 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
Keeping different looped parts in sync
Page 1 of 1 [9 Posts]
widdly
PostPosted: Thu Apr 10, 2008 12:11 am    Post subject: Keeping different looped parts in sync Reply with quote  Mark this post and the followings unread
Hi, I'm wondering how people go about playing/editing different parts and keeping them synced. "Replace Shred" is no good because it just starts anywhere.
I've worked out a system using machine.add and different files. This way I can edit each file and when I save the next loop will play the new file. I don't think this is a good system because of all the disk file reading going on, especially for small loops.
Is there some way of using events to do this?
Here's an example of my method. Load the loop.ck and it will do the rest. You can edit the other files independently.
loop.ck
 Filename:  loop.ck
 Filesize:  110 Bytes
 Downloaded:  16 Time(s)
kick.ck
 Filename:  kick.ck
 Filesize:  611 Bytes
 Downloaded:  13 Time(s)
hihi.ck
 Filename:  hihi.ck
 Filesize:  555 Bytes
 Downloaded:  11 Time(s)
drum_mach.ck
 Filename:  drum_mach.ck
 Filesize:  1.28 KB
 Downloaded:  12 Time(s)
snare.ck
 Filename:  snare.ck
 Filesize:  694 Bytes
widdly
PostPosted: Thu Apr 10, 2008 12:11 am    Post subject: Reply with quote  Mark this post and the followings unread
..oops forgot one
cow.ck
 Filename:  cow.ck
 Filesize:  814 Bytes
Kassen
PostPosted: Thu Apr 10, 2008 12:15 am    Post subject: Re: Keeping different looped parts in sync Reply with quote  Mark this post and the followings unread
Hi, Widdly!
Have a look at the "otf" examples in the /examples/ dir, there are 6 of those that can be run together, started at any moment and they'll sync up in a really cleaver way, check it out.
(hint, the percentage (%) sign refers to "modulo")
while(!machine.crash() ) <<<"all is well">>>;
widdly
PostPosted: Thu Apr 10, 2008 2:07 am    Post subject: Reply with quote  Mark this post and the followings unread
ha!
Smart. thanks for that. Makes things much easier.
widdly
PostPosted: Thu Apr 10, 2008 3:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Any tricks for removing shreds in sync?
I'm thinking you could write a file that takes a shred id as an argument then removes the shred using the modulo time trick.
if ( me.args() == 1)
me.arg(0)=>string text;
Std.atoi(text) => int shred_id;
.5::second => dur beat;
8::beat => dur bar;
bar - (now % bar) => now;
Machine.remove( shred_id );
radarsat1
PostPosted: Fri Apr 11, 2008 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
for keeping in sync i usually have a common clock based on broadcast events. each of my loops waits for a clock signal with a certain modulo before starting.
for removing i just try to time it by ear, or turn down the volume on that shred first.
widdly
PostPosted: Fri Apr 11, 2008 8:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
How do you turn down the volume on an individual shred?
Kassen
PostPosted: Sat Apr 12, 2008 5:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Code:
Gain master_fader => dac;
stuff => master_fader;
more_stuff => master_fader => dac;
.5 => master_fader.gain;
Where "stuff" refers to the Ugens you are using.
radarsat1
PostPosted: Sat Apr 12, 2008 9:05 am    Post subject: Reply with quote  Mark this post and the followings unread
exactly. in other words, you just program the shred so you can turn it down. i do a lot of my chuck control over OSC and MIDI, so "turning down the volume" amounts to turning a physical knob to the left.
Once You Know, You Newegg
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
