 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
Ambiophonic Time Correct Panning
Page 1 of 1 [6 Posts]
bachus
PostPosted: Wed Apr 23, 2008 5:31 pm    Post subject: Ambiophonic Time Correct Panning Reply with quote  Mark this post and the followings unread
Update 4
Corrected some problems and switched to the Rayleigh IDT algorithm.
Still can't tell that it does anything worthwhile.
Ambiopan.ens
 Filename:  Ambiopan.ens
 Filesize:  156.29 KB
 Downloaded:  14 Time(s)
K. Vonnegut
"We are here on Earth to fart around. Don't let anybody tell you any different."
bachus
PostPosted: Wed Apr 23, 2008 7:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Playing with this and looking at it I realize that though it is time correct it is not amplitude correct. When an acoustic source is moved to the "far" left the amplitude at the right microphone dose not drop to zero or anything like it. Thus the HRTFs must have a dominant role in in localization.
K. Vonnegut
bachus
PostPosted: Sat Apr 26, 2008 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
'nother file update
I think at this point I will abandon this and look at VST in c++ so I can play with adding HRTFs in the pan path.
What I want ultimately is something that models the ambiophonic recording method. If anyone can point to help with such it would be appreciated.
K. Vonnegut
durwood
PostPosted: Sat Apr 26, 2008 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm,
Give these a shot. Might be more ambiosonic related but they should share similarities?
http://www.gerzonic.net/?rub=2
They have the VST code I believe as well.
http://www.dmalham.freeserve.co.uk/vst_ambisonics.html
http://www.york.ac.uk/inst/mustech/3d_audio/vst/welcome.html
bachus
PostPosted: Sun Apr 27, 2008 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the link. These are interesting technologies. However the panner does seem to be for ambiosonics which is for multi-channel (>2) systems What I want is one that enhances both ambiophonic and (I think) therefore std. stereo playback.
K. Vonnegut
bachus
PostPosted: Sun Apr 27, 2008 7:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
More bugs found. I'm still getting the hang of debugging Reaktor files. I recommend that this not be used till I have a few weeks of futzing around with this. Very sorry Embarassed
K. Vonnegut
Once You Know, You Newegg
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
