 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
HowTo Install ChucK on Max OSX 10.4
Page 1 of 1 [2 Posts]
jbrunker3
PostPosted: Sun May 18, 2008 11:51 am    Post subject: HowTo Install ChucK on Max OSX 10.4
Subject description: HowTo Install ChucK on Max OSX 10.4
OK, I downloaded the ChucK tar file, and expanded it on my desktop.
The instructions are supposed to be simple, so I must be missing something.
The instructions say to cd '/bin' and do a copy of the ChucK executeable, but .... that doesn't make sense ... since there's no executeable there naturally for ChucK.
Would appreciate some help on hos to get ChucK installed on my latop.
Thanks,
JayB.
Audio files: 10
G2 patch files: 58
PostPosted: Sun May 18, 2008 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have you tried MiniAudicle? http://audicle.cs.princeton.edu/mini/ It's a graphical frontend for ChucK, and Chuck comes with it, so if you install MiniAudicle you get what you want.
For the plain ChucK that you donwloaded, when I look at the archive, if I open bin I see a file called chuck. That's the executable. You need to open a terminal, go to the bin directory with cd (cd Desktop/check-1.2.1.1-exe/bin) and then execute it with ./chuck. If you don't like terminals, go for MiniAudicle.
/Stefan
@myspace @virb A blog home - in Cyberspace no one can hear you SEGV
Once You Know, You Newegg
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
