 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
Happy New Year!
Thanks for a great live streaming floating concert and party.
 Forum index » Instruments and Equipment » MIDI Controllers and Interfaces
Arpeggiators!
Page 1 of 1 [8 Posts]
opg
PostPosted: Thu Mar 13, 2008 9:35 am    Post subject: Arpeggiators!
Subject description: and kind of related to my earlier post with the Siel DK600 MIDI issue
It would be awesome to have a software or hardware device (cheap - I'm on a tight budget here) to send arpeggiated MIDI data to my Siel DK600. I use Fruity Loops, and I always felt its arpeggiator function was lame. You can only choose octaves and chords for arpeggios, not the better way of inserting any notes into the pattern piano roll and arpeggiate those. Either I'm really missing something in Fruity Loops which I've used for at least 5 years now, or I have to choose from two other options:
1. (the preferred method) Find a cheap synth (or even an old casio keyboard like an MT-100) with MIDI output that I can send to the Siel.
2. Figure out why the arpeggiator VST plugins I've tried don't work at all. For those that are unfamiliar with Fruity Loops, there is a MIDI Out instrument that I use to send MIDI to the Siel, and this instrument does not obviously allow you to assign it to an effects channel. You can only use the built-in delay and arpeggiator functions on the Fruity instrument interfaces.
Any ideas? So far, the only thing that might be in my price range (eBay auction depending) is a Korg DW-8000, and I am only assuming that I'll be able to send MIDI from FL to the Korg and then to the Siel (but it is not totally necessary that FL be involved in this step).
One Player Game
Mohoyoho
PostPosted: Thu Mar 13, 2008 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Akai MPK49 keyboard controller has a built in arp with different patterns, swing and gate control, etc. I love mine. Otherwise any synth with arp out should work, like a used Micron.
Mark Mahoney
Kingsport, Tennessee
http://electro-music.com/catalog/product_info.php?products_id=54
opg
PostPosted: Thu Mar 13, 2008 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yikes! Pricey! I keep an I out for the Korg DW 8000s, then.
Any advice on the setup of those damn VST arpeggiator plugins?
One Player Game
deknow
PostPosted: Thu Mar 13, 2008 3:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
the microkorg arpeggiator is worth looking at. you can adjust the number of steps (up to 16), and have it skip steps....it really is fun to play with. if the siel can deal with velocity...well, each key you put down on the arp plays with it's own velocity. can easily find one for $300 used.
deknow
opg
PostPosted: Fri Mar 14, 2008 7:42 am    Post subject: Reply with quote  Mark this post and the followings unread
But I am correct in assuming that sending MIDI out in Fruity Loops on a channel of my choice to the synth with the arpeggiator set the way I want it and then MIDI out to the Siel will actually work? Confused
One Player Game
CJ Miller
PostPosted: Sat Apr 12, 2008 9:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
I "use" an Oberheim Cyclone, though it is *anything* but user-friendly. I go a year without it and completely forget how it works and need to spend a few days learning it all over again. Great fun to experiment with.
yosies
PostPosted: Sun Oct 26, 2008 10:48 pm    Post subject:  MIDI Arpeggiator. Reply with quote  Mark this post and the followings unread
There are some kinds of MIDI Arpeggiator.
http://synarp.suppa.jp/7365/
andrewF
PostPosted: Mon Oct 27, 2008 5:43 am    Post subject: Reply with quote  Mark this post and the followings unread
roland SH-32
around $150used
lots of functions, vicious (REALLY nasty) filter and great arpeg
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
