150pi
Posted: Wed Jan 30, 2008 10:32 am Post subject:
Please help. Seq in G2 |
Greetings friends!!!
Forgive please for my bad English
Please Help to design a sequencer, and that at me does not turn out in any way. I tried to do(make) as is specified in a manual on page 231, figure 2, but it at all that that is necessary. Notes enter the name without duration and velocity.
That was approximately clearly what to me the sequencer is necessary look this video.
http://www.laboitenoiredumusicien.com/boite/bonusmedia.php?boite=4&id=1222&choix_marque=273&categorie=produits&fam=
As interests record of chords, and not just single notes. Whether it is possible?
Who is thankful in advance to all will respond. |
Audio files: 278
Posted: Wed Jan 30, 2008 3:23 pm Post subject:
When I read you right This may interest you. _________________ Jan
150pi
Posted: Wed Jan 30, 2008 5:26 pm Post subject:
YES YES YES!!! the patch "polyquenzer_a1_114" - That that is necessary! Thanks! |
150pi
Posted: Thu Feb 28, 2008 4:19 am Post subject:
Friends....in the previous post im miss...but this SEQ its not what i wanted...please help me construct the SEQ with record and playback notes so as to he observe with velocities and duration
SEQ which you advise quantize notes by record not exactly
Please help!!! I can not work without him!!!!!! |
Joined: Apr 01, 2004 Posts: 2669 Location: Auckland, New Zealand
G2 patch files: 626
Posted: Thu Feb 28, 2008 1:17 pm Post subject:
150pi wrote: | Friends....in the previous post im miss...but this SEQ its not what i wanted...please help me construct the SEQ with record and playback notes so as to he observe with velocities and duration
What you want is a midi recorder/player that records polyphonic midi stream with note number, note velocity, note start time, note length. It would be nice to have such a module in the G2 but there is none at the moment. It might be possible to patch a monophonic version but I think that would be pushing the limits of what is practical.
I have considered making a G2ool python utility that could take shortish, single channel midi files and convert them to a G2 sequencer player patch. Using all a variations, I might be able to get 16 or 32 bars with reasonable time resolution.
Unfortunately my G2 is gathering dust while I wait for a Vista USB driver from Clavia :¬( |
150pi
Posted: Thu Feb 28, 2008 2:22 pm Post subject:
Quote: | Unfortunately my G2 is gathering dust while I wait for a Vista USB driver from Clavia :¬( |
It is awful!!!!!
Quote: | What you want is a midi recorder/player that records polyphonic midi stream with note number, note velocity, note start time, note length. It would be nice to have such a module in the G2 but there is none at the moment. It might be possible to patch a monophonic version but I think that would be pushing the limits of what is practical. |
SEQ in this link http://electro-music.com/forum/post-91621.html#91621
Approaches but him very dificult and occupy many DSP resourses. And him quantize notes by record not exactly.
I think, there should be a simple way to build this MF SEQ |
150pi
Posted: Mon Mar 03, 2008 4:36 am Post subject:
Can I use a MIDI sequencer RS7000? Who tried to do something that? |
Fozzie
G2 patch files: 49
Posted: Mon Mar 03, 2008 4:50 am Post subject:
Ask Dasz, he uses the combination of G2+RS7000 and is very happy with it. _________________ Spinning at ~0.0000115740740741 Hz |
150pi
Posted: Mon Mar 03, 2008 9:12 am Post subject:
Thanks |
dasz
Audio files: 29
G2 patch files: 56
Posted: Mon Mar 03, 2008 10:03 am Post subject:
Dasz is indeed very happy with the Rs7000 + G2 combo.
The Rs7000 offers realtime, step and grid (a wonderful grid) modes of sequence recording. it can import standard midi files, wav and aiff. it's clock is so steady that it's silly, and it' bpm resolution is .1
Here is how I use the two together
RS7000
4 drum sequence tracks (G2 Drums in one slot + sampled drums in the rs7000)
2 synth tracks (one synth in a G2 - one slot, the other a waldorf xt)
3 sample tracks (all samples in the rs7000)
THe RS7000 does beats and samples and synth lines which are the backbone of the set. The RS7000 then is used to mute and un-mute the tracks as needed, and I change patterns (basically changing from what one or more tracks are playing). the RS7000 is the master clock.
My 2nd G2 (and I'm not saying it is needed for you, I simply have 2) contains 4 self running interactive sequencer patches which I crossfade with the RS7000 (I mapped some of knobs in the RS7000 to send MIDI Messages). I switch between 2 prf's (or sets 4 patches).
I will at some point embed patch changes so the G2's and XT change to the right instrument (right now it is manual), and I will also record variation selection (maybe, as the variation changes is something I love to do live).
That's how it all works.
/Dasz |
jksuperstar
G2 patch files: 18
Posted: Mon Mar 03, 2008 11:17 am Post subject:
Dasz, I like the phone book spacers |
150pi
Posted: Mon Mar 03, 2008 2:42 pm Post subject:
Wow! Thank you very much for such a detailed response, but unfortunately, I need other information ....
Does no one really uses such sequencer?????????????????? |
dasz
Audio files: 29
G2 patch files: 56
Posted: Mon Mar 03, 2008 4:01 pm Post subject:
what info do you need? I can be specific.
There are other grid sequencers out there, the Korg Electribes are great, I hear.
The thing with the RS7000 is the fact has so many tracks, and each track can have as much midi data as you want (for example one track could be used as a grid of 128 rows (one per note). The RS came highly recommended from a good source (a veteran performer) and I'm glad I listened.
Mind you, the Rs7000 is not the easiest sequencer to get into. But it is not too bad of a learning curve, a good investment. I have seen a lot worse.
/Dasz Last edited by dasz on Mon Mar 03, 2008 4:06 pm; edited 1 time in total |
dasz
Audio files: 29
G2 patch files: 56
Posted: Mon Mar 03, 2008 4:03 pm Post subject:
jksuperstar wrote: | Dasz, I like the phone book spacers |
I have since modified my setup so the RS7000 sits to the left of the Mackie. It is more ergonomic. |
150pi
Posted: Mon Mar 03, 2008 7:19 pm Post subject:
Ok. To clear all RS7000
How to account for a polyphonic SEQ with record to G2? Not using such? |
jksuperstar
G2 patch files: 18
Posted: Mon Mar 03, 2008 10:31 pm Post subject:
I use a computer for recording midi sequences like that...Ableton Live in particular. There are many sequencing programs that will do what you ask, and a WHOLE lot more.
Hardware, you can get a simple Yamaha QY-70 (simple patterns, or long complex songs), Or the Korg Electribes for more pattern based. The RS7000 was always on my list, but the computer has since taken over. An Akai MPC1000 (or any MPC) will also do.
But for doing that type of recording *in* the Nord, well, that's just a bit limited in a modular system. And there are already tons of tools available to do it. So I have to qualms about it not being in there. It's not really a workstation, in the typical sense like the Roland and Korg workstations are, which is where you'd find features like that. |
150pi
Posted: Tue Mar 04, 2008 6:25 am Post subject:
Quote: | I use a computer for recording midi sequences like that...Ableton Live in particular. There are many sequencing programs that will do what you ask, and a WHOLE lot more. |
Unfortunately, I do not use a computer in the process of creating music.
Disagree. Watch the video, in the first post
(http://www.laboitenoiredumusicien.com/boite/bonusmedia.php?boite=4&id=1222&choix_marque=273&categorie=produits&fam =) |
Fozzie
G2 patch files: 49
Posted: Tue Mar 04, 2008 7:21 am Post subject:
150pi wrote: |
150pi, jksuperstar did not say it is impossible on the G2, just that there are workstations out there that have these functions built in and ready to go, so if it is important to you, you might want to use one of those synths.
With regard to the video you have linked to, why not send a personal message (PM) to the guy in the video and ask him for details or to share the patch (you never know)? He is member "xav" here on the forum.
Edit: wait, he already posted it here!!!!!! http://electro-music.com/forum/download.php?id=8811 _________________ Spinning at ~0.0000115740740741 Hz |
G2 patch files: 626
Posted: Tue Mar 04, 2008 12:03 pm Post subject:
This patch uses an audio looper. It does not record midi or use sequencers, the note data must be 'played in' each time you load the patch. Sorry for not realising that is what you were after.
There are quite a few looper patches posted here, check them out |
