 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
ChucKing on the Net
Page 1 of 1 [3 Posts]
Inventor
Audio files: 50
PostPosted: Tue Mar 11, 2008 2:44 am    Post subject: ChucKing on the Net
Subject description: netout and netin ugens
Browsing around the documentation pages, I found netout and netin. They have no links to them from the ugens page, but if you go to LiSa then scroll down you will find them. Might we set up a ChucK jamming session by ChucKing up a simple network file? What about the settings, how can we do this properly, if at all?
Kassen
PostPosted: Tue Mar 11, 2008 3:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Also, we have facilities to connect to a external VM and send it commands. Should be in the OTF commands.
There are some security implications to that though. Ge&me talked about those a while ago and I would expect to see a update there.
Anyway, I think a lot more could be done there, maybe even with (mini) Audicle integration for realtime collaborative editing. One issue though is fire-walls.... I know I'm behind one....
while(!machine.crash() ) <<<"all is well">>>;
Inventor
Audio files: 50
PostPosted: Wed Mar 12, 2008 1:14 am    Post subject: Reply with quote  Mark this post and the followings unread
The firewall on my Mac allows me to specify individual ports to be opened and closed using the System Preferences. But that's not enough, we would have to know each other's IP addresses, plus set up separate transmits for every destination if I understand it right, and that's not good. Perhaps Ge has some way to mask that from the user somehow?
Once You Know, You Newegg
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
