 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
Andromeda for Trance ?
Page 1 of 1 [10 Posts]
synthmad
PostPosted: Thu May 15, 2008 1:58 pm    Post subject: Andromeda for Trance ? Reply with quote  Mark this post and the followings unread
I'm thinking about buying an Andromeda.
I love the pads, strings and other samples I've found on the net but how useful would the Andromeda be for Trance music ? Can it recreate a supersaw ?
thanks.
Ryowolf
PostPosted: Thu May 15, 2008 9:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
I make a lot of trance music and I own an A6. I could break it down for you and fluff it up, but I will just say one thing.
Forget the Virus. This is the end of the road.
synthmad
PostPosted: Fri May 16, 2008 4:03 am    Post subject: Reply with quote  Mark this post and the followings unread
The Virus Ti has some nice sounds, although sounding very digital compared to the Andromeda. I would consider a TI but I have read that it has serious issues/bugs with polyphony and clicks.
soundwave106
PostPosted: Fri May 16, 2008 5:42 am    Post subject: Re: Andromeda for Trance ? Reply with quote  Mark this post and the followings unread
Sure. Attached is an example of a trance type sound I created with the Andromeda and a Lexicon MPX-1 reverb unit. (If people want the sysex to this, I can post this as well.) Trance isn't my normal genre, so if people have better examples, post em. Smile
Basically the unison detune sounds will get you where you want. The above sound is 8-voice unison detune, two oscillators, using a combination of saw and PWMed square. I tied the filter to the ribbon control.
I do not like the built-in reverb (the Wedge) for the long-decay type reverb typical in trance, but other than that the Andromeda should work quite well.
AndromedaTrance.mp3
 Filename:  AndromedaTrance.mp3
 Filesize:  971.74 KB
 Downloaded:  116 Time(s)
synthmad
PostPosted: Fri May 16, 2008 5:52 am    Post subject: Reply with quote  Mark this post and the followings unread
nice, thanks for that Very Happy
sunny pedaal
Audio files: 12
PostPosted: Fri May 16, 2008 6:34 am    Post subject: Re: Andromeda for Trance ? Reply with quote  Mark this post and the followings unread
[quote="soundwave106"]
sound like in the club, would be nice to study the sysex, so feel free to post it too.
analogstndrpusy
PostPosted: Fri May 16, 2008 7:32 am    Post subject: Reply with quote  Mark this post and the followings unread
very cool sound! im also not into trance but i can appreciate some good programing. post the sysex please. Smile
jonkull
PostPosted: Fri May 16, 2008 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I own both an Andromeda and a Virus TI. Of course I never have time to use either of them. Sad
Naturally the Andromeda has a warmer thicker sound but may require more programming to get the sound you're after...but that may be a good thing.
The Virus is a nice sounding instrument and will get you up and running quicker because it has a multitude of trance-like patches built in. It's not as thick sounding as analog though...especially with effects turned off. I find that my analog gear tends to overpower it in a mix.
In the end it depends on what you're after...an endlessly complex analog polysynth or instant gratification.
soundwave106
PostPosted: Fri May 16, 2008 5:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
The sysex for this patch is attached.
GenTrance.syx
 Filename:  GenTrance.syx
 Filesize:  2.29 KB
 Downloaded:  27 Time(s)
analogstndrpusy
PostPosted: Sat May 17, 2008 3:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
cool patch. thanks for sharing.
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
