The Web Hearts ChucK - My Project
Page 1 of 1 [10 Posts]
Plankhead
PostPosted: Fri Apr 25, 2008 8:20 pm    Post subject: The Web Hearts ChucK - My Project
Subject description: Ruby has Rails, Chuck has <3?
A while ago (read: a couple days) I decided I wanted to create a new web language and call it <3.
That's right. Less than three. Heart. <3. The file extension would be .<3 (It's possible, really, even on the web. Just use .&lt3; if it screws up your parsing), and it would be wonderful. Now I just had to decide what it would do.
That was the hard part.
I thought something about audio. Like...dynamic audio! Your screen can output the color white, so why not let them output white noise? It would be CSS for audio! And it would all take place on the client-side, so you wouldn't have to download all that much!
Now, I don't have any degrees in computer science. I'm a senior in high school going into film school in the fall. Somehow, for whatever reason, I know my way around a PHP document and a stylesheet, and that's gotten me involved in web design. For a while I decided to experiment with Ruby on Rails to see if I could come up with any whiz-bang ideas, but eventually the idea hit me that I wanted to be proficient in a language called <3. Why? Because I want to.
Now, what does all that have to do with this, other than the fact that I really have no business sticking my nose into creating my own web programming language? Well, essentially, it meant I'd have to find an existing open-source audio synthesizing and manipulation environment to include in my own equally open source project.
Hi, ChucK.
So I came up with the basic structure of how a <3 "beat" file would look. Part stylesheet, part scripting language, it would organize calls to a ChucK virtual machine that would theoretically be controlled by the browser (a Firefox extension is the most likely preliminary solution). Each page element would have its own specific set of functions to call, starting its timer once the parent element is done loading (i.e. the header will start doing things when it loads, as will images, and some calls won't be made until the entire page body loads).
Of course, <3 wouldn't use ChucK just for audio. It would use it for timed events as well, i.e. click a button, and five visual effects occur over the next five seconds, one at every second mark.
I created a miniwiki for the specification where I THINK I explained it pretty well. It's located at http://scratchpad.wikia.com/wiki/Category:Heart_Beat_Scripting_Language. I'll add an FAQ after posting this just to make sure.
Now, is all this possible with JavasScript and/or AJAX? Probably. As easy? Certainly not. ChucK-powered? Nein.
Thoughts?
EDIT: Windows made me have to change the file extension to .lt3. I hate you Microsoft.
Inventor
Audio files: 50
PostPosted: Fri Apr 25, 2008 8:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's certainly a very creative idea. Even Linux started with just one person taking one step first. I believe Linus Torvalds, who wrote the first Linux code, was a student at the time. Perhaps your idea will go far also. Good luck with it and do keep us posted, it's interesting stuff!
@(ºoº)@ ><}}}º> ~(^.^) <:3 )~
Plankhead
PostPosted: Fri Apr 25, 2008 8:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I read Linus Torvalds' biography, the appropriately titled "Just for Fun," and I'm aware that I've already taken a very Linuxy step by even thinking about this. The difference is that I believe he was actually a computer science student.
PostPosted: Fri Apr 25, 2008 11:04 pm    Post subject: Re: The Web Hearts ChucK - My Project
Plankhead wrote:
Thoughts?
Go! Very nice idea indeed.
while(!machine.crash() ) <<<"all is well">>>;
Inventor
Audio files: 50
PostPosted: Fri Apr 25, 2008 11:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
ChucK has a very limited network capability now, so that's one thing I'd look into. I've only seen it once, somewhere on the unit generators list, but it isn't linked to from the unit generators page. ChucK can connect between two computers (or perhaps more) if you know their ip addresses and the port numbers to use.
Also on the Wiki Projects page the top entry is from someone who at least once was working on a networked ChucK server that people could run.
Those are two things I'd consider as starting points for your effort. Good luck.
Plankhead
PostPosted: Sat Apr 26, 2008 6:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Ideally all the ChucKing will be executed on the client side. All scripts would be downloaded (or take place on the localhost to begin with).
The browser would have to be configured to process a ChucK script in a certain way. It might look for specific script comments. For example, here's my beep script:
Code:
//The next two comments are parsed by the BROWSER because they are phrased "//<3"
//The browser will look at a comment, and then look at the next character(s) to see if it should continue parsing that line.
//<3> float freq;
//<3> dur time;
SinOsc s => dac;
freq => s.freq;
time => now;
s =< dac;
When the script is called, it would be phrased http://127.0.0.1:30000/beep.ck?freq=1000&time=60%3A%3Ams (that link won't lead anywhere so don't click it).
By the way, if anyone has any comments or ideas for things on the wiki, PLEASE post on the pages or talk pages of various entries.
Inventor
Audio files: 50
PostPosted: Sat Apr 26, 2008 6:35 am    Post subject: Reply with quote  Mark this post and the followings unread
That's starting to sound a little clearer, good. Although "time" is a keyword in ChucK so I'd use another variable name. Also there is a distinction between time and dur in ChucK, dur is a delta time. But that's just a minor detail. Do you know how to write a script that will interpret the code that gets sent to your client? If so you can get started right away coding something that works. I like the idea of passing parameters into the script in typical html style, that makes sense. Keep it up, it's interesting to read.
Plankhead
PostPosted: Sat Apr 26, 2008 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
If you take another glance at the URL, you'll see "%3A%3A" between 60 and ms. That's URL encoding for "::". So, yes, a dur is passed into the dur.
Dur. Funny word.
Hoo boy. Well...remember that whole part about not having any business writing my own programming language?
Although I'm sure I could figure it out. The tricky part is getting the ChucK Virtual Machine to run natively as a browser plugin, such as a Firefox extension.
Plankhead
PostPosted: Sat Apr 26, 2008 8:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good news! The wiki is migrating to http://heartlanguage.wikia.com/ as we speak!
kijjaz
PostPosted: Sat Apr 26, 2008 8:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow! This is very good idea.. There can be a lot of more tools out of this fusion ^_^
thanks and fight fight.
Music123.com - Customer Appreciation Sale Extended! - Save Up To $80 Off Your Order - Sale Ends Soon!
