Inventor
Joined: Oct 13, 2007 Posts: 1164 Location: Florida, USA
Audio files: 50
Joined: Jul 06, 2004 Posts: 6246 Location: The Hague, NL
Posted: Sat Apr 19, 2008 6:18 am Post subject:
Re: Guitar Note Detection Subject description: Algorithms for extracting the notes from the signal... |
| Inventor wrote: |
I thought others might have some suggestions, so I'm posting about it. How would you do this? |
I have one... but it's a very different approach... and meant to be set loose on files, not in realtime.
What I do is "ride" the RMS, if the RMS goes from increasing to decreasing that must be a peak, I reason. At that point I store the last time it went from decreasing to increasing as that would be the start of the attack of this note or hit.
This is ok but it results in too many notes being detected as it will also detect volume modulations.
So; I only store the time of a "valley" in the wave (when it starts going up again) if the amplitude has decreased to -say- 75% of the last peak or less. That would still have false-positives when the volume fluctuates at a low amplitude but this is much less of a issue since my goal is to detect the n loudest hits in a drum-loop so low-volume noise won't get through anyway.
All of the hits/ notes detected in that way end up in a array to index them and after I did that I remove ones that are shorter then -say- 50::ms.
This tends to give me a set of indexes of a drum-loop that's quite workable for automatic breakbeat cutting but that's a different problem then the one you are trying to solve so the solution is different as well. It's inspired by the settings of Soundforge's "auto-region" tool, I'm not sure they use a similar method but the parameters are quite similar. It's not a realtime tool since it will store the start of the envelope's attack after (and depending on) the peak so there's already latency there and I'm more concerned with dividing the loop up in musically sensible sections then I'm with actually detecting each and every hit.
May still be of some interest? _________________ while(!machine.crash() ) <<<"all is well">>>; |
Frostburn
Posted: Sat Apr 19, 2008 7:39 am Post subject:
I did have a look in to this but no luck yet. (I've only managed to get the strongest partial out of a signal, not the fundamental)
There are so many cool effects that depend on good fundamental tracking that this surely would be a great tool.
I'm busy with school and all but once I'm done with the exams I should have a whole summer to chuck.
So yeah, I'm still alive but maybe still not chucking for a while  _________________ To boldly go where no man has bothered to go before. |
Inventor
Audio files: 50
Posted: Sat Apr 19, 2008 7:56 am Post subject:
Yes, I like the idea of "riding the RMS". I'm a little unsure, however, of how to code it. I remember from school that RMS is a calculation for periodic signals, but here the signals are not periodic. Is it done with a sliding window, as is the case with an FFT? I did something similar like this:
Signal in => FullRect fr => LPF lpf => HPF hpf => Gain div => blackhole;
lpf => div;
div.op (4);
Where the LPF is sort-of like an envelope (but not really) of the signal, and hpf is supposed to be the slope of that envelope. Then hpf / lpf is a normalized representation of that envelope and the software looks at div.last () for a threshold transition.
It didn't work, but then again I didn't try to tweak it either. Most of the reason it didn't work is that the signal envelope was nearly flat. I opened up the wav file in audacity to see the waveform and there were no positive transitions in envelope at note beginnings. On another file there were, but not significant enough to detect easily.
However, the above is not as good as an RMS calculation, because RMS will integrate all of the energy including harmonics. If each note consists of a sudden increase in harmonics, RMS will catch it I think. My only issue is how to do RMS with a sliding window calculation. Maybe RMS would just have to be approximated somehow? Something like this perhaps:
Signal in => Gain mult => Gain buff => LPF int => blackhole;
buff => mult;
mult.op (3);
Then poll int.last () and use sqrt() on it, compare to previous values. Could be something like that, eh? _________________ @(ºoº)@ ><}}}º> ~(^.^) <:3 )~ |
Inventor
Audio files: 50
Posted: Sat Apr 19, 2008 7:59 am Post subject:
| Frostburn wrote: | I'm busy with school and all but once I'm done with the exams I should have a whole summer to chuck.
So yeah, I'm still alive but maybe still not chucking for a while  |
Good to hear from you, Frostburn! I was just thinking last night: "I wonder where Frostburn and Kijjaz have been?". Even if you don't have time to code, do try to post once in a while to let us know you didn't drop off of the face of the earth! Plus if you happen to comment on any of the posts, that's a bonus. Cheers! _________________ @(ºoº)@ ><}}}º> ~(^.^) <:3 )~ |
Posted: Sat Apr 19, 2008 8:18 am Post subject:
| Inventor wrote: | | Yes, I like the idea of "riding the RMS". I'm a little unsure, however, of how to code it. |
Oh, those nice Princeton / Stanford people already did that for us, there's simply a RMS Uana.
I think, BTW, that Perry's envelope follower based on squaring the signal, then pulling it through the filter is also a RMS implementation but I may be misunderstanding stuff there again. _________________ while(!machine.crash() ) <<<"all is well">>>; |
Inventor
Audio files: 50
Posted: Sat Apr 19, 2008 8:23 am Post subject:
| Kassen wrote: | | Inventor wrote: | | Yes, I like the idea of "riding the RMS". I'm a little unsure, however, of how to code it. |
Oh, those nice Princeton / Stanford people already did that for us, there's simply a RMS Uana. |
Well, lookey here, a nice little RMS Uana all set up for me to code! Go Princeton! If I ever have kids, they're going to Princeton, haha. I'll have to code that up once this coffee gets me going this morning. _________________ @(ºoº)@ ><}}}º> ~(^.^) <:3 )~ |
Posted: Sat Apr 19, 2008 8:26 am Post subject:
| Inventor wrote: |
Good to hear from you, Frostburn! I was just thinking last night: "I wonder where Frostburn and Kijjaz have been?". Even if you don't have time to code, do try to post once in a while to let us know you didn't drop off of the face of the earth! Plus if you happen to comment on any of the posts, that's a bonus. Cheers! |
Posted: Sat Apr 19, 2008 8:28 am Post subject:
| Inventor wrote: |
Well, lookey here, a nice little RMS Uana all set up for me to code! Go Princeton! If I ever have kids, they're going to Princeton, haha. |
Don't forget Ge went to Stanford. I think Spencer also moved West. _________________ while(!machine.crash() ) <<<"all is well">>>; |
Inventor
Audio files: 50
Inventor
Audio files: 50
Posted: Sun Apr 20, 2008 4:04 am Post subject:
Wow, I tweaked the FFT size on that previous file and it started working very well. Here is an example of the output:
| Code: | 17 91.516113 0.000636 2.798322 41.815130
15 80.749512 0.000358 2.672298 39.648263
19 102.282715 0.000275 2.558877 43.740706
17 91.516113 0.000237 4.456310 41.815130
61 328.381348 0.000326 4.164487 63.934424
18 96.899414 0.000696 3.901847 42.804676
18 96.899414 0.000499 3.585915 42.804676
75 403.747559 0.000428 3.329862 67.511400
37 199.182129 0.000444 3.094754 55.279016
29 156.115723 0.000135 2.939087 51.061348 |
The columns are FFT bin number, frequency, amplitude of fundamental, average notes per second, and MIDI number. They are all pretty much correctly detected notes. The average is 3 notes per second, which is how fast the recording goes so that's good. And the MIDI numbers are about right. I think that because of the low pass filter, it might not be as good at detecting higher notes like 1kHz, but that's OK for now. _________________ @(ºoº)@ ><}}}º> ~(^.^) <:3 )~ |
Posted: Sun Apr 20, 2008 8:08 am Post subject:
| Inventor wrote: |
I put your RMS tracking feature in, Kassen, and it improved the situation quite a bit, plus i added a low pass filter change that attenuates harmonics.
Considering the guitar sound where notes start with a burst on noise before settling on the pitch I'd LPF before the pitch detection but not before the RMS one. This is because the burst of noise is quite loud and so easy (and useful!) to detect volume-wise while it doesn't convey much pitch information.
While perhaps more expensive as you'll need to Uanae chains I think that might significantly improve the reaction to plucks. _________________ while(!machine.crash() ) <<<"all is well">>>; |
Inventor
Audio files: 50
Posted: Sun Apr 20, 2008 8:24 am Post subject:
| Kassen wrote: | Considering the guitar sound where notes start with a burst on noise before settling on the pitch I'd LPF before the pitch detection but not before the RMS one. This is because the burst of noise is quite loud and so easy (and useful!) to detect volume-wise while it doesn't convey much pitch information.
While perhaps more expensive as you'll need to Uanae chains I think that might significantly improve the reaction to plucks. |
Yes, it requires two FFT's, but it does seem to work better, good call Kassen. _________________ @(ºoº)@ ><}}}º> ~(^.^) <:3 )~ |
Posted: Sun Apr 20, 2008 8:40 am Post subject:
It's really quite remarkable how far you can get with this very simple way of looking at it all. You will need to get the response rate up for this if you want to do it in realtime so I think this is a good idea. Fortunately guitar picking is a very brief and very sharp event so to avoid false-positives from for example handling the body of the guitar itself you could even consider a HPF in the chain that aims to detect plucks. _________________ while(!machine.crash() ) <<<"all is well">>>; |
Inventor
Audio files: 50
Inventor
Audio files: 50
nescivi
Posted: Thu Apr 24, 2008 8:19 pm Post subject:
| Inventor wrote: | | I'm hoping that once I get a real guitar, the "clean" signal from it will have more energy in the fundamentals. |
Well, I'm guessing that you won't, unless you pull the string in the middle and let it go from there. But since normally you play the guitar exciting the strings at the body of the guitar, you'll be inciting more of the higher harmonics than the fundamental one.
I'm betting that that is part of how we distinguish the guitar sound (apart from the body resonance and all).
but you should try and search for guitar pitch estimation algorithms, since I am sure there are a lot around, as this is an area which has high commercial interest as well. DAFX conferences might be a place to start looking. |
Inventor
Audio files: 50
Posted: Thu Apr 24, 2008 9:40 pm Post subject:
Ah, an interesting observation nescivi. I will go do some Googling on the topic now!
You might find the video in the first post of this thread to be interesting, if you haven't seen it yet:
http://www.electro-music.com/forum/topic-25122.html _________________ @(ºoº)@ ><}}}º> ~(^.^) <:3 )~ |
