 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
 Forum index » Online Music
tube'|123 - d'incise - Les Restes du Festin
le youth
PostPosted: Fri May 16, 2008 6:15 pm    Post subject: tube'|123 - d'incise - Les Restes du Festin Reply with quote  Mark this post and the followings unread
«Rhythms that bleed. Rhythms that rust and fall apart. Rhythms that fracture your perception of time. D'incise's decompositional approach is charged with an electricity that turns actual objects into distorted images. At times, you will find your neck's vertebrae moving back and forth to keep a time only existant in your mind. In the collaborative nature of "Les Restes du Festin", we can hear micro-cuts from various improvised music recordings of Johann Bourquenez (piano), Christian Graf (guitare), Christophe Berthet (saxophones), Gaël Riondel (saxophones), Cyril Bondi (drums) and d'incise (piano and percusions). In addition, we can hear the talented intervention of Lena, Bluermutt, Hopen, Ibakusha, and Monsieur Connard.
Here, electronic thoughts are translated into numerous acoustic dances to the point of loosing distinction. Dancing thoughts of electronic motion. A grand piano that stands up as anthropomorphic figure to interact and dialogue with the player. Frequencies that tickle the tympanic membrane in order to descend through the eustachian tube reverberating eternally. Binary codes that materialize into percussive instruments; number ones as drumsticks, and zeros as bass drums.
Dusty pieces of metal falling through a waterfall of sound waves until they reach the depths of an ocean of noise. Water ripples become multicolored threads that float around a beam of light. Mercury plugs that melt when plugged into amplifiers. Unidentified Flying Objects that become cymbals and give a message about phenomenal spaces. Static hairs follicles that abandon the skin to encounter the vibrations coming from the speakers. These are some of the visions I receive when listening to this sonic constructions. Micro-cuts from a macro-musician.» - Sebastian Alvarez
TEST TUBE netlabel:
http://testtube.monocromatica.com/releases/tube123.htm
direct download:
http://testtube.monocromatica.com/releases/tube123/tube123.zip
mémoire/imaginaire.recréer la poésie.
restes, bribes, cendres, déblais, débris, décharges, dépouilles,
épaves, excédents, fragments, os, poussières, rebuts, reliefs, reliquats, résidus, ruines, souvenirs, surplus, survivances, traces, vestiges...
lieux qui n'ont que l'apparence. carte de l'autre pays.
surface et sousface. être ou disparaître.
y'a-t-il une différence
entre un acteur et un mort ?
entre une image et une tombe ?
évoquer les façades.
ravaler la fuite.
rendre le pardon.
digérer le jour d'hier.
vomir celui à vendre.
inventer celui qui est nié.
il n'y a plus de théorie.
plus de table des matières
plus de mètre égale à un autre.
tout est là.
rien n'est là.
en même temps.
[music under CC by.nc.nd, copy & share, thanks]
http://www.audioactivity.net
Top Selling Products! CLICK HERE!
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
