 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
Unchucking has no effect?
Page 1 of 1 [8 Posts]
olejorgen
PostPosted: Wed Apr 09, 2008 11:06 pm    Post subject: Unchucking has no effect? Reply with quote  Mark this post and the followings unread
Code:
SndBuf buf => dac;
me.arg(0) => buf.read;
0.5 => buf.gain;
1 => buf.rate;
0 => buf.pos;
while (true) {
        20000::ms => now;
        <<< "disconnect" >>>;
        dac =< buf;
        10000::ms => now;
        <<< "connect" >>>;
        buf => dac;
disconnect and connect is printed at correct times, but the wav just continues to play.. ?
Kassen
PostPosted: Wed Apr 09, 2008 11:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi, olejorgen!
Could you please re-post this code while turning HTML off? That's the top checkbox below the field where you enter your text, If you don't turn it off the board will get confused by all the triangular brackets and you end up with lines like " dac =<buf> now; " which I'm sure wasn't what you intended.
In the meantime here's a working chuck/unchuck example;
Code:
SinOsc lfo => SinOsc s;
500 => lfo.gain;
.5 => lfo.freq;
2 => s.sync;
while(1)
   s => dac;
   second => now;
   s =< dac;
   second => now;
while(!machine.crash() ) <<<"all is well">>>;
olejorgen
PostPosted: Wed Apr 09, 2008 11:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Done. Seems like I mixed up the order, thanks Smile
Kassen
PostPosted: Wed Apr 09, 2008 11:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, you were disconnecting the dac from the buf, not the buf from the dac.
In ChucK signals flow like you read&write English; from left to right. Your code didn't generate a error because the dac can in fact be connected to modules, for example to make ChucK sample it's own output. Here the dac wasn't connected to any Ugen but that doesn't stop your from trying to unchuck it, that just doesn't do anything but it's not illegal either.
With that fix, one of my own samples and shorter durations (because my sample was just a few seconds) your code worked fine.
Stochastic
PostPosted: Thu Apr 10, 2008 1:16 am    Post subject: Reply with quote  Mark this post and the followings unread
would it be a feature consideration for the VM to output a warning that the code is trying to unchuck a non-chucked set of modules? or would that generate too many warning messages for advanced codes?
Inventor
Audio files: 50
PostPosted: Thu Apr 10, 2008 1:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Such a feature would have helped me debug Guitar Lab and Synth Lab which are constantly ChucKing and unChucking ugens.
@(ºoº)@ ><}}}º> ~(^.^) <:3 )~
Kassen
PostPosted: Thu Apr 10, 2008 1:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Here you go;
Code:
500 => lfo.gain;
.5 => lfo.freq;
2 => s.sync;
while(1)
   //introduce randomness
   //so we have something to detect
   if(maybe) s => dac;
   second => now;
   //interesting bit starts here
   //(where "interesting" means rather straight forward
   //but nearly entirely  undocumented :¬) )
   if( s.isConnectedTo(dac) ) s =< dac;
   else <<<"not connected!">>>;
   second => now;
Three cheers for arcane commands and Gmail's search function! (see Ge's reply to Kijjaz on the users mailing list 13/07/2007)
Kassen
PostPosted: Thu Apr 10, 2008 1:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Also note that chucking a ugen to another ugen (or the dac) if it's already connected to it won't do anything. This means you need a second gain to square a signal (chucking it twice to a gain set to multiply won't do since the double connection is ignored) but mostly this is convenient. This means the "maybe" above doesn't need a check.
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
