 Forum index » Clavia Nord Modular » G2 Performances - Noodles
Ode To Once
Page 1 of 1 [17 Posts]
Audio files: 107
PostPosted: Thu Jul 27, 2006 11:30 am    Post subject: Ode To Once
Subject description: a rather simple noodle
Here's something I was fooling around with. It's called Ode To Once WRT to The Once Festivals.
My work is really just slot A. I put three factory patches in Slots B-D for the voices. Feel free to change the voices in those slots to make different trios. Peter Schickele did a program on trios once. He said it was the most common form. Almost everything I write is a trio. I discovered that when I bought my first 8 track recorder and realized I didn't need all those tracks.
Solt A has three note generators that use seveal LFO-A modules to generate the notes, velocity and the varations. By changing the waveforms of the LFOs you can different sounding music. Use square waves for the note times and you'll get much more beat oriented sounds.
This performance has a defect. Sometimes the variations will change when there is a note playing and this generates a click or pop. I like this actually. It gives the feeling of listenting to a vintage recording - but it doesn't have all of the crappy sound. Maybe that's a rationalization. I didn't want to edit any of the voice patches because that would miss the point of using factory presets.
At any rate, this reflects the mood I'm in at the moment.
Enjoy...
Ode To Once.prf2
Ode To Once
A noodle for factory patches. Intended for alteration by others.
 Filename:  Ode To Once.prf2
 Filesize:  9.28 KB
 Downloaded:  1126 Time(s)
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Thu Jul 27, 2006 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Beautiful music.
Audio files: 116
G2 patch files: 317
PostPosted: Thu Jul 27, 2006 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Modified it a bit, probably not as intended Very Happy
bh_ode2_1ce.prf2
A mod on Howard's ode-to-once performance
 Filename:  bh_ode2_1ce.prf2
 Filesize:  10.12 KB
 Downloaded:  844 Time(s)
varice
G2 patch files: 46
PostPosted: Thu Jul 27, 2006 10:30 pm    Post subject: Re: Ode To Once
mosc wrote:
Enjoy...
And I do! I like this...
mosc wrote:
Sometimes the variations will change when there is a note playing and this generates a click or pop...
...or could this be caused by triggering a new note at the same time that the patch variation is being changed? I added a delay to the gate input of the Note Send modules to allow time for the patch variation changes to "settle" before a new note on is sent - this seems to reduce some (or most?) of the clicks and pops...
Ode To Once b.prf2
 Filename:  Ode To Once b.prf2
 Filesize:  9.44 KB
 Downloaded:  732 Time(s)
varice
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Thu Jul 27, 2006 10:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
g2ian wrote:
Beautiful music.
I agree. Very nice, thanks for this one mosc.
Ivity
G2 patch files: 57
PostPosted: Sat Jul 29, 2006 11:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great noodle! Very Happy
Igor
www.myspace.com/phoiod
www.bl-project.com/Ivity.html
Audio files: 107
PostPosted: Sun Jul 30, 2006 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks...
Here's another version. This time I'm using some of my own patches.
The slot A part is much improved now.
I've added an 8 bit back/forth sequencer that is switch selectable with a oscillator. There is a random trigger module to thin the clocks if desired. You can now use the master clock for any or all of the note engines, so you can sync the slots - boring but good to do in beat oriented stuff.
Most importantly, the controls are assigned to the G2 knobs so you can adjust the parameters of slot A in real time, suitable for live performance. I like interactive noodles.
The variation changes can be made to be automatic or manual for any or all slots too.
I use 8 step sequencers because they are more easily controlled on the G2's 8 knobs. There are controls for manual up/down and automatic control.
This noodle makes some really amazing sounds if you give it a long time. The repeat cycle most probably is very long.
This is pretty music on the noisy side of life.
Ode To Thrice.prf2
Ode to Thrice
An improvement over Ode to Once.
This is an interactive noodle where the note generator peramaters are brought out to the G2s knobs for real time control.
 Filename:  Ode To Thrice.prf2
 Filesize:  16.67 KB
 Downloaded:  1100 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Sun Jul 30, 2006 5:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Aah ! now we're talking Exclamation This will be on for quite a while Very Happy
cebec
G2 patch files: 31
PostPosted: Wed Aug 02, 2006 8:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is great, good range of sounds. I'm not seeing any of the knobs assigned for some reason.
Audio files: 107
PostPosted: Thu Aug 03, 2006 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Only the last one I posted has knobs assigned.
Audio files: 107
PostPosted: Mon Dec 31, 2007 12:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Getting ready for the noodle radio I see that there are a couple of versions of this that haven't been posted. Here they are:
Ode To Twice.prf2
A variation of Ode to Once - a noodle of type 12
 Filename:  Ode To Twice.prf2
 Filesize:  9.69 KB
 Downloaded:  976 Time(s)
Ode to Forth.prf2
Ode to Forth - a variation of Ode to Thrice - a noodle of type 12b
 Filename:  Ode to Forth.prf2
 Filesize:  12.22 KB
 Downloaded:  924 Time(s)
sourcecode
PostPosted: Wed Mar 12, 2008 6:24 am    Post subject: My Noodles
Subject description: Pick your own flavour
Noodles
edited by v-un-v;
contained an embedded rover link (link removed) which led to ebay site about 'pot noodles' (OT). Very funny mate, however we have you rumbled! Twisted Evil
sourcecode
PostPosted: Tue Mar 18, 2008 3:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Your dry, po-faced thread needed livening up! Very Happy
You can hardly whinge about the rover link when you use affiliate links yourselves. Rolling Eyes
Oh no! I've dared to be controversial. Shocked Shocked
No doubt big brother will drag me off to room 101.. (Checks private messages... yup, there it is: "This is how it will be"... blah blah, from elektro80.. anyone else want to have a go? BlueHell, maybe?)
Go on then, ban me for daring to post messages with pictures in them, having a large sig, not wearing a beard, OR sandals.
I'd rather have that than become one of your conformist drones.
PostPosted: Tue Mar 18, 2008 3:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, no, no, no- we don't 'ban' people round here, we may ask them to 'go away' (from time to time, but that is is under exceptional circumstances), but most of the time we just expect them (you, and your like) to behave yourselves. Wink
Now go buy yourself a Nord Modular G2, and join in the 'noodle' discussions. There's a good chap Very Happy
Mosc or Jan (or whoever has a G2), would you mind awfully loading up this thread's G2 patch as an mp3 so myself and Mr Sourcecode can enjoy this delightful noodle? Cheers Smile
ACHTUNG!
Audio files: 116
G2 patch files: 317
PostPosted: Tue Mar 18, 2008 5:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://bluehell.electro-music.com/em/music/2008/oto-col-002.mp3
Ode to once twice ... a 15 min (21 MB) collage of the patches posted above. I took some liberties in sound treatment.
PostPosted: Tue Mar 18, 2008 5:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow Jan! That's awesome!!
I gotta get me a G2 sometime soon Cool
ACHTUNG!
Audio files: 116
G2 patch files: 317
PostPosted: Tue Mar 18, 2008 5:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank Howard Laughing
And yes, you should have a G2.
