Posted: Sun Apr 06, 2008 5:42 pm Post subject:
48 khz ? |
Pierre, I do have a question. I´m still digesting your PDF, but one thing caught my eye early on.
You have digital ins and outs here.. at 48khz 24 bit. The samplesize of 24 is excellent! Great! But why 48khz? These days I know of none who are using 48khz gear anymore. DAT is essentially dead and most people will at all cost try to prevent having to apply SRC. I see one device has 192 khz. Hmm.. OK.. there are projects that just might require that samplerate, but most people will want to work with 44.1 khz, 88.2 or 176.4.
Is there any specific reason why you have chosen 48khz ? _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
cbm
Joined: Oct 25, 2005 Posts: 381 Location: San Francisco
Posted: Sun Apr 06, 2008 7:38 pm Post subject:
Re: 48 khz ? |
elektro80 wrote: | Is there any specific reason why you have chosen 48khz ? |
I've been required to deliver stuff in 48 KHz for soundtrack work, fwiw
–C
_________________ Chris Muir
http://www.eardrill.com <– My jobby (more than a hobby, less than a job) |
DrJustice
Joined: Sep 13, 2004 Posts: 2114 Location: Morokulien
Posted: Sun Apr 06, 2008 8:35 pm Post subject:
Would it be possible to offer a user selectable sample rate of 48 or 44.1 kHz for the IO? In which case I suppose the internal sample rate would be changed correspondingly (from 96/192 to to 88.2/176.4 kHz).
DJ
pguilmette
Posted: Sun Apr 06, 2008 9:09 pm Post subject:
48 Khz Subject description: 48 +khz |
Hi E80
In technical data we indicated 48 Khz standard, ... and 96 .. 192 khz at option in writing the brochure (this is a preliminary informations). My point of view is that would probably not make sense to have option on it and have at least 192 khz as standard - this is also question to consider different elements as standard (not decided yet) propably 6 outputs standards, we have actually some thought about this.
Also the ADC - DAC can be downsampled |
pguilmette
Posted: Sun Apr 06, 2008 9:12 pm Post subject:
and 44.1 khz multiple Subject description: sample rate |
... and support ofmultiples 44.1 khz is already incorporated in our current system |
Posted: Sun Apr 06, 2008 10:58 pm Post subject:
Re: and 44.1 khz multiple Subject description: sample rate |
pguilmette wrote: | ... and support ofmultiples 44.1 khz is already incorporated in our current system |
THX, I´m feeling much better now. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Sun Apr 06, 2008 10:59 pm Post subject:
Re: 48 khz ? |
cbm wrote: | elektro80 wrote: | Is there any specific reason why you have chosen 48khz ? |
–C
I guessed as much... _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
pguilmette
Posted: Tue Apr 08, 2008 8:21 am Post subject:
Sampling rate etc Subject description: tests |
In fact we made tests at higher non standard sampling rate and ultrasonic waves too, but my cat didn't liked it
If you look on the 2 websites the Acxel is the application, the RPP is the technology, and the RPP can handle other applications types, like video encoding-decoding for example. Then I would say the limitations are the ADC-DAC themselves, not the Acxel native Processor.
The current discussions (if you on the brochure (attached) we propose 3 Synthesis modes, but the native synthesis mode can handle various modes like Physical modeling, Vocoders, etc. and in combinations. The Acxel can integrate external instruments into sound structure, etc.
Eventually (not this year) Acxel structure (with one RPP or more) can be a studio environment...
Description: |
The Acxel II brochure (current version) |
Download |
Filename: |
Idarca_Acxel2-Brochure-01-6.pdf |
Filesize: |
574.14 KB |
Downloaded: |
964 Time(s) |
