petery
Posted: Wed Feb 27, 2008 10:50 am Post subject:
Midi Recording Latency Subject description: Midi Recording Latency |
Hi Everyone,
When I try to record MIDI in real time in my Cubase SX for some reason recorded notes come out delayed by 16th or more... Is it some setting that I need to adjust or there is something wrong with my set up?
I remember I had that problem vith previouse versions of Cubase long time ago and it was just a setting somewhere... I just don't remember where..
Thanks,
Peter |
Low Note
Posted: Wed Feb 27, 2008 8:08 pm Post subject:
A little more info on your set up might help.
What hardware are you using. Do you know what latency you have set to?
Do you have any quantizing going on? You might need to adjust the length that it detects. |
petery
Posted: Wed Feb 27, 2008 8:45 pm Post subject:
I'm using MIDI Delta Midisport 2x2 for MIDI and Safire Pro for audio... Runing Cubase SX... I do not think I have any quantization going on at record time...
Where do I adjust the detection length?
Thanks,
Peter |
Low Note
Posted: Thu Feb 28, 2008 4:00 am Post subject:
I only have SL 3 and its on another computer, but its in the same dropdown menu as VST Instruments. Its called Device Options or Device Setup.
There may also be something to adjust in VST Connections with latency. |
Chrono
Audio files: 37
G2 patch files: 38
Posted: Mon Jul 07, 2008 2:38 pm Post subject:
i have the same issue , and different midi interfaces act differently .. like my saffire pro midi places all notes at position 0 after recording.. my edirol um-1 places the notes further ahead.. each time i restart cubase it places the notes on a different position. I've read something about the ignoreportfilter in the cubase folder, this gives you emulated drivers wich might work properly.. |
longfella
Posted: Sat Nov 29, 2008 4:28 pm Post subject:
hi |
could be worth swapping the asio drivers around, they all have there own strong and wek areas for various tasks thats why theres more than one on your menu it should tell you howmuch its effected your system latency |
ikarus
Posted: Sat Jan 14, 2012 4:43 am Post subject:
Re: Midi Recording Latency Subject description: Midi Recording Latency |
this is a well known bug due often to duplicate midi ports ( sx for some reason on some systems creates 2 x of each midi port it detects.....) there is also an issue of the system clock on sx i think ? i went to cubase 5 in the end and dont have these issues ( though i still think c5 is pretty shite as are most steinberg products now and 99% code protection and very unstable in many ways compared to logic but hey....i dont own a mac yet ) |
