  bingsatellites Mostly Ambient
 Forum index » Clavia Nord Modular » G2 Patches - Completed » FX
bounce
Page 1 of 1 [8 Posts]
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Mon May 10, 2004 8:09 pm    Post subject: bounce Reply with quote  Mark this post and the followings unread
Here is a Nord G2 variation on the Bouncing Ball effect discussed elsewhere. It does not use samples because us poor old G2 people have to synthesise everything from scratch (luckily, that's what I prefer to do anyway).
Basically, an incoming trigger from the keyboard kicks off a series of triggers, which also clock a binary counter/DAC combination, which is used to shorten the time between triggers. When the time 'decays' to shorter that the Min_ms pulse time, the triggering stops.
OK it's a little silly but fun to play.
BTW Howard, how do I put images in the body of the message?
 Filesize:  43.1 KB
 Viewed:  4678 Time(s)
bounce.pch2
bouncing ball patch
 Filename:  bounce.pch2
 Filesize:  1.92 KB
 Downloaded:  1287 Time(s)
Audio files: 107
PostPosted: Mon May 10, 2004 8:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool...
To put images in the body of a message the image must be uploaded to a web site. Then, just type in the URL of the image and use the IMG, LEFT, or RIGHT tags.
If you don't have a web site to upload images to, then you are stuck with doing what you did, attach the image with the attachment mechanism.
AngusHastie
PostPosted: Thu Aug 12, 2004 7:50 am    Post subject: bounce Reply with quote  Mark this post and the followings unread
How do the BinCounter and DAConv modules work? The manual is not much use to the uninitiated. I can probably work out the rest if I understand how these modules funtion.
Angus
Audio files: 107
PostPosted: Thu Aug 12, 2004 8:43 am    Post subject: Reply with quote  Mark this post and the followings unread
The binary counter is an emulation of a logic circuit. It counts in binary arithmetic. There is a bit for each binary "digit". Hook up an LFO to one and watch the lights (set the LFO at a slow frequency). You'll see an interesting side effect - each output is running at 1/2 the frequency of the previous one.
The DAC, digital to analog converter, takes in 8 inputs and puts out a singal that corresponds to the binary number of the inputs. If you put in the output of a binary counter, then the output of the DAC would be a ramp.
Kraken
PostPosted: Thu Aug 12, 2004 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Salud!
Great info and great effect, thanks a lot. This G2 thing sometimes gets really eldritch.
AngusHastie
PostPosted: Thu Aug 12, 2004 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
What's edlritch?
Kraken
PostPosted: Thu Aug 12, 2004 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Salud!
eldritch (adj.) spooky, unearthly, weird
cristian
PostPosted: Fri Aug 13, 2004 7:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Eldritch is a cool word.
Whats the Spanish equivalent? Inquieto?
www.no-future.com
