 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
Directories in ChucK
Page 1 of 1 [7 Posts]
Plasticman
PostPosted: Wed Apr 09, 2008 5:34 am    Post subject: Directories in ChucK Reply with quote  Mark this post and the followings unread
When using Machine.add(), does it use the chuck file's parent directory, or the binary's? I tried to launch a file in a subdirectory with the code below, and the VM reported that the file did not exist.
Code:
Machine.add("./Modules/ModManager.ck");
edit: Could it be because I'm running Windows? The /example/shred/machine.ck example didn't work either.
Kassen
PostPosted: Wed Apr 09, 2008 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually, ChucK uses a path relative to the directory from which it was called. That may be the location of the executable, but likely it isn't as likely you put the executable in your path (copying it to /windows/system32/ will do).
If this is a problem you can use the full path in the file-name like;
Machine.add( "d:/chuck/myfiles/drums/snare.ck" );
I recommend using relative paths so you can easily move and distribute your code but this may not always be convenient.
Note that the MiniAudicle has a setting in it's menu to indicate the directory to work from, since it's a graphical application it's location in the directory tree isn't very meaningful most of the time.
Hope that helps.
Modern technology offers an endless field day to any deviant strains in our personalities. --J.G.Ballard
Inventor
Audio files: 67
PostPosted: Wed Apr 09, 2008 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm, I would try:
Code:
Machine.add("Modules/ModManager.ck");
leaving off the "./" at the beginning. Though I really don't know if that would work. ChucK itself should use the directory from which you launched it, and the miniAudicle has a place in the preferences where you can specify the directory. If the above suggestion doesn't work, try looking at this and other path examples in the docs. Good luck.
For those about to ChucK, we salute you! - Ge Wang
Let's make noise for peace! - kijjaz
Plasticman
PostPosted: Wed Apr 09, 2008 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I was trying to run it from miniAudicle, once I used the command line it worked fine. Thanks!
Kassen
PostPosted: Wed Apr 09, 2008 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
In that case you may want to check the MIni's settings for the starting directory. I think it's in the last tab of the settings.
kijjaz
PostPosted: Wed Apr 09, 2008 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
or do we need to replace / with \ on windows?
Plasticman
PostPosted: Wed Apr 09, 2008 11:50 am    Post subject: Reply with quote  Mark this post and the followings unread
No, ChucK reads \ as an escape character.
Buy N Save
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
