 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
I'm Back
Page 1 of 1 [7 Posts]
ausz99
PostPosted: Wed Apr 30, 2008 5:08 am    Post subject: I'm Back Reply with quote  Mark this post and the followings unread
Hi guys. It's been a long time since i've been on the forum and even longer since i've been playing with chuck. Just wondering if you could have a look at this coding for me. It's trying to get a SinOsc to play a harmonic minor scale but alas i've forgotten how to make use of arrays.
Code:
SinOsc s => dac;
//Harmonic minor scale
261.626 =>float C1; //Had to create C1 and C2 because
293.665 =>float D;  //otherwise C would have been assigned
311.127 =>float E; //to two notes an octave apart.
349.228 =>float F;
391.995 =>float G;
415.305 =>float A;
246.942=> float B;
523.251 =>float C2;
[ C1, D, E, F, G, A, B, C2 ] @=> int bassline[];
bassline[] => s.freq
Don't laugh at it lol coz i have forgotten a lot. I handed in my project and haven't really touched chuck since and want to get back into it now.
Cheers for any help
Ausz99
Inventor
Audio files: 67
PostPosted: Wed Apr 30, 2008 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Try this:
Code:
SinOsc s => dac;
349.228 =>float F;
391.995 =>float G;
415.305 =>float A;
246.942=> float B;
523.251 =>float C2;
[ C1, D, E, F, G, A, B, C2 ] @=> float bassline[];
for (0 => int i; i <8> s.freq;
    250::ms => now;
I changed your array to type float, set up a for loop, indexed the array, and put in a time delay for each note.
Welcome back, and by the way you can post to the ChucK forum under DIY now. Cheers.
For those about to ChucK, we salute you! - Ge Wang
Let's make noise for peace! - kijjaz
Audio files: 28
G2 patch files: 295
PostPosted: Wed Apr 30, 2008 7:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I Moved this thread to the ChucK section.
ausz99
PostPosted: Mon May 05, 2008 4:16 am    Post subject:   Reply with quote  Mark this post and the followings unread
Cheers Inventor
Code:
SinOsc s => dac;
349.228 =>float F;
391.995 =>float G;
415.305 =>float A;
246.942=> float B;
523.251 =>float C2;
    250::ms => now;
Unfortunatly this code doesn't work, i think it's something to do with brackets on the "for" loop at the end, i'm gonna have a tinker and if i get it to work i'll post it here
Ausz99
Inventor
Audio files: 67
PostPosted: Mon May 05, 2008 5:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Code:
SinOsc s => dac;
349.228 =>float F;
391.995 =>float G;
415.305 =>float A;
246.942=> float B;
523.251 =>float C2;
for (0 => int i; i < 8; i++ ) {
    bassline[i] =>s.freq;
    250::ms => now;
There, try that. I forgot to check the box for "Disable HTML in this post" and the forum software misinterpreted the "<" for html. This one should work fine, I tested it.
kijjaz
PostPosted: Mon May 05, 2008 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I propose some adjustments to the original patch:
Code:
SinOsc s => dac;
[261.626, 293.665, 311.127, 349.228, 391.995, 415.305, 493.884, 523.251] @=> float ScaleFreq1[];
0 => int Do;
1 => int Re;
2 => int Mi;
3 => int Fa;
4 => int So;
5 => int La;
6 => int Ti;
[Do, Re, Mi, Fa, So, La, Ti, Do + 7, So, Ti - 7, Do] @=> int bassline[];
int octave;
for (0 => int i; i < bassline.cap(); i++ )
    0 => octave;
    bassline[i] => int GetNote;
    while(GetNote < 0)
        octave--;
        7 +=> GetNote;
    while(GetNote >= 7)
        octave++;
        7 -=> GetNote;
    ScaleFreq1[GetNote] * Math.pow(2, octave) => s.freq;
    250::ms => now;
this works quite the same but added some convenience.
notes can be called by Do Re Mi..
and number of tone can be added or subtracted.
for example, adding with 7 makes it jump to another octave.
Inventor
Audio files: 67
PostPosted: Mon May 05, 2008 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Crank it up, kijjaz! Play that funky music kijjaz! Haha. Nice changes.
Once You Know, You Newegg
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
