Ring Modulator
Page 1 of 1 [14 Posts]
dioioib
PostPosted: Fri May 23, 2008 3:55 pm    Post subject: Ring Modulator
Subject description: DIY Ring Modulator
Hello everyone,
I have been working on a ring modulator with preamp / distortion and bypass switches I will post the schematic and the board layout for you. However, I have run into an issue. Currently I am running off dual 9v +/- batteries, I am able to get a faint sound through the FX board but nothing usable. I am working on a +/- 12v supply as well. Is my problem caused by a lack of power? Have a look and let me know if you can see any glaringly obvious errors.
 Filesize:  88.64 KB
 Viewed:  251 Time(s)
v01_ringmodulator.pdf
 Filename:  v01_ringmodulator.pdf
 Filesize:  1.49 MB
 Downloaded:  245 Time(s)
View user's profile Send private message Visit poster's website Yahoo Messenger MSN Messenger
Audio files: 218
G2 patch files: 319
PostPosted: Fri May 23, 2008 4:05 pm    Post subject: Re: Ring Modulator
welcome
The polarity of C1 ... but that's not causing the problem Laughing
Maybe you need more amplification around IC3 (as U$1 does a /10) ?
Inventor
Audio files: 267
PostPosted: Sat May 24, 2008 12:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, your 741 opamp input pins are connected backward on the two input buffers. You need negative feedback for an inverting amplifier stage, not positive feedback. Running an opamp with positive feedback is in general not recommended unless you purposely want the opamp's output to swing from rail to rail for some reason, such as in a relaxation oscillator (ahhhh, how relaxing). Try lifting the 741 input pins and soldering little bitty wires to swap the inputs. You can debug this with a meter (if you don't have a scope) by measuring the AC RMS value of the input and the output. There should be signal at both the input and the output when the circuit is working properly. Good luck and remember: opamps *like* negative feedback, it keeps them stable!
dioioib
PostPosted: Sun May 25, 2008 8:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
So swap pins 2 and 3 of each input op amp and fix the reversed cap and I should be good to go?
As for the green wiring you should see my prototype. Very Happy
I'll post the results when I am finished.
dioioib
PostPosted: Sun May 25, 2008 8:59 pm    Post subject:
Subject description: v0.2
Here is an update to the schematic and board. I will try cutting the traces and green-wiring my prototype tomorrow.
 Filesize:  173.87 KB
 Viewed:  316 Time(s)
 Filesize:  223.17 KB
 Viewed:  245 Time(s)
Inventor
Audio files: 267
PostPosted: Mon May 26, 2008 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, you should be good to go after that, just let us know how it works.
dioioib
PostPosted: Tue May 27, 2008 5:41 pm    Post subject: Ring Mod
Subject description: Ring Mod
Not so hot I think I blew something.. It might have been a cap, all I know is there was smoke. Sad
Any Suggestions ?
Audio files: 218
G2 patch files: 319
PostPosted: Tue May 27, 2008 5:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
& the circuit works not?
Most times visual inspection will show where the smoke came from, when it was on the underside of a component it could be hard, maye some smoke residue on the PCB ...
dioioib
PostPosted: Tue May 27, 2008 6:28 pm    Post subject: RingMOD Reply with quote  Mark this post and the followings unread
There is nothing visible but I can smell some char comming from the 2.2uF decoupling caps C3 C4. But they are rated to 100v so that doesn't make any sense when running off 9v unless my input audio voltage was too high. I was only running a Virus TI through it to test though nothing too crazy.
dioioib
PostPosted: Tue May 27, 2008 6:47 pm    Post subject: RingMod Reply with quote  Mark this post and the followings unread
Here are the images of the green wired monstrosity
I didn't have double sided board at the time.
 Filesize:  103.36 KB
 Viewed:  231 Time(s)
 Filesize:  110.43 KB
 Viewed:  216 Time(s)
dioioib
PostPosted: Fri Jun 06, 2008 6:58 pm    Post subject: Ring Mod
Subject description: Latest development
Latest development, a few issues have been discovered. the input resistance for op-amp one and two are too high. I am bypassing these, which, gives a more usable sound after heavy amplification. I am currently working on a +/- 12v power supply. I figure the op-amps might need some more juice, however my power supply is outputting around +/- 8 or 9v. I am using a 115v to 12.6v transformer and 7912 and 7812 regulators. Any Ideas?
Audio files: 218
G2 patch files: 319
PostPosted: Sat Jun 07, 2008 6:01 am    Post subject: Re: Ring Mod
When it's a small transformer that you measured to give 12.6V when not connected to anything the transformer likely just is not up to the job, what voltage do you have after your rectifier / before the regulators / with the load present?
dioioib
PostPosted: Sat Jun 07, 2008 4:00 pm    Post subject: Ring Modulator Reply with quote  Mark this post and the followings unread
Well the voltage after regulation is about 8-9v
the voltage before the bridge rectifier (beads) is around 9v
Pre-transformer I am getting 112v AC should I try another fuse or just swap out the transformer for one with higher voltage? I have a 24v laying around somewhere.
Audio files: 218
G2 patch files: 319
PostPosted: Sat Jun 07, 2008 4:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Either a bigger one with 12 V or one with more voltage ... 24 * 1.4 = 33.6, + 20% = 37.3, - 1.4 = 35.9 ... 24 Volt is a bit much, you don't want to go over 35 V really worst case for regulator sanity ... 15 or 18 V would be Ok, or 12 V with plenty of transformer power.
What you have now before the regulators is too low, they need about 3V of over voltage to properly regulate.
