UGens and parameters as arguments?
Page 1 of 1 [3 Posts]
wppk
PostPosted: Tue Mar 18, 2008 2:04 pm    Post subject: UGens and parameters as arguments? Reply with quote  Mark this post and the followings unread
I would like to use a UGen as an argument to a function.
I would like to be able to assign a different parameter of a different UGen every time I call the function.
When I try to run something like this then I get an error stating that "UGen has no member .freq".
what would be the best way to approach this?
like this, for instance:
Code:
fun void do_something (UGen u) {
          Std.rand2f( 100, 200) => u.freq;
//call function
while(true) {
      do_something( LPF );
100::ms => now;
Frostburn
PostPosted: Wed Mar 19, 2008 1:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I recommend creating a base class with the desired member functions and extending it. Then you can write functions that take the base class as an argument and do their thing to it.
Code:
//This is the base class
class MyOscillator{
        Gain out;
        //These are supposed to be overriden
        fun float freq(){
                return 0.0;
        fun float freq(float _freq){
                return _freq;
//Let's extend it:
class MySawtooth extends MyOscillator{
        BlitSaw blitsaw => out;
        //Override:
        fun float freq(){
                return blitsaw.freq();
                _freq => blitsaw.freq;
                0 => blitsaw.harmonics; //Calculate harmonics up to nyquist
class MyFilteredBlit extends MyOscillator{
        Blit blit => LPF lpf => out;
        //You can also set some basic parameters in the constructor
        4.0 => lpf.Q;
        //Even call the member functions
        220.0 => freq;
        //Override:
        fun float freq(){
                return blit.freq();
                _freq => blit.freq;
                3.0*_freq => lpf.freq;
                10 => blit.harmonics;
                return blit.freq();
//Here's our function using the base class
fun void do_something (MyOscillator mo) {
          Std.rand2f( 100, 200) => mo.freq;
//create an instance:
MyFilteredBlit myOsc;
//MySawtooth myOsc; //You can try this one too
myOsc.out => dac; //connect it
//call function
while(true) {
      do_something( myOsc );
      500::ms => now;
As an added bonus you'll be able to make neat packages out of your patches and you're not limited to chucks native ugens.
To boldly go where no man has bothered to go before.
wppk
PostPosted: Thu Mar 20, 2008 9:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey thanks Frostburn. Now i'm cruisin' right along.
