No sound from ChucK on Ubuntu Gutsy Gibbon
Page 1 of 1 [14 Posts]
ilSignorCarlo
PostPosted: Mon Mar 17, 2008 8:48 am    Post subject: No sound from ChucK on Ubuntu Gutsy Gibbon Reply with quote  Mark this post and the followings unread
I installed ChucK on Ubuntu Gutsy Gibbon, and it seems to work. I mean, I can run the example files, but I can't hear any sound (and yes, I have speakers turned on Razz )
On the mailing list someone told me to try the command chuck --probe, and I get this
Code:
[chuck]: found 5 device(s) ...
[chuck]: ------( chuck -- dac1 )---------------
[chuck]: device name = "hw:I82801DBICH4,0"
[chuck]: probe [success] ...
[chuck]: # output channels = 0
[chuck]: # input channels  = 2
[chuck]: # duplex Channels = 0
[chuck]: default device = YES
[chuck]: natively supported data formats:
[chuck]:   16-bit int
[chuck]: supported sample rates:
[chuck]:   8000 Hz
[chuck]:   9600 Hz
[chuck]:   11025 Hz
[chuck]:   16000 Hz
[chuck]:   22050 Hz
[chuck]:   32000 Hz
[chuck]:   44100 Hz
[chuck]:   48000 Hz
[chuck]:
[chuck]: ------( chuck -- dac2 )---------------
[chuck]: device name = "hw:I82801DBICH4,1"
[chuck]: default device = NO
[chuck]:   16-bit int
[chuck]:   48000 Hz
But I don't know what to do with all this stuff.
Any suggestion?
Thanks.
PostPosted: Mon Mar 17, 2008 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Really weird.
Let's check something really basic. Does this perhaps give a sound?
Code:
SinOsc s => dac;
5::minute => now;
Just trying to rule factors out.
while(!machine.crash() ) <<<"all is well">>>;
ilSignorCarlo
PostPosted: Mon Mar 17, 2008 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Kassen wrote:
Really weird.
Code:
SinOsc s => dac;
5::minute => now;
No :\
No sound.
I have already tried many example files, such as larry.ck, curly.ck and so on.
PostPosted: Mon Mar 17, 2008 11:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, Hmmm, just noticed your --probe report doesn't list any outputs. are you able to get sound from another program that does use the same soundsystem/drivers?
ilSignorCarlo
PostPosted: Mon Mar 17, 2008 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
In the last part of the --probe I have this:
Code:
[chuck]: ------( chuck -- dac5 )---------------
[chuck]: device name = "hw:I82801DBICH4,4"
[chuck]: # output channels = 2
[chuck]: # input channels  = 0
[chuck]:   16-bit int
[chuck]:   48000 Hz
Here it seems I have output. But how can I change these devices?
And, well, I am able to get sound from other applications. I mean, I can play mp3s, I can watch videos and all the other things.
PostPosted: Mon Mar 17, 2008 5:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
chuck --loop --dac5 my_file.ck
Frostburn
PostPosted: Tue Mar 18, 2008 12:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you sure you're not running any other sound programs that could mess up with the connection to chuck? If you're running JACK (recommended) make sure that the samplerates are compatible. Chuck has a default srate of 48000.
To boldly go where no man has bothered to go before.
kijjaz
PostPosted: Tue Mar 18, 2008 12:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Usually, if i'm using an onboard soundcard, it'd be the first dac listed in the probe.
but it depends .. anyway.
That output = 0 i see in the first probe here is like when i have another programming using the soundcard
(for example, a web browser!)
so usually, i try to exit all the programs before probing.
Another question:
are you using ChucK from the debian repository or compile chuck on Ubuntu?
i guess that one you're using is chuck compiled for ALSA support.
ilSignorCarlo
PostPosted: Tue Mar 18, 2008 2:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, there was a paused video in the browser window.
So... shall I close everything, or does exist some setting to play both things?
I'm using chuck compiled for ALSA. Which one is better?
Why is it recommended whit JACK?
This doesn't work anyway.
kijjaz
PostPosted: Tue Mar 18, 2008 7:06 am    Post subject: Reply with quote  Mark this post and the followings unread
1. Ok, there was a paused video in the browser window.
kijjaz: a paused video? that'd be the case. so closing the browser (maybe the whole browser, not just that window) to let the soundcard be available.
some setting to play both things? hmm eh i'm not sure about the new tools like PulseAudio. I'll go into that someday.
But!! .. If you're working with Jack .. That would allow playing from multiple softwares in its natural way.
(only if the softwares support jack.. I think a usual web browser doesn't support jack)
2. I'm using chuck compiled for ALSA. Which one is better?
kijjaz: Actually, I recommend having both ALSA and JACK version ready.
i usually compile for ALSA and put the result in /usr/bin
and compile for JACK and add -jack to the file name and also put in /usr/bin
so I can select between the one I want to use.
3. Why is it recommended whit JACK?
With also, chuck/miniAudicle works fine: producing audio, processing other kinds of things MIDI OSC etc..
but there're many good things with using with Jack here..
- If JACK runs smoothly, chuck/miniAudicle with jack support can run smoothly also..
- you can do more things by connecting Audio or MIDI between softwares that support Jack.
The second feature is what's very fun about using Jack with chuck..
coz you can do like.. redirecting audio signals.. (even feedback chuck's output into its input..)
record the result in another program (for example, Audacity, Rosegarden..)
do an analysis (for example, view in an oscilloscope, or see volumn meterbridge)
put through effects..
redirect MIDI between programs.. (also between USB MIDI Interfaces)
etc..
So it's gonna be more fun and you can worry less.
That depends on the latency and the stablility of your Jack running on your machine also.
Have you got a realtime kernel and tried running Jack with realtime yet?
If not, i'll try to collect all the information needed to install and config for that in Ubuntu Gutsy easily.
I'm usually on Ubuntu Gutsy and running realtime Jack on it also.
ilSignorCarlo
PostPosted: Tue Mar 18, 2008 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Great. I read this post and now it works with both alsa and JACK.
But this is the first time I really try using JACK.
Shall I always run it from shell with the command: jackd -d alsa ?
I did so and it worked, but, I don't know... are there other possibilities?
And what shall I use to connect inputs and outputs between other applications?
I haven't it yet... I think I'm going to install it.
kijjaz
PostPosted: Tue Mar 18, 2008 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
This is my recommendation for use in Ubuntu Gutsy:
1. install a realtime kernel.
by installing these packages (and some other packages i recommend having it ready for future use):
linut-image-rt linux-headers-rt linux-restricted-modules-rt linux-backports-modules-rt
If you don't need the hears, restricted modules, backports modules, you can just install the image.
2. enable realtime.
I recommend an easy way.. but it involves installing packages from UbuntuStudio:
install this: ubuntustudio-default-settings
This will help configure. It will also give normal users permission to use realtime .. so we'll be able to use jack with realtime.
3. install qjackctl. this is GUI for running jackd, so it'd be more convenient.
you can go into 'Setup' and set different things.
Select driver to use (for example, ALSA..) and select from different soundcards.
Some firewire audio interfaces are also supported by freebob. see http://freebob.sourceforge.net/forums.html/Main_Page
after getting the realtime-enabled kernel, done giving permission to use realtime, you can try qjackctl and set Realtime and see if it works.
Sometime it just does't work, I don't know why..
Changing some values might help.
Enjoy Jack & ChucK hehheheh.. ^_^
ilSignorCarlo
PostPosted: Wed Mar 19, 2008 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Everything works now, wow Very Happy
I still don't know about real-time, but I'll try something as soon as possibile.
Thanks a lot, bye.
Self-referential phrases, like this one, are not so funny or good for a forum signature.
kijjaz
PostPosted: Wed Mar 19, 2008 3:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Although you can't have the realtime feature yet,
it can normally run qiute smoothly on modern machines.
Enjoy using Jack!! hehheh.
I recommend looking into these nice softwares that support Jack also:
Audacity, hydrogen, jackeq, jack-rack, jamin, meterbridge, puredata, rosegarden.
There are also many more I still haven't tried out and couldn't comment.
Buy N Save
