Porkchop
Posted: Tue Apr 08, 2008 5:30 pm Post subject:
Max/MSP Trouble |
Hey, I'm building my own performance environment in Max/MSP, and I'm currently having trouble using effects.
Basically I'd like to use MSP effects like overdrive~ and cascade~ with a MIDI sequencer that I've built. I can't figure out how I can get the midi signals to work withthe MSP objects.
Does anyone know how to do this? Or even if it's possible?
Thanks in advance. Last edited by Porkchop on Tue Apr 08, 2008 7:10 pm; edited 1 time in total |
cbm
Joined: Oct 25, 2005 Posts: 381 Location: San Francisco
Posted: Tue Apr 08, 2008 6:19 pm Post subject:
First off, this message should probably be in the Max forum:
Forum index » Instruments and Equipment » MAX/MSP - PD
Second, what do you want your MIDI signals to control. It's pretty easy to use a MIDI controller to control overdrive amount or eq or other things like that. What specifically do you want to do?
-Chris _________________ Chris Muir
http://www.eardrill.com <– My jobby (more than a hobby, less than a job) |
Porkchop
Posted: Tue Apr 08, 2008 7:08 pm Post subject:
Ah ok sorry about that.
Ok, I should perhaps rephrase. I want the effects to be added to the midi sound- i.e. I have 3 multisliders giving the pitch, velocity and duration linked to a tempo object and a counter, thereby giving a basic sequencer. I would like the effects to be added to the final sound made my this sequencer. |
cbm
Posted: Tue Apr 08, 2008 9:22 pm Post subject:
Porkchop wrote: | Ah ok sorry about that.
So what is actually making the sound? The obvious possibilities include an external synthesizer, the operating system's DLS synthesizer, a VST, or generated with MSP?
-C _________________ Chris Muir
Porkchop
Posted: Tue Apr 08, 2008 10:15 pm Post subject:
It's the DLS. Sorry, shoulda said before, I'm kinda new at this :/ |
cbm
Posted: Tue Apr 08, 2008 10:27 pm Post subject:
Porkchop wrote: | It's the DLS. Sorry, shoulda said before, I'm kinda new at this :/ |
Unless you have some way to bring that audio back into Max, there's not much you can do. There is at least a reverb message to the DLS synth, that is documented in the Messages to Max chapter of the Max Topics manual.
Depending on your platform, there are a few ways to approach looping the DLS synth audio back into Max. _________________ Chris Muir
