 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
Receiving more than one integer or float at once using OSC..
Page 1 of 1 [6 Posts]
Dr. Spankenstein
PostPosted: Fri Mar 28, 2008 6:37 pm    Post subject: Receiving more than one integer or float at once using OSC.. Reply with quote  Mark this post and the followings unread
I was thinking, rather than sending a whole load of data on various different ports via OSC at the same time wouldn't it be safer to collect the numerical data in a list and then send that via one port as a long OSC message to ChucK?
If it is better than the lost of one variable messages at a time on different port method, how would I go about retreiving the information from a list?
Code:
OscRecv recv;
6448 => recv.port;
recv.listen();
recv.event("/a, i i i i i i i i i" ) @=> OscEvent oe;
while( true )
    oe => now;
    while( oe.nextMsg() )
           int i;
       oe.getInt() => i;
           <<< "got (via OSC):", i>>>;
For example my code above has nine possible integers but I am unsure how to get all the data into separate variables in ChucK?
I'm assuming this is a better road to go down as I have a lot of data to pass to ChucK very quickly and unless I have a latency of around 10ms then ChucK crashes when it comes to receiving the data, even though it is told to wait on the incoming data before progressing.
I hope that made sense,
Rhys
Inventor
Audio files: 37
PostPosted: Fri Mar 28, 2008 7:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Does this recent post help?
http://electro-music.com/forum/topic-25052.html
Sorry, but I don't know much about this...
@(ºoº)@ ><}}}º> ~(^.^) <:3 )~
soundcyst
PostPosted: Sat Mar 29, 2008 2:08 pm    Post subject: Re: Receiving more than one integer or float at once using O Reply with quote  Mark this post and the followings unread
i think you can just keep piling up oe.getInt()s like this:
OscRecv recv;
6448 => recv.port;
recv.listen();
Code:
while( true )
    oe => now;
        int i[9];
        for (int j = 0; j<10> i[j];
            <<< "got (via OSC):", i[j]>>>;
i know that when i code for the monome, we do this to get all 3 button press values.
Code:
while ( oe.nextMsg() != 0 )
      oe.getInt() => x;
      oe.getInt() => y;
      oe.getInt() => state;
      //etc...
soundcyst
PostPosted: Sat Mar 29, 2008 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
i have no idea why the code parameter isn't working
it's supposed to be a for loop
Code:
for (int j = 0; j [less than] 10; j++ ) {
    oe.getInt() => i[j];
    ///your printing stuff
sanch
PostPosted: Sat Mar 29, 2008 8:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
For me the array size is dynamic that way :
The technic with to create the string type create a memory leak...
the code should works
actually i would like to make it all dynamic and inside a class , but it´s more complicate than i thought for a newbie like me.
Code:
50 => int max; //max array size
float data[max];
 //array to store data from v4
"f" => string type;//"f" => string type;
"localhost" => string hostName;//"localhost" => string hostName;
8050 =>int receiverPort; //6574 => int receiverPort;
"" => string ftype;
"" => string save;
for(0 => int i ; i < max ; i++){  //generate type string
if (i == 0)type  => save;
else ","+ type  => save;
ftype + save => ftype;
<<<ftype>>>;
OscRecv receiver;// objet OSC pour la réception
receiverPort => receiver.port;// commencer l'écoute sur le port
receiver.listen();// créer une adresse réceptrice des messages, y stocker la valeur de fréquence reçue
receiver.event( "/1" ,ftype ) @=> OscEvent oe;
fun  float[] oeListener() {
      oe => now;                   // en attente de l'arrivée d'un message OSC
      while ( oe.nextMsg() != 0 )  // capturer les nouveaux messages
     <<< oe.getFloat() @=> data[i]>>>;
      return data;
while (true) {
      oeListener() @=>  data;
     for(0 => int i; i < max ; i++) <<<data[i]>>>;
[/quote]
Dr. Spankenstein
PostPosted: Sun Mar 30, 2008 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I've gone for the one message at a time method for the time being, as time isn't something I have a lot of now.
However I discovered the problem I was having with OSC is that I shouldn't try and send loads of data of separate ports. Sending it all over one port works perfectly though without crashing ChucK!
Rhys
Music123.com - Customer Appreciation Sale Extended! - Save Up To $80 Off Your Order - Sale Ends Soon!
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
