2D Array: value assignment problem
Page 1 of 1 [7 Posts]
kijjaz
PostPosted: Sun May 25, 2008 12:50 pm    Post subject: 2D Array: value assignment problem Reply with quote  Mark this post and the followings unread
I've got this code:
Code:
(second/samp) $ int => int SampleRate;
float A[SampleRate, SampleRate];
for(int x; x < SampleRate; x++)
for(int y; y < SampleRate; y++)
    (x $ float + y $ float) / SampleRate / 2 => A[x,y];
i'm running on Ubuntu Linux 8.04, sample rate = 48000
other things work fine,
but with the above program it says:
Code:
chuck: chuck_type.cpp:3185: Chuck_Type* type_engine_check_exp_array(Chuck_Env*, a_Exp_Array_*): Assertion `array->indices->depth == depth' failed.
Aborted
What did i do wrong?
Inventor
Audio files: 67
PostPosted: Sun May 25, 2008 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
kijjaz, the correct syntax for a 2D array is:
Code:
a[10][10]
Also, you are defining an array with 2.3 trillion elements in it. When I fixed your code and ran it, my poor little Mac locked up and I had to reboot! Serves me right for not reading the code carefully, haha!
For those about to ChucK, we salute you! - Ge Wang
Let's make noise for peace! - kijjaz
PostPosted: Sun May 25, 2008 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Code:
a[10][10]
Yes. You see that's wrong and I do as well, but I wonder why ChucK didn't complain. I can get this to run;
Code:
int foo[3, 4];
...and I have no idea at all what that would mean. That's not valid syntax, at least not valid in a documented way. I think this is a bug and should be on the WiKi.
Yeah, that raised a eyebrow here...
Code:
Math.pow(48000, 2) => float num_of_floats;
num_of_floats * 32 * 2 => float num_of_bits; //I think this is what double precision means
num_of_bits / 8 => float num_of_bytes;
num_of_bytes / 1024 => float num_of_KB;
num_of_KB / 1024 => float num_of_MB;
num_of_MB / 1024 => float num_of_Gig;
<<<num_of_Gig>>>;
Unless I made some mistake that's slightly over 17 gigabyte. That's quite a array....
Modern technology offers an endless field day to any deviant strains in our personalities. --J.G.Ballard
kijjaz
PostPosted: Sun May 25, 2008 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
hahahhahahhaahahaha oohh yes it's just wrong syntax.
that killed ChucK so should report as bug. lol.
This is nice.
kijjaz
PostPosted: Sun May 25, 2008 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Code:
float A[SampleRate][SampleRate];
    (x $ float + y $ float) / SampleRate / 2 => A[x][y];
result:
(it hangs......) then
Code:
terminate called after throwing an instance of 'std::bad_alloc'
  what():  std::bad_alloc
Aborted
is it simply out of memory for usual allocation?
PostPosted: Sun May 25, 2008 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, unless my math is wrong that's a 17+ gigabyte array, I think we can safely assume that's the issue, yeah. I'm not sure a single process can address that much memory on a 32 bit OS and ChucK won't run in 64 bit, so....
This is probably a good thing because that loop over all the array entries would take a while.
Do I dare ask what you need a array that size for? Couldn't it be simplified just a little bit?
It's certainly a novel way of crashing!
kijjaz
PostPosted: Sun May 25, 2008 9:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was just wondering what I can do with a 2D delay line..
but i guess i should work with a smaller array
and use some optimization methods.
i'll try more hehe.
Music123.com - Customer Appreciation Sale Extended! - Save Up To $80 Off Your Order - Sale Ends Soon!
