trade? |
I have a custom dual ADSR board with outputs that indicate when the D and R stages are activated that I'd be happy to trade for a PS3100 board.
The main circuit is from the ASM-1
http://home.swipnet.se/cfmd/synths/friends/stopp/asm1adsr.pdf
I had the board manufactured by futurlec - it's double sided (no screen-print or mask). Works great. The module was intended to be used for complex multiple stage envelopes. Add the two envelopes together, with one being triggered by for example the release stage of the other, and you get some interesting envelopes. I find that I use the two independently more frequently, or use one as a trigger delay generator. The LED's use CGS LED boards (not included on the main board.).
It's a great module, and you'd be the only other person on the planet with one.
-gerald
(jonesing for a PS3100 PCB)
logo64_AT_gmail_DOT_com |
loss1234
ericcoleridge
Posted: Wed Nov 28, 2007 4:57 pm Post subject:
I would like to see these printed again as well. |
crashlander42
Joined: Oct 21, 2006 Posts: 292 Location: Orlando, FL (US)
funkyfarm
Posted: Mon Feb 11, 2008 2:44 am Post subject:
funkyfarm wrote: | TRIPLE RESONANT FILTER MOTM-410 uses three VTL5C4/2 ; it's based on the same design, isn't it ? |
different CV circuitry, different LFO (more versatile). i don't know who original designed this OpAmp based VCBP. some members here will just know it, i bet. i could take a look at electronotes. AFAIK bernie hutchins investigated such things discussing filter designs.
Quote: | C4 ain't too fast ? some values have to be tweaked ? |
you aren't referring to C16 on my schematic?
different builders experienced different ratio of wet/dry signal. you could tweak this by changing R11.
if i did a 2nd run of PCBs i would place a resistor+trimmer there. the mix section would be just a single potentiometer followed by an OpAmp buffer (the remaining OpAmp could then be used for inverting one of the CVs). _________________
Tech Buddy at Random*Source |
funkyfarm
Posted: Mon Feb 11, 2008 3:03 am Post subject:
sorry, too hurry, i was refering to vactec vtl5C4...
(I put 15k instead of 10k for R11, "effect gain" resistor)
About separate outputs, buffers didn't seem to make any great difference here too...
I've put three outputs sockets, but I guess only one is useful (normalised type, a jack disconnecting one filter from the mixer section built around U3b) ; one filter on LEFT channel, the two others mixed then routed to RIGHT channel.
a la MAM RS3...
Now i'm looking for a simple envelope follower circuit that would do "some frequency separation at three ranges, "Low", "Mid", and "High", with a separate follower circuit at the output of each of these "channels".
http://www.midiwall.com/gear/rs3.html
Planned for spring 2008, maybe this should be a good start...
BUCHLA 194 |
loss1234
ericcoleridge
Posted: Mon Feb 11, 2008 9:52 am Post subject:
I agree with Loss, I hope this board is offered again. I don't know what I'm doing wrong, but I've press and peeled this one twise, and haven't been able to get it running yet. I am planning on using 3 or 4 filters in my modular, and I would like this to be one.
I'd love a manufactured PCB (in case you are taking note of interest in a new PCB run). |
pdman1
Joined: Mar 28, 2007 Posts: 50 Location: North Shore Massachusetts
Posted: Sat Feb 23, 2008 11:04 am Post subject:
2nd run?? |
yes I d also like to know if there will be a second run of PCBs.
Thanks |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1351 Location: Telford, PA USA
Posted: Sat Feb 23, 2008 11:40 am Post subject:
I too would be interested in buying one if a second run was made. |
Posted: Sun Feb 24, 2008 12:21 pm Post subject:
don't have much time these days 'cos we're moving. would a 2nd run of the first version do? otherwise we would have to wait with a 2nd run until april/may. opinions? _________________
Danno Gee Ray
Posted: Sun Feb 24, 2008 12:24 pm Post subject:
If that is the version shown on your website, and the one all these people are talking about, then it would do very well for me.
Are you refering to the one offered here on Em previously? That is the one I wanted. |
loss1234
Posted: Sun Feb 24, 2008 1:33 pm Post subject:
Danno Gee Ray wrote: | If that is the version shown on your website, and the one all these people are talking about, then it would do very well for me.
yes, the one offered here a year ago.
the thing is, i mentioned the possibility of an improved version with buffered output above. that would have required a new layout, breadboarding, prototyping and all that... _________________
Danno Gee Ray
Posted: Sun Feb 24, 2008 3:44 pm Post subject:
Iwould be glad to buy one like the ones already offered. If, in the future, you decided to sell an improved and updated version, I might well buy that as well. For now, I'd take what you could sell me. |
ericcoleridge
Posted: Mon Feb 25, 2008 12:40 am Post subject:
I'd prefer the version without LFO(I think that's the first version). But I'd definitely be interested in whichever is offered. |
Posted: Mon Feb 25, 2008 12:52 am Post subject:
ericcoleridge wrote: | I'd prefer the version without LFO(I think that's the first version). But I'd definitely be interested in whichever is offered. |
no problem at all. the 1st and only version offered here did provide the simple LFO, but it was independent from the actual resonators circuit.
i will change some footprints on the layout this week and then start a new thread for a possible 2nd run (evaluation). _________________
drapdap
Posted: Mon Feb 25, 2008 4:27 am Post subject:
fonik wrote: | i will change some footprints on the layout this week and then start a new thread for a possible 2nd run (evaluation). |
so this really is happening! nice one, Fonik!
i didn't really look into these yet, but lfo's one can quickly put together.
does it have cv control over what?
robert
ps: deffinitely count me in with 3 of these Hermann! |
loss1234
loss1234
Danno Gee Ray
Posted: Mon Feb 25, 2008 3:43 pm Post subject:
I'm in for one. |
