 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
How I manage my PC trouble free...
Page 1 of 1 [7 Posts]
jjj
PostPosted: Tue Apr 08, 2008 9:16 pm    Post subject: How I manage my PC trouble free... Reply with quote  Mark this post and the followings unread
Here I just want to share my trouble free PC joy with you.
My PC has Win-XP and Win-Me on two different Pri-partitions installed; controlled via BootMagic.
For years I went through hell with all sorts of crashes, OS re-installations, data losses and... you name it.
I also tried countless rescue, data recovery and backup programs...
Nothing really saved me from disasters. Too often my Win-XP refused to boot and I had to go through days of re-install miseries. Crying or Very sad
I then tried Deep Freeze. It helped, but it wasn't flexible enough.
With Rollback Rx my nightmares finally ended, because I can update my PC manually or automatically (in seconds) and it takes amazing little disk space. Check it out!
The only thing that can go wrong now is when the HDD dies! To prevent that sort of data loss I copied the whole HDD onto another identical HDD, then unplugged its power cable; adjusting BIAS.
Jeez, I'm so glad I finally found that illusive PC peace. Now I have time for more constructive PC creativity and hope you too have found your PC peace.
Please tell me how you did it even better... Smile
TheShaggyDA
PostPosted: Sun May 18, 2008 5:18 am    Post subject: Re: How I manage my PC trouble free... Reply with quote  Mark this post and the followings unread
Bought a Dell laptop 5 years ago, running XP. Used daily, haven't had any problems. I just keep it clean with the odd defrag, and I don't install anything I don't really need. It's my main PC, so it's not just for browsing - I use it for Visual Studio 2005 and Cubase SX3. For other O/S work I use a virtual PC.
Going to treat it to a RAM & HD upgrade soon, so it'll probably start failing once I've spent money on it Smile
It's a huge contrast to my work PC, a Sony Vaio running Vista. I've had it for 6 months and a week hasn't gone past without it freezing randomly or going sluggish for no apparent reason. Once I've collected the necessary drivers, it'll be getting wiped and having XP Pro put on it.
Audio files: 25
PostPosted: Sun May 18, 2008 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm wondering why you're still bothering with a dual boot system jjj. Especially if it's just to run ME. I've found ME to be nothing but trouble.
XP on the other hand is a joy. My machine is the leanest and meanest it's ever been. I keep XP squeaky clean by following the Tweak Guide written by Koroush Ghazi. Great guy.
http://www.tweakguides.com/TGTC.html
If you don't sing in a government choir,
and you forget why you got hired,
you can warm your hands on friendly fire.
- John Foxx
jjj
PostPosted: Sun May 18, 2008 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Thx for the Tweak guide; I'll try it.
Yes, I still use dual-boot XP & WnMe. True WinMe is quite troublesome, but at least it re-installs in a flash. I only use it for some good legacy software, which only work properly with Win98/Me. Maybe XP's compatibility function can overcome it, but my vidio/TV card and SoundBlaster-Live soundcard only works with Win98/Me or by sacrificing many features in XP (or by using drivers ...with love from Russia: http://kxproject.lugosoft.com/forums.php?language=en ) That's why I'm stuck with Win/Me.
All I was looking for was a reliable way of booting XP, for almost every month or so, it just refused to boot and I couldn't repair it with "R".
That's where Rollback Rx really put an end to it.
Yet, last week even Rollback Rx seemed to fail: on booting the XP's loading indicator moved about 20 times, when a blue screen momentarily showed up and the PC restarted again. This cycle never ended! I tried every trick and nothing seemed to help.
Yet then, after I prepared for copying the backup from my spare HDD... (surprise!) suddenly Rollback Rx booted again properly!
From that I take that it must have been merely a BIOS malfunction, because after renewing the HDD connection in BIOS, Rollback was able to read the HDD properly. So, I was wrong to distrust Rollback Rx as well, because only hardware malfunctions impede its performance. Smile
Audio files: 25
PostPosted: Sun May 18, 2008 3:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
A soundblaster live will run perfectly under XP. I had mine installed for years with no troubles. It does take a bit of setting up though. You have to completely remove all sound card drivers first. Then run the latest "Liveware" drivers manually.
Have you got Service Pack 2? It sounds like you don't. Because without it XP is quite unreliable.
Sudden rebooting is often due to heat and or connection problems. Make sure you clean all the dust off your CPU heatsink, and everywhere else, and check that all connectors are clean and shiny. The ATX power connector typically carries a bit more current than it should on older Motherboards and can get a bit dodgy from heating/cooling cycles. Check it.
- John Foxx
PostPosted: Sun May 18, 2008 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah yes- but this looks even more cool!!!;
nLite
dead cool site too Cool Cool Cool
jjj
PostPosted: Sun May 18, 2008 7:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
A soundblaster live will run perfectly under XP. The latest "Liveware" drivers manually.
I tried all of that, but it mugged up the original program features. Kx driver do a better job than SB. Also, better than manually deleting SB bad uninstall files, is to just rename the folder, because some of their files still might hang around in the system, causing installs.
My XP has got Service Pack 2.
In my case it was only an "one-of problem", which didn't repeat since. It really must have been just a corrupted BIAS setting, but it took me about an hour to discover it; only by chance, after I was ready to re-install a copy of the backup. At least, I learnt again something from it...
Beside, I clean the CPU-heatsink regularly. Smile
Top Selling Products! CLICK HERE!
Copyright © 2003, 2004, 2005, 2006 and 2007 by electro-music.com
