What CGS modules have you built
Page 1 of 2 [30 Posts]
The Alison Project
PostPosted: Sun May 11, 2008 6:31 pm    Post subject: What CGS modules have you built Reply with quote  Mark this post and the followings unread
I will start it off and let you all see how insane I am for Ken's circuits. If any one has questions they could not find answers for on any specific modules, ask away.
CGSRR Real Ring Modulator
CGS03 Psycho LFO x2 (different speeds)
CGS04 DC Mixer (plus a few built into filters etc)
CGS06 Burst Generator x2
CGS07 Gate Sequencer (with addition buffer + switch board)
CGS09 VC Divider
CGS13 Gated Comparator
CGS18 Drum Simulator
CGS19 Chime/Bell Simulator
CGS21 Super Psycho LFO
CGS22 Master Divider V1
CGS23 CV Mega Mixer
CGS26 Analogic
CGS28 Sequential Switch
CGS29 Wave Multiplier
CGS31 Digital Noise
CGS32 Infinite Melody w/ CGS41 Diatonic Conveter
CGS33 Matrix Mixer
CGS34 Analog Shift Register x2
CGS35 Steiner VCF
CGS36 Pulse Divider w/ CGS54 XOR XNOR Logic
CGS37 CV Cluster
CGS38 Saw Pitch Shifter
CGS39 Logic (4 AND, 4 OR, 4 XOR, 8 Inverters)
CGS40 Modulo Magic
CGS47 Cynare Drum Sim
CGS50 Morph Lag x2
CGS52 Lockhart Wave Folder x2
CGS55 Analog Switch Matrix w/ CGS51 Weighted Random Switch
CGS57 Bi-N-Tic Filter
CGS58 Utility LFO
CGS59 Programmer Sequencer (16 steps)
CGS62 Slope Detector x2
CGS65 Tube VCA x2
The Alison Project
www.thealisonproject.com
Last edited by The Alison Project on Mon May 19, 2008 5:44 pm; edited 1 time in total
Peake
PostPosted: Sun May 11, 2008 7:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I stuffed dozens of his boards a while back for someone else, but currently have two tube VCAs that I cannot get to work for some reason. I must have repeated a mistake on both boards, although I followed the layout photo. No sound at all unless I touch the 072's traces. Power connections and amounts are correct.
Edit: Corrected through the installation of the "Second Choice" tubes. Huzzah!
You are a Stone madman, Allison Project!
lanxe
PostPosted: Sun May 11, 2008 8:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
i built these:
2 x cgs vca
1 x 8 stage cgs programmer/sequencer
2 x cgs vco (still having issues with them right now)
1 x cgs steiner vcf
2 x cgs cv mega mixer
2x cgs psycho lfo
Ryan
johans121
PostPosted: Sun May 11, 2008 10:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've built a bi'n'tic filter/oscillator and 4 tube vcas (cgs65).
I currently have 2 vco's, 1 sub-osc, and 2 steiners in the pipeline.
-Jim
*edit, beer + forums = typos
neandrewthal
PostPosted: Mon May 12, 2008 1:20 am    Post subject: Reply with quote  Mark this post and the followings unread
So far:
Psycho Lfo.
Bare PCBs:
DC Mixer x 4
Gated Comparator
Burst Generator
Analog Logic
VC Divider
Pulse Dividers
Suboscillator
XOR XNOR
BiNTic
VCO
Wave Multipliers
Digital Noise
Pehr
Audio files: 9
PostPosted: Mon May 12, 2008 2:28 am    Post subject: Reply with quote  Mark this post and the followings unread
3x Quad logic gates (NAND, NOR and XOR)
3x Synthacon VCF (currently building)
Want: Analog shift register...
loxodrom.blogspot.com
loxodrom @ garageband.com Now with new tracks, November '08
My electro-music Klee Sequencer build thread (pictures)
RF
PostPosted: Mon May 12, 2008 5:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I built these CGS circuits on perfboard....
CGS03 Psycho LFO
CGS06 Burst generator (x2)
CGS42 Gate Seq. CV Adapter
CGS10 Pedal board/Mini Keyboard
CGS18 Drum simulator (x4)
CGS24 Gate to Trigger Converter (Lots)
CGS30 Band pass filter (x2)
CGS35 Steiner VCF
CGS36 Pulse Divider
CGS52 Simple Wave Folder
CGS54 XOR XNOR logic
CGSLD LED driver (Lots)
I'm preparing to order several boards from him.....
Thanks fro sharing these, Ken!
bruce
Funky40
G2 patch files: 5
PostPosted: Mon May 12, 2008 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
i have this ones running:
2x CGS 65 Tube VCA ( a third one is not running )
1x CGS 28 Sequential switch ( 3 more Boards populated ) ( Two will give a 8x8 trrigger sequenzer )
1x CGS 36 Pulse divider ( Two more halfways populated last week)
1x CGS 64 VCA, built with SSM2210 ( lost interest, have some more Boards )
1x CGS 52 sinple Wavefolder
1x CGS 29 Wavemultipliers ( this has Issues on the Pulse Knobs ) ( a second one is populated )
1x CGS 31 digital Noise ( has Issues, I can just use white and pink Noise )
2x CGS 24 Gate to Trigger converter ( just populated two more last week )
1x CGS 58 Utility LFO ( just one side wired up, lost interest, have 3 Boards more populated )
1x Psycho LFO ( not wired up, lost interest ) ( i need LFOs with reset inputs )
1x CGS 26 analogic, just populated last Week
not running:
2x CGS 60 Stompbox adapter
on the wish list:
all Drum modules, and some other stuff
sneakthief
PostPosted: Tue May 13, 2008 12:10 am    Post subject: Reply with quote  Mark this post and the followings unread
CGSLD LED drivers
CGS01 Sub-oscillator/harmonic sequencer
CGS03 Psycho LFO
CGS35 Steiner VCF
CGS58 Utility LFO
and I plan on getting the Tube VCA soon Smile
Sneak-Thief - raw electrofunk
zthee
PostPosted: Tue May 13, 2008 12:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I've built the following
CGS04 - mixer
CGS24 - Gate to trigger
CGS29 - Wave multipliers
CGS34 - ASR
CGS35 - Steiner
And I'm gonna order the following in june
CGS01 - Sub osc
CGS03 - Psycho LFO
CGS26 - Analog Logic
CGS28 - Seq. switch
CGS31 - Digital noise
CGS36 - Pulse divider
CGS64 - VCA
CGS66 - PSU
I need more CGS modules! Very Happy
PostPosted: Tue May 13, 2008 12:52 am    Post subject: Reply with quote  Mark this post and the followings unread
the very first module i ever built was the
psycho LFO (added a LED in meantime), then
two dc mixers
two passive ringmods
wavemultiplier
vc divider
utility LFO
b'n'tic VCO/F
harmonic suboscillator
cheers,drunken
pix of my work at flickr
Scott Stites
Audio files: 83
PostPosted: Wed May 14, 2008 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
IIRC, my first ever module was the Wave Multiplier - I've got bunches of Stone, built and un-built. But, that Wave Multiplier hardly ever goes unused in a patch. Holy Mackeral, I love that thing!
I'm not quite clear about what you just spoke
Was that a parable, or a very subtle joke?
- Brad Roberts
My Site
krisp14u
PostPosted: Thu May 15, 2008 4:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I have built and working with panels
CGS21 Super Psycho LFO (fun fun fun)
CGS33 Matrix Mixer
CGS57 Bi-N-Tic Filter (this is a must build i will make another soon)
CGS59 Programmer Sequencer (8 steps) (needs a front panel)
CGS65 Tube VCA x2 (everything must go through one of these )
part built or to build soon
CGS09 VC Divider
CGS57 Bi-N-Tic Filter ( I need another)
CGS65 Tube VCA x2 (I hope 4 will be enough )
Hum dum,
Agga pang,
Ing, ang, ooo
www.krisp1.com
andrewF
PostPosted: Thu May 15, 2008 8:29 am    Post subject: Re: What CGS modules have you built Reply with quote  Mark this post and the followings unread
CGS65 Tube VCA x2
What !?! No VCOs? Shocked
ericcoleridge
PostPosted: Thu May 15, 2008 10:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Several DC Mixers
A couple CV Mega Mixers
Several LED Drivers
a couple Gate to Trig Blocks
a Couple Slope Detectors
a couple Morph Lags
Sequential Switch
Burst Generator
Wave Multiplier
Sub-Oscillator
Pulse Divider and Logic
Waiting to be built:
Cynare
Drum Simulator
The Alison Project
PostPosted: Thu May 15, 2008 9:57 pm    Post subject: Re: What CGS modules have you built Reply with quote  Mark this post and the followings unread
Yeah not yet, I'm good for VCO's right now. When I need another VCO thou I am giving the CGS one a shot, full version.
The Alison Project
andrewF
PostPosted: Mon May 19, 2008 5:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
guess I'm up there in AlisonProject territory Smile
CGSLD LED driver lots
CGSRR Real Ring Modulator (3 diy)
CGS01 Sub oscillator 2
CGS02 Wavetable 2
CGS03 Psycho LFO 2
CGS04 Mixer 8 (2 joystick controllers)
CGS06 Burst generator 1
CGS07 Gate Sequencer (3 board set) 1
CGS07P Gate Sequencer Preset board 1
CGS08 V8 simulator 1
CGS09 Voltage Controlled Divider 2
CGS10 Pedal board/Mini Keyboard 1
CGS12H Display Adapter - 2
CGS13 Gated Comparator 2
CGS18 Drum simulator 2
CGS19 Chime/bell simulator 2
CGS21 Super Psycho Modulation source 3
CGS22 Master Divider 2
CGS23 CV Mega Mixer 1
CGS24 Gate to Trigger Converter 2
CGS26 Analog Logic voltage processor 2
CGS27 7 pin tube experimenter board 3
CGS28 Sequential Switch 2
CGS29 Wave Multipliers 1
CGS30 Band pass filter 2
CGS31 Digital Noise 1
CGS32 Infinite melody 1
CGS33 Matrix Mixer 1
CGS34 Analog Shift Register 3
CGS35 Steiner VCF 2
CGS36 Pulse Divider 2
CGS37 CV Cluster 1
CGS38 Saw Pitch Shifter/Wave Multiplier 1
CGS39 Quad logic gate 2
CGS40 Modulo Magic 1
CGS41 Diatonic Converter 1
CGS42 Gate Seq. CV Adapter 1
CGS43 Cascade Mixer 1
CGS45 Dome Filter. 3
CGS47 Cynare drum sim. 1
CGS48 VCO. 13
CGS50 Harry's Morph-Lag 1
CGS51 Weighted Random Switch 1
CGS52 Simple Wave Folder. 3
CGS55 Analog Switch Matrix. 1
CGS56 Gate Converter 1
CGS57 Bi-N-Tic Filter. 2
CGS58 Utility LFO. 2
CGS59B/4xA Programmer/Sequencer 1
CGS62 Slope Detector. 2
CGS64 VCA. 4
CGS65 Tube VCA 2
RF
PostPosted: Mon May 19, 2008 6:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
andrewF wrote:
CGS48 VCO. 13
Shocked VCO's! Laughing
I am not worthy......
bruce
The Alison Project
PostPosted: Mon May 19, 2008 6:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
AndrewF, damn....
I'd be interested to see what you did with the Dome Filter.
Chris
The Alison Project
Scott Stites
Audio files: 83
PostPosted: Mon May 19, 2008 6:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
That modulo magic thread sure got me to thinking about that one.....
- Brad Roberts
My Site
andrewF
PostPosted: Mon May 19, 2008 7:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
frequency shifter - the panel is set up to be patched as I like, or use each section as a stand-alone module - it also has 6 ring mods (4 - 1496 based, 2 passive), 2 quad oscillators, a CGS VCO and the rest from Electronotes.
to be honest, I have never got around to tuning it properly, it makes plenty of weird noises as is. One day i will sit down with some set-up instructions and a 'scope to sort it.
It is one project I would like to re-do sometime - requiring more Dome filter PCBs. If enough people are keen, we might be able to convince Ken to do another run.
You would also need Electronotes to see the schematic - it is in the Preferred Circuits collection ( ~$30 or so ).
The Alison Project
PostPosted: Tue May 20, 2008 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very Impressive. Andrew I just realized who you are, I have spent alot of time drooling at the pics on your webpage. When I first started building CGS stuff I would look all the time to what panel components you were using etc etc (well trying, that crazy artwork can be hard to read).
The Alison Project
otherunicorn
PostPosted: Wed May 21, 2008 1:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I hate to boast, but I've built all of them Smile
Of course the correct response to this is "I should sincerely hope so!"
http://www.cgs.synth.net/
johans121
PostPosted: Wed May 21, 2008 6:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, I should sincerely hope so!
Luka
PostPosted: Sun Jun 15, 2008 3:36 am    Post subject: Reply with quote  Mark this post and the followings unread
i just finihsed my VCO, utilty LFO, psycho LFO, digial noise, real ring module
i have a steiner vcf on the bench that has some wack problem
Smile
so happy
this is the first analogue VCO ive had
it sounds unbelievable
these are my first completed modules woohoo
got so many more to do now
the cgs modules left to come are
2 x tube VCA
1 x VCA
1 x wavemult
3 x dc mixer
thanks ken and laurie!!
problemchild
melbourne australia
Music123.com - Customer Appreciation Sale Extended! - Save Up To $80 Off Your Order - Sale Ends Soon!
