  Antimon Antimon Waves
brass etching technique
Page 1 of 2 [29 Posts]
Photon
PostPosted: Wed May 07, 2008 10:21 am    Post subject: brass etching technique Reply with quote  Mark this post and the followings unread
I've been making my panels out of brass. Brass is more expensive than aluminum. It weighs quite a bit more and is harder to work with. However it has some other properties that I thought were very attractive for my purposes:
1.) It can be etched using a fairly simple set-up, using readily available chemicals
2.) It can be soldered
3.) It looks cool, in a 'Jules Verne' sort of way.
SNVoice
I've been asked to describe the process that I use in some detail and I'm happy to do that. However, I do have access to some equipment and tools at work that make that job a lot easier (ie. full machine shop access). If I had to do this totally at home, I might have chosen a different approach. That isn't to say that it couldn't be done at home.
The panels are fairly cheap to make (worked out to be about $2. per panel). The real cost is time. There is a lot of hand work in each panel.
I buy the brass in a sheet that is usually about 3 foot sq. depending on what my supplier has in stock at the time. I cut this using a band-saw with the appropriate metal cutting blade. I cut it into 6 x 36 inch strips (my panels are 5.25 height, FRAC) then I can cut them to the appropriate width as needed.
To do the graphics I start with a sketch. Once I have a design that I like, I lay out the panel in a CAD program with all the panel controls (pots, switches, etc) in place to make sure that nothing interferes. Then I shut off the layer with the controls and export it to Adobe Illustrator. In Illustrator I layout the lettering and any other graphics.
This file is mirrored and the color is inverted and exported as a .jpeg. I print this 100% and photocopy it onto press-n-peel film. I iron the image onto the brass after carefully de-burring and degreasing the panel. I also touch up any imperfections in the toner with enamel paint.
The idea is that the toner acts as a resist. Any open area will be etched.
Brass is 70% copper. I use a solution of Copper Sulfate Pentahydrate to provide the copper ions for the etch bath. This chemical is available in crystal form from garden centers, where its sold as a weed killer. I should mention at this point that Copper in this form is TOXIC. I dissolve the crystals in water until the solution is saturated. I store it an plastic jug and have been using it over and over. Consult local authorities about proper disposal in your area.
The etch set up itself is fairly straight forward. I use a plastic storage container that is narrow in one dimension (you want the plates fairly close to each other. A brass frame was constructed out of .125" brass rod to support the panel to be etched . this is the anode. The cathode is made similarly, but has a brass panel soldered permanently in place. A DC current supply is handy, but I suppose a battery could also be used. See pictures below.
panel etching
etching set-up
Any exposed part of the panel that you don't want etched should be masked with tape.
The positive lead from the supply attaches to the panel to be etched and the negative to the cathode. The bath is filled with the CuS solution and the power is turned on. I generally etch things in the 4v/1A range. The resistivity of the bath will make a difference. Its worked from day one, so I never tried optimize it.
Once the panel is etched, 30 minutes to 1 hour depending on exposed surface area, I remove it from the bath and clean it up. At this point I machine the panel to its final dimensions and drill the holes. The graphics are filled in with a rub on paint stick. A final coat of spray on lacquer keeps the panel from oxidizing.
Here's a close-up of my mixer panel showing the etch depth and the level of resolution. The photo was taken prior to filling in the letters with black paint. This particular panel etched for 1 hour (4v/1A). The letters are 14 points tall (about 3mm)
detail of etching resolution
Another benefit to brass is that it can be soldered to. Here you can see the stand-offs for the PCB are soldered directly to the panel.
wiring the SNV
numbernone
PostPosted: Wed May 07, 2008 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
JUST WOW
toybox
PostPosted: Wed May 07, 2008 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Iv always have thought you had the most beautiful panels been trying to etch
aluminum but the laser printer i was using was shit!! but yesterday i got my hands on a new printer so im ready to give it a new try Very Happy
mY MusIc
http://www.myspace.com/toyboxbastard
PostPosted: Wed May 07, 2008 5:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Peter,
Thanks for that explanation. I am impressed with the resolution of etching process. The lettering comes out quite good.
Folks, I have seen his panels in person and they really do come out nice !!
I would imagine that you had to crank the iron up a few degrees to get that solder to melt around those posts when attaching them to the front panel. Wink
Now, too bad you could not etch aluminum the same way. It's much lighter . I am not to bright when it comes to material sciences and maybe there could be a way. Wink
Bill
Photon
PostPosted: Wed May 07, 2008 5:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I use a torch Very Happy
Thanks everyone for the kind words. Let me know if anything needs clarification.
Audio files: 212
G2 patch files: 319
PostPosted: Wed May 07, 2008 5:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think this makes for very nice panels indeed!
Was wondering, do you protect the back side of the panels against etching?
Photon
PostPosted: Wed May 07, 2008 5:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks. Yes, I use duct tape.
toybox
PostPosted: Wed May 07, 2008 5:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I thought i seen aluminum etched with a salt water solution the same way.But i was going to try ferric chloride?
mY MusIc
toppobrillo
PostPosted: Wed May 07, 2008 11:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
your panels look great! i tried some electro-etching of aluminum with salt-water and an old computer supply- not immersing the panel but using a steel plate with salt-water soaked flannel piece- i seems to work but very very slowly. im sure theres a better electrolyte for aluminum.
Luka
PostPosted: Sun Oct 12, 2008 5:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey photon
im about to start etching aluminium plates and i have a couple of questions about your process
1. is this power supply ok?
ebay link - please dont outbid me folks Smile
"POWERTECH PLUS MP-3096 13.8VDC DC LAB POWER SUPPLY IN BOX
REGULATED
COMPACT
LIGHTWEIGHT
SHORT CIRCUIT PROTECTION
OVERLOAD PROTECTION
OUTPUT VOLTAGE 13.8VDC
RATED OUTPUT 5 AMPS
SURGE CURRENT 7 AMPS
VOLTAGE REGULATION <5%
RIPPLE VOLTAGE 100MV"
2. you said you etch your panel and then take it back into the shop and neaten up the panel. if i have aluminium panels already cut to size is it going to be tricky to get a clean finish especially around the edges?
problemchild
melbourne australia
Appliancide*
PostPosted: Sun Oct 12, 2008 9:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the post! I have been considering this technique ever since I saw one of your posts showing some of your panels. The difficulty factor make's me think twice....but then I look at those amazing panels....
Thankfully(?) I have yet to populate a single board so I will have a while to mull this over.
SineSurfer
PostPosted: Sun Oct 12, 2008 9:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
for those curious about etching aluminum panels:
elSID closeups
my midibox sid
elSID closeups
those leds are 3mm
the GIMMICK panel 2
my best result so far!(5mm leds here)
It's done like with pcb etching bath, but using muriatic acid(hydrochloric acid) + oxygenated water (hydrogen peroxide) in 2:1 mix for a couple of minutes(exposed aluminum makes a lot of bubbles) rinse with running water, spray paint the panel(black paint on my panels), sandpaper away the paint outside the grooves and voila!
Be very careful with the acid mix, wear googles and gloves and DON'T smell the fumes... pretty toxic.
The best thing is that the same mix can be reused on new panels so there is no waste to get rid of Smile
Disclaimer: YMMV, and I'm not responsible if you do something stupid for not being careful enough, if you have any doubt DON'T attempt this Wink
btw. sometime i'll try to etch brass the same way, I love Photon panels!
Freddy, riding the wave!
http://www.hakkenmusic.blogspot.com
Luka
PostPosted: Sun Oct 12, 2008 10:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
thats nice sine.
did you have to paint in the whole panel with pnpblue/paint including the edges so they were not engraved or can you just cover them with tape ?
problemchild
melbourne australia
SineSurfer
PostPosted: Sun Oct 12, 2008 11:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi Luka, just enough pnp blue to transfer the labels, the rest is covered with scotch tape, I guess any plastic tape will work but you'll want to use one that is easy to remove afterwards, also, if there are any spots without enough or missing toner, you should cover it with tape too, or if it's too small use a sharpie pen, a couple of passes to make the ink thicker as eventually the acid will eat it.
Luka
PostPosted: Sun Oct 12, 2008 11:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
great, this seems like a good way to go
buying a lab supply seems to be a lot more expensive than i first though
problemchild
melbourne australia
Photon
PostPosted: Mon Oct 13, 2008 7:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Luka
I don't have any experience etching aluminum, so I don't know what would be required for a power supply. That certainly looks like it would do it. I would make sure that the output is variable. You probably don't need the full 13V. Also, I'm not sure what would be the best electrolyte to use. I think I've heard people using table salt. It's cool that you're going to give this a try. Good luck (and be careful).
If your panels are cut to the final size before etching, you might want to pre-drill the mounting holes (for attaching the panel to the rack). That way if your control art is slightly skewed, it won't effect how the panel fits on the rack...know what I'm saying?
I agree that a purely chemical etching approach might be a good way to go, if you have a source for obtaining the chemicals and you feel comfortable using them.
SineSurfer-Those panels look GREAT. Nice work. What is the concentration on the HCL and H2O2. Are they laboratory grade or you getting them from the hardware store?
SineSurfer
PostPosted: Mon Oct 13, 2008 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
hi Photon, mix would be:
2 parts HCL as it comes from the hardware store
1 part H2O2, the bottles I can get easily on the pharmacy are labeled as 11 vol, a fellow says 30vol would be better.
just make enough to fill your container up until covering the panel, I use one of those rectangular plastic food containers big enough to lay the panel horizontal.
with this mix you can have the panel etched in 3 minutes or less., the etch depth is small though, like 0.5 mm, giving it more time will increase depth but not sure if the toner will resist well for too long, sharpie ink won't.
Luka
PostPosted: Tue Oct 14, 2008 4:50 am    Post subject: Reply with quote  Mark this post and the followings unread
good point on the mounting holes photon
any other good toner transfer methods other than pnp blue? seriously if i have to use that stuff im going to have to get a loan from the bank! i heard poeple using normal magazine paper? what should i look for?
glossy, flat?
no print, print?
thick paper, thin paper?
any ideas?
problemchild
melbourne australia
Photon
PostPosted: Tue Oct 14, 2008 6:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I've tried glossy photo paper without much luck. Give it try maybe you'll have better luck than me. There are a lot of variables you can play with (density of toner, iron temperature, etc.)
PNP Blue is expensive, but its the bomb. I have a 95% success rate with it.
Luka
PostPosted: Tue Oct 14, 2008 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
did some reseach and any magazine paper is fine!
awesome
and i found a great variable regulated psu and an aluminium mordant
Copper sulfate 1 Kilogram
NaCl (sodium chloride -- table salt) 1 Kilogram
NaHSO4 (sodium bisulfate as SaniFlush) 25 grams
H2O (water -- depending on strength of bath) 10-20 Liter
Ill post some details on my progress once i get some alumium and the psu
problemchild
melbourne australia
Photon
PostPosted: Tue Oct 14, 2008 7:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Great! Keep us posted. Very Happy
Luka
PostPosted: Sat Oct 18, 2008 7:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
progress!
i just bought a power supply
$70
next is to buy a laser printer
hopefully it will cost under $100
and then ill start doing some tests on paper that i can use for transfers
it is going to be interesting as i have designs for my klee do etch and they are really large. i might start off small Smile
problemchild
melbourne australia
budzz89
PostPosted: Sat Apr 18, 2009 7:02 am    Post subject: Reply with quote  Mark this post and the followings unread
elSID closeups
my midibox sid
elSID closeups
those leds are 3mm
the GIMMICK panel 2
well said about this aluminum, i new things i actually i learn now
blanchard grinding
RSFC
PostPosted: Fri Dec 10, 2010 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
For aluminum I have been using saline sulphate. It's cheap, easy, no electricity less toxic than ferric chloride and muriatic acid.
Results:
Danno Gee Ray
PostPosted: Fri Dec 10, 2010 7:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Where do you get your saline sulphate?
