 FAQFAQ   CalendarCalendar   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   LinksLinks GalleryGallery
Post Your KLEE Panels Designs Here
Page 9 of 12 [292 Posts]
Goto page: Previous 1, 2, 3, ..., 7, 8, 9, 10, 11, 12 Next
mono-poly
PostPosted: Tue Jun 03, 2008 2:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I need a corel or eps format file.
Are there more people who want a panel like that in dotcom format?
Because that really breaks down the price a lot.
cliq
PostPosted: Tue Jun 03, 2008 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
i would be interested in such a panel, too.
Budgrubber
PostPosted: Tue Jun 03, 2008 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I have been sourcing parts for this panel and have not been able to find an eight position rotary switch that is evenly spaced like I have it laid out. If anybody has a source I would be happy to hear about it. Otherwise I will have to change that part of the Range section a little before this gets printed.
mono-poly, I can save it from Illustrator as an EPS but I cannot add it as an attachment to the forum. PM me your e-mail and I will try to send it that way. What is the price looking like? If you don't mind me asking.
bugfight
PostPosted: Tue Jun 03, 2008 2:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Budgrubber wrote:
I have been sourcing parts for this panel and have not been able to find an eight position rotary switch that is evenly spaced like I have it laid out. ...
i used c&k A12515RNZQ
mouser p/n 611-A12515RNZQ
shaft is long, but plastic so easy to cut down.
i also opened it up and cut the stop tab off so it rotates 360
(which i had expected it to do as manufactured...)
Budgrubber
PostPosted: Wed Jun 04, 2008 5:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes! That looks like it will work and it doesn't cost a fortune. Once my order of switches and LED's comes in I should have everything ready to go. Except the panel itself of course.
bugfight
PostPosted: Tue Jun 10, 2008 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, here's my design:
here's a blurry photo, not fully done, but assembled anywayz...
box by hammond, gfx printed on papilio inkjet printable clear adhesive vinyl.
 Filesize:  72.5 KB
 Viewed:  77 Time(s)
here's the design in digital finery, if that's your taste, times being what they are...
 Filesize:  25.89 KB
 Viewed:  117 Time(s)
Audio files: 28
G2 patch files: 295
PostPosted: Tue Jun 10, 2008 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Clear layout, nice looking panel!
Audio files: 25
PostPosted: Tue Jun 10, 2008 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm,
very nice looking, functional layout.
If you don't sing in a government choir,
and you forget why you got hired,
you can warm your hands on friendly fire.
- John Foxx
BananaPlug
PostPosted: Tue Jun 10, 2008 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Um, sorry to do this but it's "Coarse" not "Course." sigh
ultra
PostPosted: Tue Jun 10, 2008 5:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
i think he modded it so it changes directions instead. Wink
bugfight
PostPosted: Tue Jun 10, 2008 5:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Uncle Krunkus wrote:
Hmmm,
thanks guys!
dammit!
i guess i'll just chuck this in the garbage and start over...
but wait...
what's this little blue marker do?
hmmm knotical...
neandrewthal
PostPosted: Thu Jun 19, 2008 12:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Fonik, Krunkus, anyone with sliders, can someone please tell me how much panel space the sliders take up?
PostPosted: Thu Jun 19, 2008 12:08 am    Post subject: Reply with quote  Mark this post and the followings unread
i got alpha's 30mm travel sliders from futurlec. they are about 45mm x 10mm. i placed them with a horizontal spacing of 15mm, considering the knobs i wanted to use.
however, try to find a datasheet for the sliders or even wait with manufacturing the panel until you got your sliders. safety first. Wink
cheers,drunken
pix of my work at flickr
Audio files: 25
PostPosted: Thu Jun 19, 2008 2:03 am    Post subject: Reply with quote  Mark this post and the followings unread
My sliders are a no-name type from Dick Smith.
They're 45mm travel, body 73mm long, 13mm wide, with mounting holes (tapped 3mm) at 65mm centres. I mounted them 17mm apart which requires smaller (10mm wide) knobs than usual. I had to get the knobs from Farnell, they were actually the hardest part of my Klee to source, and the last part placed.
I was thinking the other day that if I were to make another Klee I would replace the sliders with a switch of some type. I don't mean to rain on your parade, but I reckon 95% of the time you actually want the sliders to be at a particular ratio of the maximum voltage scale (which is very flexible anyway) and the ability to dial in an exact fraction is a bit over rated.
A 6 position rotary with a matched resistor network around 5 positions (0,25,50,75,100%) plus a small rotary pot on the 6th position for the extra flexibility.
Just an idea.
- John Foxx
PostPosted: Thu Jun 19, 2008 2:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Just an idea.
absolutely! IIRC we discussed this in the original thread. i was thinking about that, too. someone was pointing to a 4x4 switch matrix with colored illuminated rubber switches, i am not able to find the link, though. i was thinking of using three of them, one for the pattern and one for the gates (only two busses then) and one for the sliders. would make a nice predictable uncertainty (or unpredictable certainty?) sequencer.
cheers,drunken
PostPosted: Thu Jun 19, 2008 2:10 am    Post subject: Reply with quote  Mark this post and the followings unread
does anybody remember this switch matrix i am talking about?
cheers,drunken
bugfight
PostPosted: Thu Jun 19, 2008 5:39 am    Post subject: Reply with quote  Mark this post and the followings unread
was it the sparkfun 4x4?
http://www.sparkfun.com/commerce/product_info.php?products_id=7835
they are kinda big...
i made this for midibox:
http://www.midibox.org/forum/forums.html/topic,10004.msg74631.html#msg74631
in fact, you could replace the entire digital board with a midibox
and get clock, noise, midi sync, stored patches, etc etc
add analog out and you can replace the analog pcb too...
long sequences, multiple outs, wheee
maybe someday...
this has gone a bit off topic though, eh?
PostPosted: Thu Jun 19, 2008 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
BINGO! thank you so much!
cheers,drunken
The Alison Project
PostPosted: Sat Jun 21, 2008 11:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
My Klee V2. Original a 19" panel homemade with sharpie marker (posted back in this thread I believe).
 Filesize:  445.45 KB
 Viewed:  59 Time(s)
The Alison Project
www.thealisonproject.com
djthomaswhite
PostPosted: Mon Jun 23, 2008 2:26 am    Post subject: MOTM KLEE Panel Design
Subject description: 7-Space 5u high panel
Hi guys,
Based off of my MFOS Rotary panel, here is my in progress KLEE panel. I hope to get the kinks worked out of this and maybe production of them through someone (no announcement yet though). The start washers are where push button will go. Large nuts = jacks, small nuts = switches, etc. Those black plugs on some of the holes are Lumex LED's upside down to represent the style I will be using. Thoughts?
Thomas
Check out www.naturalrhythmmusic.com/mfos.html for my other rotary sequencer layout. The FPE panel file for this one is in the filkes section on the Modular Synth Panels group at yahoogroups. Thanks!
 Filesize:  207.98 KB
 Viewed:  56 Time(s)
Thomas
www.naturalrhythmmusic.com/diy.html
Rykhaard
PostPosted: Mon Jun 23, 2008 9:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just checked out the 1st half of Divide By Odd - 1st Movement from your webpage. I can't WAIT to hear what you start doing when your Klee is done! DVO is one of the coolest ambient pieces I've heard in a long, long time! (Not enough time tonight to listen to the whole thing).
The ever changing drones in the background with seemingly odd but not, burblings in the foreground ...... Smile Barking right up my own ambient alley - further inspiring me in my return in building to build FASTER so that I can get enough of my machine up and running to begin composing on it. Very Happy
Great work sir! Looking forward to more from ya! Shocked Very Happy Especially with the power of the Klee! (Reminding myself to start on building mine, SOON! Smile )
Rych
http://www.damian.deathlehem.com/ - home of my modular synth
http://www.rykhaard.com/ - my personal homepage - with 89 of my tunes I`ve writ
http://www.molindarius.com/numerology - my Numerology site with my Numerology software
neandrewthal
PostPosted: Mon Jun 23, 2008 11:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the answers about the sliders guys. I was thinking of having a go at designing one to become a bridechamber panel but not after that Shocked I'm buying one for sure. Looks great!
Edit: I just noticed you said no announcements yet. Didn't Scott Deyo say it's "officially ripped off"?
The only thing I'd change is expand the oval a bit to better fill the space that is available. That would give us just a little more space between the knobs.
djthomaswhite
PostPosted: Tue Jun 24, 2008 12:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, the knobs might look a bit close together, but in my rotary MFOS build the entire center circle of "fine" knobs is as close together as the closest of spacing on this build. I have no experience yet with the KLEE but those who I have spoken with say you end up playing with the load switches often. I don't want to get the oval so big as to interfere with the bus switches for gates or load.
The circle/oval is easy to adjust based on tweaking from the outside edge of the pots and there is no interference with the grabbing of them from both sides either. The only thing I might change is to either shift the oval to the right a bit or two move the switches by the external input jacks on the left. Now that I have had a full night of sleep I seem to think the spacing could be more balanced to the right side of the module.
Scott Deyo... hold on any planning till we get this just right please. Yes, Scott will likely be working to get this out to the masses for one of his awesome prices. Glad to see you're interested and thanks for the feedback. Can the KLEE users out there give this a functionality look over please? Thanks guys!
Thomas
Thomas
Audio files: 25
PostPosted: Tue Jun 24, 2008 7:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Functionality wise it looks just fine.
Very cool looking panel.
- John Foxx
Scott Stites
Audio files: 83
PostPosted: Fri Jun 27, 2008 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
At least for the method of how I use the Klee, I'd have to disagree. This would sort of kill things for one step sequences. For the higher range sequences, the small adjustments do make quite a bit of difference. Lately I've taken to tuning steps to a keyboard in the high range, then going from there. They often "compress" nicely down to the lower ranges. I wouldn't be able to do that with switches.
But each to their own. Very Happy
Cheerio,
Scott
(10000 miles from my Klee Crying or Very sad )
I'm not quite clear about what you just spoke
Was that a parable, or a very subtle joke?
- Brad Roberts
My Site
