 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
Moving Buttons in MAUI
Page 1 of 1 [5 Posts]
Inventor
Audio files: 50
PostPosted: Mon Mar 24, 2008 3:22 am    Post subject: Moving Buttons in MAUI
Subject description: You can move buttons around with the mouse!
Folks, I got the idea today that it would be cool if we could move MAUI buttons around within their view panels with the mouse, so I gave it a try. It seems to work pretty well except it makes some little ghosts of the button. I did it by simply updating the button position and re-calling the view's .addElement () method. This could be a useful addition to our user interface options with MAUI. Anyway, it was an interesting little experiment. Code attached.
Mouse_MAUI1.ck
Test experiment of moving a MAUI button around within it's view panel using the mouse.
 Filename:  Mouse_MAUI1.ck
 Filesize:  2.23 KB
 Downloaded:  18 Time(s)
Inventor
Audio files: 50
PostPosted: Mon Mar 24, 2008 3:33 am    Post subject: Reply with quote  Mark this post and the followings unread
This version works a little bit better, so try this one instead of the previous one.
Mouse_MAUI2.ck
Slightly improved version of experiment moving MAUI buttons with the mouse.
 Filename:  Mouse_MAUI2.ck
 Filesize:  2.42 KB
 Downloaded:  16 Time(s)
Inventor
Audio files: 50
PostPosted: Tue Mar 25, 2008 3:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I added sound to it; the amplitude and freqency of a sinusoid are now controlled by the moving mouse button. You hear ghostly woo-woo sounds as you move the mouse.
Mouse_MAUI3.ck
Mouse MAUI: now with sound!
 Filename:  Mouse_MAUI3.ck
 Filesize:  2.66 KB
 Downloaded:  12 Time(s)
Inventor
Audio files: 50
PostPosted: Tue Mar 25, 2008 12:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I took the hint from Kassen on the ChucK-Users mailing list, and expanded the program to be a Pong game. Actually it's more like Breakout because the paddle is at the bottom of the window.
If you hit the moving button with the paddle, you get a point when it reaches the top. If you miss the moving button, the ball travels off the window and ChucK gets a point.
It still has the ghostly sound that is a function of ball position, plus I added a click for each bounce and a whoop-whoop-whoop when ChucK scores.
Ah, Pong, what a trip down memory lane!
MAUI Pong screenshot, how cool is that?
 Filesize:  16.82 KB
 Viewed:  499 Time(s)
Pong1.ck
MAUI Pong source code, it's ChucK gone mad!
 Filename:  Pong1.ck
 Filesize:  5.45 KB
 Downloaded:  15 Time(s)
Inventor
Audio files: 50
PostPosted: Tue Apr 01, 2008 12:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I've improved the Pong game a bit. The ball is now an LED that changes color each time it bounces. The screen is taller and narrower for that multi-bounce effect. And most notably the game gets more difficult as time goes on. The paddle gets smaller and the ball gets faster. Fun, fun, fun!
Pong2.ck
New better MAUI Pong - get it now!
 Filename:  Pong2.ck
 Filesize:  6.4 KB
@(ºoº)@ ><}}}º> ~(^.^) <:3 )~
Once You Know, You Newegg
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
