granular synthesis methods for ChucK
Page 4 of 4 [82 Posts]
kijjaz
PostPosted: Mon Mar 31, 2008 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, please don't change the name.
yours's one good tape machine.
i just wanted to practice and try to make another version work, maybe different but work.
hahahahha. thanks.
I'll work on the fixes soon.
kijjaz
PostPosted: Mon Mar 31, 2008 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
This one sounds / looks more like it.
kijjaz-DigitalTape01-0.2.ck
 Filename:  kijjaz-DigitalTape01-0.2.ck
 Filesize:  4.56 KB
 Downloaded:  30 Time(s)
Inventor
Audio files: 67
PostPosted: Mon Mar 31, 2008 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
This one was quite good also.
For those about to ChucK, we salute you! - Ge Wang
Let's make noise for peace! - kijjaz
kijjaz
PostPosted: Mon Mar 31, 2008 10:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you guys for trying my little toy out. here comes verysion 0.4 alpha for more testing pleasure.
I've adjust a little bit, try to make it more simple..
and the result is surprisingly better.
kijjaz-DigitalTape01-0.4.ck
kijjaz's digital tape 0.4 alpha
 Filename:  kijjaz-DigitalTape01-0.4.ck
 Filesize:  4.6 KB
 Downloaded:  24 Time(s)
kjzdt04-01.mp3
a result from the above code
 Filename:  kjzdt04-01.mp3
 Filesize:  139.15 KB
 Downloaded:  76 Time(s)
Inventor
Audio files: 67
PostPosted: Tue Apr 01, 2008 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
It's not quite as good as the previous two of yours, IMHO, but it's still pretty good. I'm starting to think that this whole grains thing can easily be overdone. The mind needs something to grasp on, little fragments of voice or sound are necessary. If we chop it up too much it becomes unintelligible, which may be your desired effect, but usually not.
kijjaz
PostPosted: Tue Apr 01, 2008 5:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Hahahha i really like the old versions' result.. but one thing they produce are too much digital noises resulting in very high frequency noise. When I said 'better' here is that the copied signal looks more like a smooth sine wave. I intended to use the raw sine wave as the starting point because i want to test if it produce too much aliasing or noisy overtones out of original sine wave.
one thing the examples sounds very different because I change it all the time to test and see if there are still so much noise or not. when I'm satisfied, i posted the code hehehheh.
i'll implement more toys for it now ^_^. thank you guys.
Inventor
Audio files: 67
PostPosted: Tue Apr 01, 2008 11:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I tried to fix LiSa in Synth Lab to make a recording similar to what you two are doing, and it went "sproing" like a jack-in-the-box! I coded that thing way wrong and now it's totally broken, so it's back to the drawing board for me. Shrug, it happens! Keep on ChucKin'...
