rufuss sewell
Posted: Tue Feb 26, 2008 4:27 pm Post subject:
Unison X: Spread the PAN of voices? |
I'd love to be able to mod the pan of voices in Unison X. Basically assign the mod wheel to spread the pan of each voice further one way or the other so that at full up, each voice is spread completely across the stereo field. Voice 1 all the way LEFT, and voice 16 al the way RIGHT, with all the others equally between. I would then add a bit of detuning to make the entire sound completely huge.
Is this possible? |
soundwave106
Joined: Nov 24, 2004 Posts: 331 Location: Elmo's Mud Wrestling Club
Posted: Wed Feb 27, 2008 5:38 pm Post subject:
Not that I'm aware of, though one of the random functions can provide pan per voice pretty nicely. |
sunny pedaal
Joined: Nov 16, 2004 Posts: 735 Location: netherlands
Audio files: 12
Posted: Thu Feb 28, 2008 2:31 am Post subject:
with an external mixer and using single voice outputs it will. |
ThreeFingersOfLove
Posted: Sun Mar 02, 2008 5:54 am Post subject:
Quote: | with an external mixer and using single voice outputs it will. |
Not really: if you use the voice outputs, then the configuration is this:
Output 1: voices 1 and 2
Output 2: voices 3 and 4
Output 8: voices 15 and 16
So if you have say a 6 voice unison lead, and provided you have assigned voices 1-6 for that sound, it will come out from the voice outputs 1, 2 and 3. How will you pan voices 1 and 2 since they appear in a single output? Maybe, by using an external mixer (like I do and like you said) you can pan voices 1-2 hard left, 3-4 center and 5-6 hard-right. I don't see how random panning could help here, since this modulation exists per patch. I don't think individual voice panning is actually possible.
On the other hand, there is a workaround: You can make a certain patch and give it a certain pan, then copy this patch to another location and give it a different pan (you can always try different tunings to emulate Unison-X or any other stuff). YOu can do as many as you like, up to 16 if they are monophonic. Then bring all these variations-patches into a mix, and voila you have individual panning per voice (a bit tricky to adjust, though)
sunny pedaal
Audio files: 12
Posted: Mon Mar 03, 2008 5:53 am Post subject:
the outputs are individual, they are stereoplugs with tip is one voice and ring is the other . base is the common"earth". so nothing against a mixer with 16 in 2 out. |
ThreeFingersOfLove
Posted: Mon Mar 03, 2008 11:13 am Post subject:
You are right... what was I thinking anyway it is actually possible since what you say is true, I forgot that I actually have 8 voice outputs but 16 inputs on my mixer (and not eight). Thanks for pointing this one out. |
sunny pedaal
Audio files: 12
Posted: Mon Mar 03, 2008 2:30 pm Post subject:
maybe you could use the trackinggenerator and connect it to the panning,
or ( what i like ) assigning notenumber to pan. , to get the spreading over the keyboard from le to ri.
or trigger( up =le) the lfo-squarewave and retrigger|(down= ri) it while assigning it to the panning. |
